		peteohms
				 Posted: Sun Jul 27, 2008 1:36 pm    Post subject: Rotax oil pickup fitting at bottom of engine on 912 |
				On my Kitfox III there is a fitting at the  bottom of the 912ul engine where the oil return line attaches at 90 degrees and  returns oil to the oil tank.  I need to losen this fitting about 3 to 5  degrees so that the return hose is not kinked.  There appears to be a  copper washer between the fitting and the engine and I am sure if I loosen the  fitting a few degrees that it will leak.  How can I do this without causing  a leak?
  Pete
  Hell Paso, TX
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
		Roger Lee
				 Posted: Sun Jul 27, 2008 8:49 pm    Post subject: Re: Rotax oil pickup fitting at bottom of engine on 912 |
				Hi Pete,
 You can loosen the bottom banjo nut just a little and rotate your hose without losing any oil and if you did lose a little it would be just a drop or two. I believe the torque on that banjo nut is 150 in/lbs.
  _________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Home 520-574-1080  TRY HOME FIRST
Cell 520-349-7056 |
