asarangan(at)gmail.com Guest
Posted: Fri Jul 11, 2008 8:26 am Post subject: Removing PVA release agent |
I am not sure what the PVA release agent looks like. My cockpit module
has very thick glossy stuff all over the the underside. It looks more
like excessive epoxy. But I am concerned if this might be the PVA
release agent. If so, it's not going to come off with any amount of
washing in soap and water. Some heavy duty sanding would be in order.
Does anyone have some advice on this?
Thanks!
Posted: Fri Jul 11, 2008 9:59 am Post subject: Removing PVA release agent |
Andrew, My advice is to take it seriously and wash very thoroughly and then
wash again. I think the release agent is just a water soluble thing which
will be there in small quantities and not necessarily visible. My reason for
saying this is that release agents contain a chemical known to be good at
enhancing or provoking the production of allergic reactions. I was a bit
casual about the washing as it looked reasonably clean, but I developed a
serious allergy, giving asthma and most unpleasant lung and nose symptoms
whilst dry sanding the wing and fuselage smooth surfaces to prepare for gel
coating, which like paint needs a matt surface without any trace of shine,
(and it is potentially lethal, since repeated exposure once sensitive can
give anaphylactic reactions) I am not sensitive to ordinary fibreglass or
filler dust but only the dust from those moulded surfaces which have been
coated with releasing agent.
Regards, David Joyce, G-XSDJ
Posted: Fri Jul 11, 2008 10:36 am Post subject: Removing PVA release agent |
Hi Andrew
"I am not sure what the PVA release agent looks like. My cockpit module
| Quote: | has very thick glossy stuff all over the the underside. It looks more
Does anyone have some advice on this?"
Use the hottest water you can tolerate, we used just plain green Palmolive
dish washing soap (great hand cleaner)and scotchbright pad. Once water
sheets rather than beads up you can switch to plain water and
scotchbright. You need to rinse off all the soap which is no trivial job.
Just keep rinsing, you could use green scouring pads (for sinks) as well.
When you think you got it all off, use some hot water "when" you see
bubbles forming, keep at it.
Ron Parigoris
loboloda(at)execulink.com Guest
Posted: Fri Jul 11, 2008 1:05 pm Post subject: Removing PVA release agent |
Andrew,
My spars were coated with something, I presume it was a release
agent, nothing would stick to it.
I tried detergent and water, and tri sodium phospate, neither of
which did much.
Sanding just worked the contaminant into the spars.
Eventually I tried Comet kitchen cleaner, and the foaming/scouring
action plus lots of water
cleaned them well.
After this a friend from the auto industry gave me a bottle of
"Polycracker" prep wash.
Sprayed on wiped off and rinsed, the stuff was brilliant at removing
whatever was on the spars.
Dave
On 11-Jul-08, at 12:23 PM, Andrew Sarangan wrote:
<asarangan(at)gmail.com>
Thanks!
Posted: Fri Jul 11, 2008 1:29 pm Post subject: Removing PVA release agent |
Now you are getting me worried. I did not wash my XS wing spar before
applying the reinforcement plies, nor did the manual mention it. I
simply scuff sanded it. But I did not notice any adhesion problems.
Anyone else notice this?
On Fri, Jul 11, 2008 at 5:06 PM, david miller <loboloda(at)execulink.com> wrote:
Andrew,
My spars were coated with something, I presume it was a release agent,
I tried detergent and water, and tri sodium phospate, neither of which did
much.
Eventually I tried Comet kitchen cleaner, and the foaming/scouring action
plus lots of water
cleaned them well.
After this a friend from the auto industry gave me a bottle of "Polycracker"
prep wash.
Dave
> Thanks!
Posted: Fri Jul 11, 2008 2:35 pm Post subject: Removing PVA release agent |
Andrew
PVA release, (poly vinyl alcohol) is water soluble. It will be like a
film and tend to peel off. Wet it and it will soften and feel greasy/sticky.
I am not aware that the factory used it, too much trouble, it is slow to
dry when applied.
Graham
craigb(at)onthenet.com.au Guest
Posted: Fri Jul 11, 2008 2:57 pm Post subject: Removing PVA release agent |
Having used PVA for other glassing work, I havn't noticed any sign of it
on my kit.
craig
keithhickling(at)clear.ne Guest
Posted: Fri Jul 11, 2008 10:56 pm Post subject: Removing PVA release agent |
Andrew,
Andy told me that the PVA release agent is only on the smoothe moulded
surfaces, I think just on those with white filler on the surface - ie
fuselage, wing skins on XS etc. That's all the manual says to wash. I think
what you are seeing on the underside of the cockpit module
is excess epoxy as you suggest. Mine certainly had a lot of epoxy ridges and
lumps, which the manual suggests sanding off to get a reasonably even
surface for bonding. I presume these are from the vacuum bags.
I don't know about the wing spars - like you, I didn't wash them before the
reinforcing tapes, just scuff sanded, and the bonding seemed fine. I
stressed the spar bracket quite a bit getting the spars separated, and it
showed absolutely so inclination to debond.
Keith Hickling,
New Zealand.
Posted: Sat Jul 12, 2008 5:34 am Post subject: Removing PVA release agent |
Andrew,
My kit had foam wings.
You would very quickly notice if there was a problem with adhesion,
voids would be
visible, and it would be possible to lift the edge of the lay up,
don't ask me how I know.
Dave
On 11-Jul-08, at 5:26 PM, Andrew Sarangan wrote:
> Andrew,
> agent,
> which did
> much.
> action
> plus lots of water
> cleaned them well.
> "Polycracker"
> prep wash.
> Dave
>> module
>> more
>> order.
>> Thanks!
Posted: Sat Jul 19, 2008 10:08 am Post subject: Removing PVA release agent |
Ron
I used Palmolive dish soap and hot water. Made me sweat like a pig in
the 90-deg weather:-) I could only see small shreds of transparent
plastic wrap stuck to various surfaces. I am assuming this is the PVA
agent that has dried to form a thin film. I can peel off small chunks,
but I can't tell how much of the entire surface is covered with this
film. Most importantly, I tried soaking one of these pieces in hot
water and soap and it showed no tendency to dissolve even after an
hour. So obviously I am looking at the wrong stuff, or this is a lot
harder to remove than I had assumed.
Any thoughts?
On Fri, Jul 11, 2008 at 2:33 PM, <rparigor(at)suffolk.lib.ny.us> wrote:
Hi Andrew
Ron Parigoris
Posted: Sat Jul 19, 2008 1:42 pm Post subject: Removing PVA release agent |
Hi Andrew
"I could only see small shreds of transparent
| Quote: | plastic wrap stuck to various surfaces."
I am not sure of the exact designation of the release compound europa
uses, but it is in fact water soluble. Using scotch bright with Palmolive
takes it off OK. What you are describing does not sound like a release
agent. My kit was covered with tan packaging tape. Boy what a pain to get
off. It was definite not 3M 375 tape (my favorite packaging tape used
extensive in model building), but most likely some cheap stuff that got
stuck better than many of my layups! I am wondering if what you see is
very thin clear packaging tape?? Or shrink wrap pulled very tight on
remains of packaging tape?
www.mcmaster.com search:
Ultra-Sharp Razor blades
Buy a hundred Ultra-Sharp Carbon Steel Blades. Try some mineral spirits
and razor blades (and finger nails), it may be tape?? Can also try some
Isopropyl Alcohol. See if you can disolve with other than watere. Use
scotch-bright with a solvent that seems to work. Be very careful with
acetone and blue foam.
Shaving with very sharp razor blade and solvent sounds like a good plan
without seeing first hand??
Curious what your resolve will be.
Ron P.
Posted: Sat Jul 19, 2008 5:04 pm Post subject: Removing PVA release agent |
Here is a link to some photos. It is in corners and crevices, so I
doubt it is packing tape. It does not dissolve in water at all. I
waited several hours. It really looks like cling wrap, or some type
of peel ply, but no one has mentioned its existence in the moldings.
It tears easily and only comes off in small bits, so it is hard to
guess how much of the surface is covered by this stuff. I will try
your suggestions on using a sharp blade and IPA. Let me know if you
see anything in the photos.
http://www.sarangan.org/aviation/europa/fuse/ch11.html
On Sat, Jul 19, 2008 at 5:39 PM, <rparigor(at)suffolk.lib.ny.us> wrote:
Hi Andrew
Ron P.
Posted: Sat Jul 19, 2008 5:14 pm Post subject: Removing PVA release agent |
Andrew,
I think what you are describing is plastic film remaining from the moulding
process (? part of vacuum bagging process). As I mentioned, Andy told me
there is no release agent on the non-moulded surfaces - ie on the underside
of the cockpit module. All I found was excess epoxy ridges and small pieces
of plastic film that was adherent in parts.
If that's what it is, and you are talking about the underside of the CM that
bonds to the fuselage, by the time you have sanded the bonding surfaces to
remove the epoxy ridges, leaving a fairly flat surface, you should find that
virtually all the plastic remnants are removed.
Keith Hickling.
Posted: Sat Jul 19, 2008 5:48 pm Post subject: Removing PVA release agent |
FWIW some of my mouldings had a plastic film simmilar to what andrew
described, but mine
was orange in colour and so easy to spot, and embedded in the resin in a few
spots, normally around complex
corners etc, i just sanded the offending bits out as i went, as you suggest
keith i believe it is a part of the
bagging process and small pieces are getting trapped in the resin
craig
Posted: Sun Jul 20, 2008 10:34 am Post subject: Removing PVA release agent |
Hi Andrew
"Here is a link to some photos. It is in corners and crevices, so I
| Quote: | doubt it is packing tape."
OK I see what you are talking about. My plane had areas too like yours. I
think it is probably left over remnants of vacuum bag. Razor blade and a
few different tipped Exactos should rid you plane of most of it. Any areas
to be bonded you could take your time and razor out most and sand off the
rest. If it isn't going to be bonded to, don't kill yourself.
Ron P.
