		GenGrumpy(at)aol.com Guest
				 Posted: Sat Jun 21, 2008 5:52 pm    Post subject: SB work |
				 For what it's worth for you who have not begun the wonderful task of doing  the SB on the rear bulkhead, here's some data for you.
  Started yesterday afternoon, worked all day today.  10.5 hrs so far  with about 2 hrs to go to finish.
  This is with 2 people working dedicated full time, and assisted by 2 others  when it came time to pull the horizontals off with those blasted trim  cables.
  For those still building the horizontals, make the holes for the cables  bigger than the plans say in case you ever have to take the tail off......
  Riveting the doublers in and re-doing the top plate.......we used hand  squeezers as well as 2 different jaw'd pneumatic squeezers plus rivet gun and  bucking bar to get to all of the required rivets.
  Not a fun job at all.
  No cracks in my bulkhead at 70 hrs prior to installing the doublers.
  Not a fun or easy job.  Find some extra hands to help - you'll need  them.
  grumpy
  N`84JM
 Gas prices getting you down? Search AOL Autos for fuel-efficient used cars.
		Tim Olson
				 Posted: Sat Jun 21, 2008 6:17 pm    Post subject: SB work |
				Hey John, glad you got the SB going!
 I just finished the SB today myself.  Had me and 2 ladies
 to do the work...they did most of it.  We got the HS completely
 off and ready to drill rivets in maybe 2-2.5 hours.  Had the
 doublers in place after lunch, the reassembly went fairly
 well.  I'll do a write-up on it.  My reassembly was perhaps
 longer than some peoples would be, due to some wiring related
 things that I did in addition.
 Total time was about 9.25 hours to complete the SB, and another
 .25 to test fly it.
 This one will definitely have a write-up, although I didn't
 take much for photos since there is already a great online
 photo display of it.
 http://picasaweb.google.com/rv8erpics/RV10SB0861?authkey=HdMqmAzGxsc
 I agree, as far as the holes in the HS go, except I removed my
 HS and Elevators/trim tabs as a unit, so I only had to pull the
 cables from the trim mechanism.
 I did all of my rivets with a rivet gun, and it went real
 quick and easy.
 I found no cracks in the bulkhead, by the way, at 349 hours.
 And I've flown it hard enough shaking that tail with that
 stall series I did video and photos of that I figure if I
 don't have cracks, not many will.  More on that later though.
 The job goes fastest with at least 2 people.  Having 3 there was
 nice in that I was always able to work nonstop as they helped
 with the peripheral tasks so I could plug away.
 Glad to be done!
 GenGrumpy(at)aol.com wrote:
  	  | Quote: | 	 		       **
  trim cables.
  grumpy
  N`84JM
		Lew Gallagher
				 Posted: Sun Jun 22, 2008 4:26 am    Post subject: Re: SB work |
				Hey John, Tim,
 Thanks, I was thinking we are incompetent!
 Similar results -- we also started and finished the SB yesterday -- fortunately the tail feathers were still off, but after spending all afternoon with the two of us, our mutual feeling was "now were back to where we were yesterday"!
 With all the drilling and pounding -- especially in that upper corner where the crack is reported, I can't help but wonder if we didn't weaken it more than strengthen it.  But it's done.
 Later, - Lew
 _________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
		GenGrumpy(at)AOL.COM Guest
				 Posted: Sun Jun 22, 2008 5:25 pm    Post subject: SB work |
				I should have brought mine up to you to do!
  I mis-calculated time yesterday, total time was about 16 hrs, 14 of that  with a dedicated helper.
  We did 2 -10s side by side, with 2 guys working each bird.
  My rudder trim cables were much harder to deal with than the other  bird.....wish I had put a connector into the trim wiring harness.  That  would have made it much easier to deal with the trim assy.
  But....I'm now back up and ready for test hop.
  grumpy-N184JM
  In a message dated 6/21/2008 9:19:35 P.M. Central Daylight Time,  Tim(at)MyRV10.com writes:
   	  | Quote: | 	 		  -->    RV10-List message posted by: Tim Olson <Tim(at)myrv10.com>
 .25 to test fly it.
 quick and easy.
 Glad to be done!
 Tim Olson - RV-10    N104CD - Flying
  	  | Quote: | 	 		          **
  trim cables.
     grumpy
  N`84JM
      es  y       -->                 - MATRONICS WEB FORUMS  nbsp;               - List Contribution Web Site  ;                             =========================
		ddnebert
				 Posted: Mon Jun 23, 2008 4:14 am    Post subject: Re: SB work |
				Fortunately, I still haven't joined my tailcone or have cables in the way, but I began the doubler plate work yesterday. I found that drilling out the old #30 rivets was hard to reach as the shop heads were facing forward and the taper of the fuselage made the angle tough (Did go buy an angle drill tool for this). I clecoed the doublers on the forward side of the bulkhead and carefully drilled perpendicular to make the many new #30 holes, then mounted it on the aft side, reamed, and then deburred everything. Having more than one set of hands will be handy to get the last few rivets in.
 How do you all get those nasty filings out of the tailcone? Someone needs to invent a drill with a powerful vacuum... Best I can do is with a vacuum and attachment.
		|  Description: |
				| Placed doubler on fwd side to make initial holes. |
		|  Filesize: |
		 41.11 KB |
		|  Viewed: |
		 713 Time(s) |
		|  Description: |
				| Doubler on aft side after reaming and priming |
		|  Filesize: |
		 38.5 KB |
		|  Viewed: |
		 757 Time(s) |
 _________________ RV-10 Builder #40546
Tail mostly done, wings complete, end of SB fuse, working on doors and fiberglass |
		Tim Olson
				 Posted: Mon Jun 23, 2008 5:36 am    Post subject: SB work |
				Yeah, I used a 90 degree drill for those couple rivets holding it on
 to the top of the bulkhead.  A small 90 drill like you can get
 from aviation tool places works well for that.  I clecoed mine
 on the aft part of the bulkhead, since I figured for the match
 drilling we were doing that was the best, and used the same
 90 degree drill to drill the holes.  I just worked alone on that
 part.
 The attached photo shows the attached doubler plate.  I used
 a rivet gun on the forward side, for a couple reasons....1)
 the rivet head should technically be on the thinner material
 if possible.  2) it gave more clearance for the gun.  I was
 shocked that after a couple years without much riveting, they
 all came out perfect.  It was easy to rivet and buck working
 alone in this area.
 To get the filings out, I used a small shop vac hose, and banged
 outward against the side of the skin to get the shavings to
 loosen and get sucked up.  No fun, but I got most of them.
 Wish I would have had my akzo primer, but I settled for a
 bit of self-etching on this part.  Not perfect, but it worked.
 ddnebert wrote:
  -------- RV-10 Builder #40546 Tail mostly done, wings complete,
  starting SB fuse
				 Posted: Mon Jun 23, 2008 8:41 am    Post subject: SB work |
				ddnebert wrote:
 AMEN!!!
  	  | Quote: | 	 		   How do you all get those nasty filings out of the tailcone?
 I have a 3' length of 1/2" PVC pipe taped to the regular round vacuum
 attachment.  It works well, but the 1/4" PVC pipe may work better.  My
 shavings are still in there until I finish the riveting
 Linn
		toaster73(at)embarqmail.c Guest
				 Posted: Mon Jun 23, 2008 11:05 am    Post subject: SB work |
				How about masking off and using drop cloth before beginnning.
 -Chris Lucas
 #40072
		AirMike
				 Posted: Thu Jun 26, 2008 10:07 pm    Post subject: SB work |
				Started re-assembly after deconstructing the tail. I did it without an angle drill.....  How? Got in as tight as I could with the red Sioux drill. Then I used some creative bending of my long 30 & 40 bits that I got from Cleveland. I first drilled the rivets with a #40 bit going all the way through VERRRRY carefully to stay in the center. Drilled the heads with the 30 drill - broke off the heads and then pulled the rest out with a compression pliers. I only buggered one hole slightly this way. Trimmed out the doubler and primed it and started squeezing the double rivets.
 Got all of them but 6. Need a partner to shoot while I buck tomorrow.
 12 hours in and 2-3 to go.........uggggg
 _________________ See you OSH '18
Q/B - sold. |
				 Posted: Fri Jun 27, 2008 8:35 am    Post subject: SB work |
				Completed the job in 6 unhurried hours on an assembled fuselage without
 the tail surfaces installed.
 Drilling out the rivets was pretty easy.  Sharp bits help.  So does a
 12" bit and an angle drill for 2 or 4 of them.
 Was able to power squeeze all the doubler rivets and all the horizontal
 tail deck rivets with the exception of 4.  Used a hand squeezer on the 6
 or 8 rivets that go into the vertical tab at the front.
 Bill Watson
 Durham NC
 See you at Oshkosh
		johngoodman
				 Posted: Mon Jun 30, 2008 5:37 pm    Post subject: Re: SB work |
				Started it yesterday on an unattached tailcone. I've logged 8 hours and 2.8 for my wife. Will probably finish in another 2 hours after I borrow a 4" yoke. I only drilled out the two rivets on each side common to the F-1010 and F-1010A. This is the hardest part. The entire operation can be done from outside the tailcone, although I had an advantage in that I could roll it to one side or the other on a table for easy access.
 There is no need to pull the F-1014 aft deck and ruin those "beautiful" rivets. The right tools are essential. Sioux drill, Right Angle drill attachment with the optional chuck - such as Avery's kit, slightly longer chucking bits than normal, a mirror, and a flashlight held by you-know-who.
 Everything is accessible through the lightening holes in the aft deck and the large hole in F-1009. If you can't roll the tailcone from side to side like I could, it's still doable, but will definitely be less comfortable.
 I buggered one of the four rivets that was inboard, so I carefully "buggered the other one to match." Drilled them to take an AN3-5A and it looks great.
 As soon as I borrow the 4" yoke, I'll get the hard to reach ones done. The pneumatic squeezer doesn't get along with the one rivet next to the J-channel, so I'll probably have to shoot & buck it. De-burring was surprisingly easy, although the mirror makes your sense of direction go crazy.
 I'm extremely pleased with the results and I didn't have to touch the aft deck (although it did teach my forearms a lesson). I would highly recommend doing it this way if at all possible. I doubt if it's any faster, but I sure feel better about leaving the aft deck alone.
 For you flying guys, Tim's discovery of some smoking rivets may make the Van's way the preferred method - I might have missed something like that.
 John
 _________________ #40572 Phase One complete in 2011 |
		Kearney(at)shaw.ca Guest
				 Posted: Mon Jun 30, 2008 6:54 pm    Post subject: SB work |
				Hi
   6nbsp;
  A question from a member of 6nbsp;the peanut gallery who just received the SB kit E Is there any reason that Cherry Max rivets 6nbsp;shouldn 7t be used 6nbsp;for the hard to reach rivet locations?
   6nbsp;
  Inquiring minds need to know E E E
   6nbsp;
  Les Kearney
   340643 6nbsp;
		pascal(at)rv10builder.net Guest
				 Posted: Mon Jun 30, 2008 7:40 pm    Post subject: SB work |
				nope!
  Sent: Monday, June 30, 2008 7:50 PM
  Subject: Re: Re: SB work
  Hi
  A question from a member of the peanut gallery who just received the  SB kit. Is there any reason that Cherry Max rivets shouldn't be  used for the hard to reach rivet locations?
  Inquiring minds need to know...
  Les Kearney
  #40643
		Tim Olson
				 Posted: Mon Jun 30, 2008 8:44 pm    Post subject: SB work |
				You should be able to use them.  The only caveat is that
 if you use them, and there is another better "fix" down the line
 that is required, it's very very hard to drill out CherryMax
 rivets compared to just drilling standard universal rivets.
 If it's forever though, then there shouldn't be any big problem.
 pascal wrote:
 [quote] nope!
  *Sent:* Monday, June 30, 2008 7:50 PM
  *To:* rv10-list(at)matronics.com <mailto:rv10-list(at)matronics.com>
  *Subject:* Re: Re: SB work
  Hi
  Les Kearney
  #40643
		wcurtis(at)nerv10.com Guest
				 Posted: Sun Jul 13, 2008 3:07 pm    Post subject: SB work |
				 	  | Quote: | 	 		  Rob Wright wrote:
 Crack SB complete; 6 hours and a couple of difficult rivets (did not remove top shelf)!
 So I must have done something wrong.  I see folks taking A LOT of hours to comply with the SB.
 Assuming you are still constructing and have the tail off, to drill out the 50 or so rivets, match drill the reinforcing plates, and then re-rivet, took me under 3 hours--one hour to drill out rivets and match drill; one half hour to prime and deburr; and another hour to re-rivet.  And that was only because I was doing other things during that time.  Again, this is for those that did NOT have to remove the tail--what is all the extra time spent on?  Doing it by not removing the top shelf should take even less time--maybe.
 http://nerv10.com/wcurtis/05Tailcone/Tailcone90.html
 William
		jim(at)CombsFive.Com Guest
				 Posted: Sun Jul 13, 2008 3:26 pm    Post subject: SB work |
				It's that initial set of assumptions you make -
 (1) "Assuming you are still constructing and have the tail off"
 (2) "(did not remove top shelf)"
 Many folks have the tail on.  Taking it off and putting it back on, in addition to removing the rivets on the top shelf makes for much more time.
 Jim Combs
 40192
 Date: 2008/07/13 Sun PM 07:19:44 EDT
 Subject: Re: SB work
 William
		flywrights(at)yahoo.com Guest
				 Posted: Mon Jul 14, 2008 8:36 am    Post subject: SB work |
				Nah, It took me more time to leave the shelf on because I'm better (I think) at manuevering in small places than drilling out so many rivets without elongation.
 Rob
				 Posted: Mon Jul 14, 2008 10:10 am    Post subject: SB work |
				This is probably common knowledge http://home.earthlink.net/~gilalex/Rivet/ but  when I did this SB I used this method. I was quite surprised that there wasn't  one rivet in the complete process I messed up.. first for me!!
  I actually have a better looking shelf now than I  did before starting.. There were 3-4 rivets I looked at and thought there were  awful, that are now much better looking.
  Pascal
  Sent: Monday, July 14, 2008 9:33 AM
 Rob
  -----  Original Message ----
 From: William Curtis <wcurtis(at)nerv10.com (wcurtis(at)nerv10.com)>
 Sent:  Sunday, July 13, 2008 7:19:44 PM
 --> RV10-List message posted by: "William Curtis" <wcurtis(at)nerv10.com (wcurtis(at)nerv10.com)>
 Assuming  you are still constructing and have the tail off, to drill out the 50 or so  rivets, match drill the reinforcing plates, and then re-rivet, took me under 3  hours--one hour to drill out rivets and match drill; one half hour to prime and  deburr; and another hour to re-rivet.  And that was [quote]
 title='3D"http://www.matronics.com/Navigator?RV10-List"
CTRL + Click to follow link' href='3D"http://www.matronics.com/Navigator?RV10-List"'>http://www.matronics.com/Navigator?RV10-List
 href='3D"http://forums.matronics.com"'>http://forums.matronics.com
 href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/contribution
				 Posted: Mon Jul 14, 2008 10:39 am    Post subject: SB work |
				Yeah, I learned this at an OSH workshop a few years ago but this is a good reference.  I usually skip step 3 however.  I just use a #40 bit into the 1/8" rivet and then use a #40 punch to snap off the head.  Usually works real good an a lot less chance of "buggering' the 1/8" hole.
 William
		Tim Olson
				 Posted: Mon Jul 14, 2008 10:58 am    Post subject: SB work |
				Yes, that's the best method that I've ever been told in the
 past also.  I personally use a flat ended punch to snap
 them off, although some people use the flat end of a drill
 bit.  It works well, because you're just snapping the head
 of the rivet off.  You can do it with a smaller sized bit,
 too.  It's been suggested before that people buy a #31 and
 #41 bit, because then you can drill ever so slightly
 undersized to the hole, so you don't hit the surrounding
 metal if you're off center.  Not much difference, but it's
 nice.  At OSH it might be worth poking around with the
 vendors to get those bits.
 pascal wrote:
 [quote] This is probably common knowledge
  Pascal
  *From:* Robert Wright <mailto:flywrights(at)yahoo.com>
  *Sent:* Monday, July 14, 2008 9:33 AM
  *Subject:* Re: SB work
  without elongation.
  Rob
