paulrod36(at)msn.com Guest
Posted: Mon Jul 28, 2008 11:01 am Post subject: Corvair Fuel Lines |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Now that I'm about to start on the plumbing, I'm wondering aobut the capacity of the 1/4" fuel lines supplied by Zenith---- Are they sufficient to feed a Corvair engine at full throttle, or should I move up to 3/8" lines? Any consensus out there?
Paul Rodriguez
601XL/Corvair
Gig Giacona
Posted: Mon Jul 28, 2008 12:09 pm Post subject: Re: Corvair Fuel Lines |
Yes they are.
[quote="paulrod36(at)msn.com"]<xml><xml><endif> Now that I'm about to start on the plumbing, I'm wondering aobut the capacity of the 1/4" fuel lines supplied by Zenith---- Are they sufficient to feed a Corvair engine at full throttle, or should I move up to 3/8" lines? Any consensus out there?
Paul Rodriguez
601XL/Corvair
601XL Under Construction
hills(at)sunflower.com Guest
Posted: Mon Jul 28, 2008 5:07 pm Post subject: Corvair Fuel Lines |
Paul;
When in doubt, up ya go…why take a chance….go 3/8 all the way !!!!
Roger
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of paulrod36(at)msn.com
Sent: Monday, July 28, 2008 1:58 PM
To: zenith-list
Subject: Corvair Fuel Lines
Paul Rodriguez
601XL/Corvair
| Quote: | | http://www.matronics.com/Navigator?Zenith-List | 0123456789
davgray(at)sbcglobal.net Guest
Posted: Mon Jul 28, 2008 5:52 pm Post subject: Corvair Fuel Lines |
Paul
I used the supplied 1/4 inch fuel lines supplied with the 601XL kit from the wing to a center Andair fuel valve then bradied SS AN-6 to the carb. When tested at the carb inlet the fuel line and facet pump delivered approx. 20 gal/hr into an open fuel can. Both facet pumps performed the same.
Gary Ray
601XL
Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Tue Jul 29, 2008 9:16 am Post subject: Corvair Fuel Lines |
Paul
The recommended tubing size for aluminum fuel lines is 3/8". But metal tubes are sold by outside diameter. The rubber tubing supplied by ZAC is sold by inside diameter, so ZAC's tubing is 1/4" i.d., which is about the same i.d. as 3/8" aluminum tubing. The 1/4" ZAC supplied tubing should be just fine.
Terry
At 08:07 PM 7/28/2008 -0500, you wrote:
| Quote: | Paul;
Roger
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com (owner-zenith-list-server(at)matronics.com)] On Behalf Of paulrod36(at)msn.com
To: zenith-list
Paul Rodriguez
601XL/Corvair |
Terry Phillips ZBAGer
ttp44~at~rkymtn.net
Corvallis MT
601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons are done; working on the wings
http://www.mykitlog.com/N47TP/ [quote][b]
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
