jkreidler
Joined: 13 Feb 2008 Posts: 151 Location: Sheboygan Falls WI
Posted: Tue Jul 15, 2008 4:06 am Post subject: Antenna Wire |
How has everyone been creating antenna wires? Is there a good 'cheap' tool for crimping on BNC connectors? I know we can purchase the bulk wire and connectors, we are just not sure if there is a good reliable way of crimping on the connectors. The alternate question would be, does anyone have a good source for a company that will make custom antenna wires (we specify the length and connectors)?
Thanks, Jason Kreidler
4-Partner Build (Jason Kreidler, Tony Kolar, Kyle Hokel, Wayne Elsner)
Sheboygan Falls, WI
#40617 Finishing
Do Not Archive [quote][b]
_________________ Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617 |
Tim Olson
Posted: Tue Jul 15, 2008 4:38 am Post subject: Antenna Wire |
The crimping is easy, and I think I got my crimper from
Stein. The BNC and TNC connectors I use are "crimp or solder"
terminals also for the center conductor, but I've soldered
all of mine. The external crimp is nothing to worry about.
jason.kreidler(at)regalbeloit.com wrote:
Sheboygan Falls, WI
#40617 Finishing
roadmaps
Posted: Tue Jul 15, 2008 4:44 am Post subject: Antenna Wire |
Jason,
I highly recommend you contact Stein (Stein(at)Steinair.com (Stein(at)Steinair.com)) for wire, tools, panels, and/or cabling. He has good prices and can be very helpful for homebuilt panels and wiring.
(no association, just a happy customer)
John Testement
jwt(at)roadmapscoaching.com (jwt(at)roadmapscoaching.com)
40321
Richmond, VA
Painting and final assembly
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jason.kreidler(at)regalbeloit.com
Sent: Tuesday, July 15, 2008 8:03 AM
Subject: Antenna Wire
Sheboygan Falls, WI
#40617 Finishing
Do Not Archive | Quote: |
Checked 270.4.10/1551 - Release Date: 7/14/2008 6:49 AM
wcurtis(at)nerv10.com Guest
Posted: Tue Jul 15, 2008 4:52 am Post subject: Antenna Wire |
You will want a good crimp tool for all your electrical work. Get one with replaceable dies that will satisfy your many tasks.
I have a Paladin Classic 1302 crimp tool. For coax, I use the 2034 die. The 2035 die is a good die for crimping most of the small (10-22AWG) electrical connectors in the RV-10.
http://www.action-electronics.com/crimpers.htm
William
http://nerv10.com/wcurtis/
ricksked(at)embarqmail.co Guest
Posted: Tue Jul 15, 2008 6:37 am Post subject: Antenna Wire |
I got crimper from Stein and it works great...Coax connections were the easiest of all the crimps. I picked up a 3 blade rotary coax stripper on ebay that does a perfect job removing the insulation.
Rick Sked
40185
Posted: Tue Jul 15, 2008 1:49 pm Post subject: Antenna Wire |
I would certainly get the tool from Stein. You can get one crimper and two dies, one for the ring terminals and one for the coax. That is much better than getting cables already made, because routing a coax cable is much easier than routing a connector, especially through a conduit or snap bushing that is already fairly full. I have done that before and it is a nightmare. It would be cheaper to get the tool and connectors than to get the cables already made, probably, and it will save you a lot of hastle.
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
On Jul 15, 2008, at 8:03 AM, jason.kreidler(at)regalbeloit.com (jason.kreidler(at)regalbeloit.com) wrote:
Sheboygan Falls, WI
#40617 Finishing
| [b]
