		peteohms
				 Posted: Fri Jul 25, 2008 3:19 pm    Post subject: Changing Crush Gasket |
				I'm about to do my first oil change on my 912ul.  Instructions call for changing the crush gasket.  Is there a generic gasket available at local auto parts stores?
 Pete
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		jack.kuehn(at)gmail.com Guest
				 Posted: Fri Jul 25, 2008 4:13 pm    Post subject: Changing Crush Gasket |
				I don't even remove the plug any more.  I just remove the whole can from the airplane and take the top off, dump out the old oil and clean everything up as clean as new.  Depends on your installation though.  It's actually easier for me to remove the entire sump than to stand on my head and remove the darn plug.  The can needs a good cleaning anyway.
 Jack
 On Fri, Jul 25, 2008 at 5:19 PM, peteohms <apeterchristensen(at)sbcglobal.net (apeterchristensen(at)sbcglobal.net)> wrote:
		Roger Lee
				 Posted: Fri Jul 25, 2008 5:53 pm    Post subject: Re: Changing Crush Gasket |
				Hi Pete,
 Your right that Rotax says to replace the crush washer every time. What I'm about to say is not politically correct, but most people don't replace it every time. Unless it leaks it is still good. Just don't over torque it when you put it back together and smash it. You can use it 3-4 times before replacing the crush washer. Like I said this is against the Rotax manual, but I have never seen one leak that has just been used once.
 If you want to replace it now you could probably pick up a crush washer at a motorcycle shop or order one from Lockwood or California Power Systems.
  _________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Home 520-574-1080  TRY HOME FIRST
Cell 520-349-7056 |
		hgmckay
				 Posted: Fri Jul 25, 2008 6:50 pm    Post subject: Changing Crush Gasket |
				Pete:
 Not to my knowledge. The copper crush washers recommended by Rotax should
 always be used. Your life is at stake. The Rotax Engines DO NOT LIKE LOSS OF
 OIL. Use the recommended crush gasket!! You can get them from Lockwood
 Aviation.
 Hugh
		pwmac(at)sisna.com Guest
				 Posted: Sat Jul 26, 2008 4:42 am    Post subject: Changing Crush Gasket |
				Now this item is a concern. Add a mechanical gadget that has failure modes out of your control does present life threatening issues. Not very likely, for sure, however I would take a torqued bolt as the safest way to go even with out the crush washer.
  Paul
  At 09:10 PM 7/25/2008, you wrote:
  [quote]--> RotaxEngines-List message posted by: "Craig Payne" <craig(at)craigandjean.com>
  You could install one of the quick-drain valves from Saf-air or Curtis and
  be done with it. Aircraft Spruce and California Power Systems both carry
  them:
   http://www.rotaxparts.net/Scripts/prodView.asp?idproduct=1306
   http://www.aircraftspruce.com/catalog/eppages/safairsump.php
   http://www.aircraftspruce.com/catalog/appages/curtisquickdv.php (scroll to
  bottom)
  -- Craig[b]
				Boy what a gross exaggeration. O\If the bolt is torqued it just wont come out - period. Every car manufacturer says the same thing as Rotax. We have been ignoring that forever. What happens is one gets some weeping. No big deal. Don't worry about it.
  Paul
  At 08:51 PM 7/25/2008, you wrote:
  [quote]--> RotaxEngines-List message posted by: "Hugh" <hgmckay(at)bellsouth.net>
  Pete:
  Aviation.
  Hugh[b]
		Roger Lee
				 Posted: Sat Jul 26, 2008 7:30 am    Post subject: Re: Changing Crush Gasket |
				Hi Jack,
 Just a note.
 If you are flying an ELSA then the quick drain valve is certainly not a bad way to go. If you are SLSA you need an approval from the MFG. I don't believe Rotax sanctions the quick drain valve. We have tried to get them in use for the Flight Design CT, but the FD won't sign off on it because Rotax wouldn't. If you are registered ELSA you can do anything you want. That being said Rotax has it's own warranty items they like or dislike.
 This is one of those discussions that you have to personally decide.
 The book says new crush washer. The experience in the field says it is ok to reuse it a few times. The majority don't change out the crush washer and don't have any problems.
 Up to you now to decide.
Tucson, Az.
Cell 520-349-7056 |
		peter.rees01(at)tiscali.c Guest
				 Posted: Sat Jul 26, 2008 10:56 am    Post subject: Changing Crush Gasket |
				Why not just buy a new one? At UK fuel prices, if  you fun on Mogas, you're going to burn about 900GBP of fuel per oil change  (based on 15l/h, 50hr service and 1.20GBP per litre (ocuh!)) - I think that the  washers are about 1GBP or less. Same goes with the oil filter - why try and find  an alternative to the Rotax part - its only about 5GBP or so - is your engine /  life really worth risking to save 6GBP???
  Peter
		peteohms
				 Posted: Sat Jul 26, 2008 1:21 pm    Post subject: Changing Crush Gasket |
				Jack,
  That's exactly what I did.  I just removed the whole can and I  found out that there is NO drain plug on my Kitfox III.  So that's  what I had to do.  Next time I think I'll just suck out all of the oil  from the reservoir through the pickup line and call it good.  I'll probably  shorten the oil change time to make up for not getting all the oil.
  Thanks to all who responded!
  Pete
  Hell Paso, TX
  Kitfox III SN 1000, 912ul
  [quote]   ---
  _________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
		thilo.kind(at)gmx.net Guest
				 Posted: Sat Jul 26, 2008 2:26 pm    Post subject: Changing Crush Gasket |
				Hi Paul,
 that statement is not entirely correct. A bolt will come out, even, when properly torqued – especially at airplanes due to the vibrations. Torquing only makes sure, that the bolt is loaded with the proper tension required for the connection. To avoid loosening of a bolt, several methods are available such as safety wiring, stop nuts, Locktite, etc. The oil release bolt should be safety wired – otherwise the bolt will come loose eventually. Not a good in-flight experience.
 The function of the crush washer is to seal the opening. Threats / bolts provide no seals, so liquids – in this case oil – will leak. The crush washer is made from copper. The soft copper metal is pressed by the bolt to the engine house. Due to the pressure the surface of the copper washer deforms to comply with the surface of the bolt and the engine housing, respectively, and hence acts as a seal. Since the surface is deformed after one use, a new washer should be used whenever the bolt was removed.
 Best regards
 Thilo Kind
 Zodiac CH 601 HDS with Rotax 912 flying
 RV 8A under construction
 From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of paul wilson
  Sent: Samstag, 26. Juli 2008 14:32
  To: rotaxengines-list(at)matronics.com
  Subject: RE: RotaxEngines-List: Changing Crush Gasket
  Paul
  Pete:
  Aviation.
  Hugh   	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?RotaxEngines-List  | 	  0123456789
		Roger Lee
				 Posted: Sat Jul 26, 2008 3:15 pm    Post subject: Re: Changing Crush Gasket |
				I knew this was going to be a hot topic.
 The drain screw gets 18.5 ft/lbs or 222in/lbs of torque.
 Whether you use the old one or a new one it needs to be safety wired.
 We could discuss topics like these for days and it will eventually come down to just you to determine "Do I like Ford's or do I like Chevy's.
 You can't go wrong if you follow the book.
Tucson, Az.
Cell 520-349-7056 |
				 Posted: Sat Jul 26, 2008 6:24 pm    Post subject: Changing Crush Gasket |
				You are repeating what all manufacturers say. In the real world its no big deal. Our race trucks seldom get a new washer and when we do its never copper its dead soft aluminum.  Never had a leak an never heard of  the bolt falling out. Been doing this to many years and so we know its no sweat. Bolts fall out at the quick lube place because they are installed finger tight.
  If you think the vibration is bad in an airplane check out the vibration on an off road race truck. We lockwire on a lot of fasteners but the drain bolt is just torqued.
  Paul
  At 04:24 PM 7/26/2008, you wrote:
  [quote]Hi Paul,
  Best regards
  Thilo Kind
  From: owner-rotaxengines-list-server(at)matronics.com [ mailto:owner-rotaxengines-list-server(at)matronics.com (owner-rotaxengines-list-server(at)matronics.com)] On Behalf Of paul wilson
  Subject: RE: Changing Crush Gasket
  Paul
  Pete:
  Aviation.
  Hugh
				 Posted: Sat Jul 26, 2008 10:54 pm    Post subject: Changing Crush Gasket |
				Hi Paul,
 on a car it’s not a big deal, because the vibrations are different (not uniform) due to always changing RPM setting and induced non-uniform vibrations from the un-even road. This reduces the tendency for bolts to loosen. Airplanes run at almost constant RPM settings, which results in a very uniform vibration. Fasteners will definitely come loose and therefore should be properly secured.
 There are two reasons for the replacement of the crush washer: the deformation of the surface after first use and work hardening of the copper as well as many aluminium alloys after exposure to vibrations. This can result is breaking of the crush washer. That’s why good practice dictates to replace the crush washer every time.
 I admit, that in a car both the safety-wiring of the bolt and the replacement of the crush washer could be overkill – worst that can happen to you is that the car stops at the shoulder of the raod. In an airplane, this is an entirely different story… That’s why all the manufacturers as well as the FAA recommend / insist on those measures. It is definetly not a money making deal of manufacturers – they are not make a lot of money on a piece of safety wire and a copper washer….
 Thilo Kind
  Sent: Sonntag, 27. Juli 2008 03:31
  Paul
 Hi Paul,
  Best regards
  Thilo Kind
  Paul
  Pete:
  Aviation.
  Hugh
    012345678901234
				 Posted: Sun Jul 27, 2008 9:52 am    Post subject: Changing Crush Gasket |
				Paul
 Thilo is right, and there's another good reason for using new crush
 washers, this is not a drain plug and solid, it's a banjo bolt. Over
 torque it and it will stretch or break, also the barrel.will deform and
 no longer be flat.
 The crush washers are oval section so they easily deform when new to
 form a seal. It takes too much torque to deform them when they are
 already crushed. Not wise to try and vent a well designed wheel
 Graham
 Thilo Kind wrote:
  Hi Paul,
  Thilo Kind
  *From:* owner-rotaxengines-list-server(at)matronics.com
  [mailto:owner-rotaxengines-list-server(at)matronics.com] *On Behalf Of
  *paul wilson
  *Sent:* Sonntag, 27. Juli 2008 03:31
  *To:* rotaxengines-list(at)matronics.com
  *Subject:* RE: Changing Crush Gasket
  Paul
		lucien
  Joined: 03 Jun 2007 Posts: 721 Location: santa fe, NM
				 Posted: Sun Jul 27, 2008 11:45 am    Post subject: Re: Changing Crush Gasket |
				My .02,
 If I have a crush washer on me when I do my oil change, I replace it. I'll reuse old ones, tho. Copper will harden a bit once it's crushed so a used washer isn't as pliable as it was (besides already being flat as a pancake).
 But at the specified torque (195 in/lbs I believe?, can't remember off top of my head), the drain plug usually still gets a good seal and doesn't leak.
 And yes, I wouldn't even consider not safety-wiring the drain plug after installation new crush washer or no....... yeah it's extremely unlikely a properly torqued plug could come out but the wire reduces that probability to as close to zero as you can reasonably get for just a little bit of effort
 LS
  _________________ LS
Titan II SS |
				 Posted: Sun Jul 27, 2008 11:49 pm    Post subject: Changing Crush Gasket |
				Hi! Lucien
 Just to explore the topic further ...whilst I would never advocate not
 changing the crush washer.... if it is a solid copper ring and you have
 forgotten to have a replacement on hand then it would be best to refit
 it after you have annealed it .....heated it cherry red and quenching it
 in oil.(the opposite to hardening steel!) That will restore it's
 flexibility to reuse. However many crush washers are made of light gauge
 copper and are rolled and so folded to allow the crush to take place
 (like on ignition plugs) these would not be suitable for annealing.  I
 have a 1936 Velocette OHC 350cc motor cycle and it's head gasket is a
 solid copper ring about 3" diameter which I have never renewed but
 always annealed without ever leaking
 Bob Harrison. Europa G-PTAG 914 Rotax.
		peteohms
				 Posted: Tue Jul 29, 2008 2:38 pm    Post subject: Changing Crush Gasket |
				Jack,
  Do you have to then purge the oil  system?
  Pete
  [quote]   ---
Leander, TX
				 Posted: Tue Jul 29, 2008 5:00 pm    Post subject: Changing Crush Gasket |
				Pete,
 I have not purged exactly as the Rotax video and documentation says you should, but I am going to start doing it.  I didn't really understand the process until I saw the video they posted at the Rotax web site.  Until now I have made sure the oil line to the thermostat and oil cooler and oil pump were full, and removed spark plugs and simply turned the engine a bunch by hand, then with the starter until I get oil pressure on the guage.  Next time I will apply air pressure and check the lifters as recommended.  May be overkill, but it's an expensive engine and deserves the best of care!!  And I would prefer that it not stop running at the wrong moment!
 Jack
 On Tue, Jul 29, 2008 at 3:35 PM, Pete Christensen <apeterchristensen(at)sbcglobal.net (apeterchristensen(at)sbcglobal.net)> wrote:
 [quote]        Jack,
  Pete
  [quote]   ---
