Posted: Tue Jul 22, 2008 8:17 am Post subject: [Probable Spam] Re: Altimeters |
Alberto,
The barometrically adjustable sensitive altimeter is a better selection
as the encoder weighs very little.
Rather than have one component combined taking down both in a
malfunction, the digital face is
not be a very effective way to convey altitude as changes. Doubt a
standard repair shop
would be interested in fixing the electronic combined altimeter/encoder.
Being able to set barometric and visualize the altitude in flight is
important.
http://www.macsmachine.com/images/completion/full/panelatcruise.gif
Only in an Engine Information System or glass instrument set does the
combining of sensor outputs become economical and
useful, just my personal perspective of course.
Iberplanes IGL wrote:
| Quote: | Hello,
What about this one?
http://www.aircraftspruce.com/catalog/inpages/tlaltimeter.php
Altimeter TL-3524 is an altimeter with encoder in one. With the
Altimeter, not only you can save weight by having two instruments in
one but in addition it is also one of the first encoders that transmit
the code immediately after the turn-on. In your Altimeter, you can
easily set the height that is to be kept - the instrument will then
inform you whether you are above or bellow this set height, the MDA,
approach.
The instrument also informs you on reaching the transition altitude,
the height with lack of oxygen etc. Using a PC and the program that is
a part of the delivery, the Altimeter also enables you any time to go
through the history of measured values.Size: 2-1/4" Not FAA approved.
For homebuilt/experimental only.
Alberto Martin
www.iberplanes.es <http://www.iberplanes.es>
Igualada - Barcelona - Spain
Iberplanes
Joined: 10 Dec 2007 Posts: 174 Location: Igualada - Barcelona - Spain
Posted: Tue Jul 22, 2008 10:23 am Post subject: [Probable Spam] Re: Altimeters |
Hello Larry,
Ok, nice tip you gave me. Soon I´ll have to take a decision on avionics. Last Sunday while I was flying our P96 the Dynon sent a nice message something like "Max temperature Reached" and then it shut down. It was really hot, 37C degrees, I tought the engine was having trouble but the 912ULS was ok, both oil and water on the green arc. The problem was the Dynon......
For my XL I like the MGL Oddisey, but now I´m reconsidering my ideas... AMD has a nice cockpit, the "six pack" and Dynon for engine.
Well, thanks for the tip.
Alberto Martin
www.iberplanes.es
Zodiac 601 XL Builder
Serial: 6-7011
Tail Kit: Finished
Wings: Not Started
Fuselage: Ordered
Engine: Jabiru 3300
_________________ Alberto Martin
601 XL - Jabiru 3300
Igualada - Barcelona - Spain |
Gig Giacona
Posted: Tue Jul 22, 2008 10:47 am Post subject: Re: [Probable Spam] Re: Altimeters |
Add a large computer cooling fan behind the panel. You won't have that problem again. The max operating temp is 50C. If it is getting that hot behind your panel then you are probably going to start cooking some other things that aren't as smart as the Dynon.
Another plus to the fan is that if you vent it right it will double as a defogger for the canopy.
| Iberplanes wrote: | Hello Larry,
Ok, nice tip you gave me. Soon I�ll have to take a decision on avionics. Last Sunday while I was flying our� P96 the Dynon sent a nice message something like "Max temperature Reached" and then it shut down. It was really hot, 37C degrees, I tought the engine was having trouble but the 912ULS was ok, both oil and water on the green arc. The problem was the Dynon......
For my XL I like the MGL Oddisey, but now I�m reconsidering my ideas... AMD has a nice cockpit, the "six pack" and Dynon for engine.
Alberto Martin
601XL Under Construction
amyvega2005(at)earthlink. Guest
Posted: Tue Jul 22, 2008 12:35 pm Post subject: [Probable Spam] Re: Altimeters |
50 C is over 122 degrees! I run my Dynons at over 100 F all the time. I would call Dynon and see if they want to check the part out. It sounds suspect that a product in the cabin coud not take hot temps at 37c, thats not out of its element.
Juan
psm(at)att.net Guest
Posted: Tue Jul 22, 2008 1:53 pm Post subject: [Probable Spam] Re: Altimeters |
Hi Juan,
I agree with you that 50 degrees Celsius is very hot. If the cabin
temperature was 37 C then it is not hard to believe it was over 50 C
inside the Dynon box. I have never worked on electronics designed to
work over 50 degrees C. The actual components are only rated to a
maximum of 70 C unless you select military grade components which
cost a lot more than the commercial ones. The difference between the
50 degree specification and the 70 degree one for the chips is the
designer's margin. This is similar to the extra strength a
mechanical or aeronautical engineer builds into his design.
Perhaps a fan to keep the back of the instrument panel cool is a good
idea. Even some vents in the top of the area in front of the
instrument panel would be helpful from convection cooling.
Paul
XL getting close (recovering electrical engineer)
At 01:31 PM 7/22/2008, you wrote:
| Quote: | 50 C is over 122 degrees! I run my Dynons at over 100 F all the
Juan
Posted: Tue Jul 22, 2008 4:37 pm Post subject: [Probable Spam] Re: Altimeters |
Bill,
If you're going for the installation of an encoder and transponder,
which I'd recommend the sensitive for sure. Hitting pattern altitude
and getting accurate feedback on altitude for maintaining separation of
easterly and westerly headed aircraft is very important. If you've a
class C airport to land or take off from or traverse near you, it's
especially important that you have the best altimeter and the cost is
much less a consideration than complying with the controllers
directives. They seem to be writing violations as often as opportunity
permits these days. The nice thing, sensitive altimeters are not prone
to malfunction as other types, so I'd go with the barometric-adjustable,
sensitive type.
If I were flying a much slower climbing ultra-light aircraft, the
non-sensitive altimeter would be just the ticket, but not for a 601.
Bill Naumuk wrote:
| Quote: | Bryan-
This is probably the best description of the difference posted. I
assume (And this is a big assumption) that the readings within the
sweep of the one hand are as accurate as those of the "Sensitive" alts.
If my assumption is correct, since this is intended to be a backup
instrument to the D-100 I'll be OK. I'm a relative flat-lander and
have only busted 6-7K feet in a rental in Colorado.
Everyone, do your best to dissuade me- open season.
Doesn't matter, I have to work on the house anyway. Check this out:
Contracted a guy to put siding on the front of the house. Gave him
an idea of what needed to be done and a rough estimate of the time it
would take. He left, then half hour later came back and said he
couldn't work under a homeowner's time estimate and no quoted. This is
after the materials had already been ordered.
I estimated the worst portion of the job would take 2 hrs. After
he no-quoted I was so pissed I went out and did it myself in 22 minutes.
And people wonder why it's taken me so long to complete my project!!!!
Iberplanes
Posted: Tue Jul 22, 2008 10:18 pm Post subject: [Probable Spam] Re: Altimeters |
Please Juan, if you have an email, just send it to me so I can contact them
Gig Giacona
Posted: Wed Jul 23, 2008 5:42 am Post subject: Re: [Probable Spam] Re: Altimeters |
http://dynonavionics.com/docs/company_contact.html
There's the link to their contact page with phone number, e-mail and snail mail addresses. There is also a link on that page for their support forum which has lots of info and they do respond quickly.
If you don't get a quick response please keep in mind that this is the week before Oshkosh and if they are like other homebuilt vendors they have most if not all of their staff getting ready for that.
| Iberplanes wrote: | | Please Juan, if you have an email, just send it to me so I can contact them |
Posted: Wed Jul 23, 2008 6:19 am Post subject: [Probable Spam] Re: Altimeters |
i understand your position but diagree with it. The instruments in the cabin should not at that way. I fly pretty much every day in 601. IN 100 deg weather. the dynons don't do that. MOst planes I fly down here have galss panels and they are tied down outside. they dont do that. Good Idea for the fan perhaps, but its cheaper to call the manufacturer and find out if that is normal course of businesws for the equipment. Option two is get better ventilation and shade in the cabin while being stored.
Juan
Gig Giacona
Posted: Wed Jul 23, 2008 6:56 am Post subject: Re: [Probable Spam] Re: Altimeters |
I tried to save you the call. The specs on the Dynon show a max operating temp of 50 C. That is from the manual which is available at their website. I would certainly hope that Dynon included auto off in the system. The alternative is for the thing to burn itself up.
| amyvega2005(at)earthlink. wrote: | i understand your position but diagree with it. The instruments in the cabin should not at that way. I fly pretty much every day in 601. IN 100 deg weather. the dynons don't do that. MOst planes I fly down here have galss panels and they are tied down outside. they dont do that. Good Idea for the fan perhaps, but its cheaper to call the manufacturer and find out if that is normal course of businesws for the equipment. Option two is get better ventilation and shade in the cabin while being stored.
Juan
Posted: Wed Jul 23, 2008 7:27 pm Post subject: [Probable Spam] Re: Altimeters |
Gig,
Agreed. Hey dude, I checked out your website and the progress of your project. Nice PLane! I like your IFR template for the COckpit Panel. I actually miss building now. It was fun to have something to do after putting the kid and wife to bed. Hope you are enjoying the project.
Cheers, Juan
