Deems Davis
Posted: Fri Jul 04, 2008 5:56 am Post subject: Control Approach - Rudder pedals |
Earlier this week Paul Grimstad posted a message along with a picture of
his newly developed rudder pedals for the RV-10. The following day a
package arrived at the Davis house hold with production model #1. I saw
Pauls prototype over a year ago at a dinner at his Home in Oregon, and
persuaded him, that if he ever decided to produce them for others to
make me his 1st customer. True to his word Paul called and said 'they're
ready' and my check was in the mail. I finished with the installation
yesterday, you can read about it on my website.
http://deemsrv10.com/Home-77.htm
http://deemsrv10.com/Home-78.htm
I've created a picture album as well:
http://deemsrv10.com/album/Control%20Approach%20Rudder-Brake%20Pedals/index.html
Paul has done an EXCEPTIONAL job developing these, all of the pieces are
CAD designed, The metal parts are all precision machined, or laser cut.
the welding is done in jigs, the fit is perfect! This is the last
modification I plan on making (I promise !) I've patiently waited while
Paul's perfected these, but it's been well worth it.
Deems Davis # 406
'Its all done....Its just not put together'
PS. I've got no financial interest in this, I do count myself as a
friend of Pauls' and want this to be a sucess for him.
speckter(at)comcast.net Guest
Posted: Fri Jul 04, 2008 7:33 am Post subject: Control Approach - Rudder pedals |
Us big guys with trifocals just hate working under the panel like that.
Looks great, wish they would have been available when I did mine, but the
discomfort of redoing the rudders convinces me to leave well enough alone
and just go flying.
Gary
Deems Davis
Posted: Fri Jul 04, 2008 9:09 am Post subject: Control Approach - Rudder pedals |
I have a pair of glasses that are total close range. Works great until you
try and step off the wing and walk across the hanger. Might as well be
drunk.
Gary
40274 Flying
AV8ORJWC
Posted: Fri Jul 04, 2008 2:37 pm Post subject: Control Approach - Rudder pedals |
Your pictures look like the Matco's bolted right up. That would mean my
upgrade to Groves should fit fine. It sure looks cleaner. How much time
do you have into the retro? Two days after receipt of pedals, Wow and
in that Phoenix heat to boot.
Here is to safer flying without the rats nest of tubing and cylinders
hanging into the cabin. Too bad the factory doesn't get behind selling
the retro.
John
Deems Davis
Posted: Sat Jul 05, 2008 4:56 pm Post subject: Control Approach - Rudder pedals |
OK, I'll bite, what is it about the Grove brake cyls that make them an
upgrade? (I can't stand knowing there's a mod/upgrade I haven't considered )
The whole shebang took 12 hours. of that 1 1/2 was removing center
console and associated electronics.
It took another 1 1/2 hours to remove the old rudder pedals.
fitting the tunnel cover and cutting the slots (took me 3 times) and re
routing the Scat tubes took 3 hours.
Installing the new pedal assembly and connecting the rudder cables took
2 hours.
Remounting the brake cylinders took 4 hours
I figure this should be about worst case:
a. I'm slow
b. It was/is 110-112 degrees
c. my panel is 2 inches lower than stock further restricting access
d. I'm fat (but working on it)
e. I'm old (working on it as well but haven't made much progress)
If these were being installed during the build vs a retrofit, without
the instrument panel or upper fwd fuse in place, it should take no more
than 2-3 hours total. Given that they come fully assembled, that would
actually be a time savings over the stock pedals.
Deems Davis # 406
John Cox wrote:
AV8ORJWC
Posted: Sat Jul 05, 2008 6:08 pm Post subject: Control Approach - Rudder pedals |
The Groves had/have improved machining, HD O-rings and could sustain
higher pressure creation. They might have had a slightly larger
capacity. They were black anodized - not gold (Kool). They remain the
choice of Lancair builders who are upgrading performance(but that is not
enough after Matco's are installed). They have a Helper spring on the
outside of the shaft to assist to a Return to No Brake mode.
I have suggested to Paul that a 1/8 Elbow fitting added at the firewall
would assist Retro Builders to redirect Scat tubing away from his
fulcrum arms. He is considering that.
The DHI lines are a Big Deal. There have been lots of upgrades from
Nylaflow lines.
Lancairs come across the fence 50% faster than a VANS (in flare) and
more than 60% heavier (with WOW). That all works into the math
calculation for rotor mass, pad surface area and pressure of H-5606.
When the brakes get mushy and the field is short, the operators look to
improved performance. Lancairs need hard surface and 4,000+. Tim
wanted Dirt or Grass and 2500 feet. When there is a cliff, trees or a
dogleg, the improved braking becomes a bigger deal than just HP.
Tim went with dual calipers and 75% more rotor mass (I think 0.435"
rather than 0.250"). I have a firm back east, that grooves my rotors on
the BMWs. The groove is set to minimum caliper width so it is also an
indicator line for rotor replacement. It allows outgassing from the
heated pads to dissipate and return to conversion of energy mass into
friction and heat. It is the heat dissipation that is the science.
Hoyt Fleming put NACAs ducts on the side of his wheel pants and cooling
ducts internally like on NASCAR vehicles to direct the flow over the
rotors. I told John Jessen it is the heat buildup that caused NASCAR to
go to a cool down lap to avoid warping of the rotors from uneven
cooling. Seems the pads were retaining heat and contributing to rotor
warp. It is much like the respect pilots should have for turbo oil and
a cooling cycle before shutdown. Short taxis should be avoided on hot
days. Land long, taxi back, save rotors and $$$.
John
jcumins(at)jcis.net Guest
Posted: Mon Jul 07, 2008 7:49 am Post subject: Control Approach - Rudder pedals |
Looks like I want a set when I get to that part in the build process. I am
only on page 6-3 of the Vertical Stab but loving every minute of it.
John G. Cumins
40864 Emp build
Deems Davis
Posted: Mon Jul 07, 2008 8:26 am Post subject: Control Approach - Rudder pedals |
Install them initially during your build and it will be a breeze. You'll
love them.
Deems
John G. Cumins
40864 Emp build
Bldgrv10450(at)comcast.ne Guest
Posted: Mon Jul 07, 2008 12:07 pm Post subject: Control Approach - Rudder pedals |
John
Thanks for your approval. I am working on ordering materials for a quanity
build now.
I'm with you on loving every minute of building this airplane, all be it one
handed for the time being.
Paul Grimstad
Tnelson
Posted: Tue Jul 15, 2008 3:47 pm Post subject: Re: Control Approach - Rudder pedals |
Paul,
I am interested in the pedals. Could you provide contact info?
My email is tnlnelson(at)comcast.net
_________________ Todd
RV-10
Emp Complete
Slow build wings... |
