AT150 Interrogation Light
Fox5flyer
PostPosted: Tue Jul 29, 2008 4:04 am    Post subject: AT150 Interrogation Light Reply with quote
I have a Narco AT150 transponder in a Kitfox 5 with the antenna on the belly with a 5.5" ground plate. It seems to be working fine according to ATC. Good data and the mode C is accurate. However, the interrogation light is on steady, rather than blinking as the radar sweeps past it. It used to be just fine, but at some point it began to act differently where it would flicker, especially on the ground. Now, if the engine is off and I activate it, the interrogation light comes on for a few seconds, then turns off. I believe that's how it's supposed to act. However, when flying, it seems to come on steady and stay that way with an occasional flicker during flight. As I said, ATC says it's working fine.
Has anyone seen this? Any idea what my problem is? Several times I've removed it, cleaned and lubed the contacts, and replaced it with the same results. Since it's working fine, I'm not to worried about it, but I'd like to get this light working like it's supposed to.
Thanks for any help offered.
Deke
mprather(at)spro.net
PostPosted: Tue Jul 29, 2008 7:27 am    Post subject: AT150 Interrogation Light Reply with quote
Maybe you have something in the airplane generating noise which causes the
transponder to reply - even though it wasn't interrogated by an actual
radar signal. How's the audio in your comm radio? Any new noise? Off
the top of my head, maybe you have a bad spark plug wire, or alternator
diode or something like that. Does your engine have dual ignition
systems? If yes, does the transponder behave the same way on each of them
separately? Can you turn the alternator off and still run the txp from
battery (as a test)? I doubt you have a DME in a Kitfox, but they operate
in the same band as the transponder so might be a source of interference.
As a long shot, possibly your cell phone is setting it off. Did you get a
new phone? Does it misbehave with the phone turned off?
I can't recall if the AT150 has a remote ident button, but maybe the wire
that connects that circuit isn't isolated properly. I think those work by
grounding the wire. Vibration might cause that wire to rub against
ground. In reality, the pin in the shell connector for that function
probably doesn't even have a wire in it, so that's probably not the issue.
Maybe the reply discrimination circuit is messed up in your txp. Possibly
a radio shop has a loaner unit you could swap into the tray. Or maybe
they can test the unit for that functionality.
Matt-
Deke
rjquillin
PostPosted: Tue Jul 29, 2008 8:20 am    Post subject: AT150 Interrogation Light Reply with quote
Matt, Deke,
I was thinking many of the same things, but given ATC was reporting
his unit was 'normal', I discounted them, as I would have thought
they would have complained of excessive replies or ident's making a
mess of their sereens. IIRC, the 150, unlike the 50, does have a
remote ident pin. I'll look in my SM tonight as see if there may be
a some failure to the light circuit only, doesn't seem likely, but...
If the unit is in an area with many ADSB units and/or heavy radar
coverage, it could actually be interrogated at some high rate and the
reply light is working normally. One would expect it to be a bit
quieter on the ground, out of sight of multiple radar sites but
perhaps still seeing ADSB inquires. However, Deke reports a
change. Has anything else changed within the AC that may give a clue?
I agree, a bench check at a radio shop or exchange unit should be
near the top of things to try.
Ron Q.
Matt-
> Deke
sportav8r(at)gmail.com
PostPosted: Tue Jul 29, 2008 1:04 pm    Post subject: AT150 Interrogation Light Reply with quote
My Garmin xponder does that whenever both Pmags are powered up. If I kill one side, it behaves normally again. If I kill the other side, the problem remains. ATC seems to see me okay most of the time while this is going on. Strange, indeed. Makes it hard to see true interrogation hits.
-Bill B
On Tue, Jul 29, 2008 at 12:13 PM, Ron Quillin <rjquillin(at)gmail.com (rjquillin(at)gmail.com)> wrote:
[quote] --> AeroElectric-List message posted by: Ron Quillin <rjquillin(at)gmail.com (rjquillin(at)gmail.com)>
Matt, Deke,
I was thinking many of the same things, but given ATC was reporting his unit was 'normal', I discounted them, as I would have thought they would have complained of excessive replies or ident's making a mess of their sereens. IIRC, the 150, unlike the 50, does have a remote ident pin. I'll look in my SM tonight as see if there may be a some failure to the light circuit only, doesn't seem likely, but...
If the unit is in an area with many ADSB units and/or heavy radar coverage, it could actually be interrogated at some high rate and the reply light is working normally. One would expect it to be a bit quieter on the ground, out of sight of multiple radar sites but perhaps still seeing ADSB inquires. However, Deke reports a change. Has anything else changed within the AC that may give a clue?
I agree, a bench check at a radio shop or exchange unit should be near the top of things to try.
Ron Q.
--> AeroElectric-List message posted by: "Matt Prather" <mprather(at)spro.net (mprather(at)spro.net)>
Matt-
> Deke
Fox5flyer
PostPosted: Wed Jul 30, 2008 5:08 pm    Post subject: Re: AT150 Interrogation Light Reply with quote
Thanks, Matt. You've given me several things to try. Yes, I do have a new cell phone and the first thing I'll try is to turn it off and see what happens. I also have dual electronic ignition and I'll do some experimenting there too. One thing I've noticed is that one of the ignitions has begun to make a noise in my headset. Basically I can hear the trigger wheel going past the crank sensors, so I may have some wiring that is leaking through to the headset wiring and possibly to the transponder too. Something to look at. Other than that the ignitions seem to be operating fine, as is the alternator, however I have no way of turning it off. The transponder acts normally when the engine isn't running. I my area its very rural with no interrogation pulses until I get at least 2000agl, and even those are a long way off, so I'm not getting bombarded with pulses.
However, I do have some things to try. Thanks.
Also, thanks to the others who offered help.
Deke
Matt-
Deke
nuckolls.bob(at)cox.net
PostPosted: Wed Jul 30, 2008 6:17 pm    Post subject: AT150 Interrogation Light Reply with quote
Got in on this thread late but as others have noted,
the transponder receiver is rather 'twitchy' with
respect mistaking incoming noises as a bona fide
"paint" from a ground based radar.
A technician I used to work with had some rubber
bands permanently installed over the hand grip
on his line operated electric drill. I asked what
they were for and he was happy to demonstrate. Use
the rubber bands to hold the trigger made and then
lay the drill on the floor right under the transponder
antenna. From outside the cockpit you could see the
reply light going nutso. He had one of those altitude
and squawk code receiver/readouts that could then
be used to see if the altimeter encoder was reading
the same as the pitot-static test set altitude.
The drill motor and the el-cheeso readout accessory
took the place of some rather expensive test equipment
for doing pitot static tests.
Try pulling all the breakers/fuses except transponder.
See if effects go away. Reinstall feeder protection
one device at a time to see if you can identify the
one that's upsetting the transponder. But all who
have responded to this thread have identified possibilities
for pesky little noises that might be causing the
problem. It doesn't take much.
Fox5flyer
PostPosted: Thu Jul 31, 2008 8:32 am    Post subject: Re: AT150 Interrogation Light Reply with quote
Thanks for your reply, Bob. I appreciate all input. Well, I flew this morning for about an hour and the first thing I checked was that my cell phone was turned off. No change. At cruise the light was on steady. Next, I switched off my left ignition which did two things. It stopped the noise in my headset and the interrogation light on the transponder went out and started blinking normally! I'm getting close. So, now I can tear into the wiring and see where my left ignition wiring is in a common bundle with my headset receive and also the transponder. What would you suggest here? Obviously I need to either separate some wiring or do some shielding, but I'm not sure which way I should go. If you were to home in on a specific wire, which would it be? My engine is the NSI EA81 with stock Electromotive ignition modules. I personally don't think anything is wrong with the ignitions. I believe I just have an ignition wire somewhere causing interference. I'll dig my schematics out to see if I can experience an epiphany.
Thanks again,
Deke
NE Michigan
etienne.phillips(at)gmail
PostPosted: Thu Jul 31, 2008 9:00 am    Post subject: AT150 Interrogation Light Reply with quote
Could it be a spark-plug lead connected to the left ignition circuit that has a problem with it's shielding?
Etienne
2008/7/31 Fox5flyer <fox5flyer(at)idealwifi.net (fox5flyer(at)idealwifi.net)>
[quote]--> AeroElectric-List message posted by: "Fox5flyer" <fox5flyer(at)idealwifi.net (fox5flyer(at)idealwifi.net)>
Thanks again,
Deke
NE Michigan
PostPosted: Thu Jul 31, 2008 9:39 am    Post subject: AT150 Interrogation Light Reply with quote
Deke,
Sounds like you're making progress.. Does the engine have two plugs per
cylinder? If so, the problem could be as simple a faulty high tension
lead - or even a bad plug.
Along these lines, my guess would be that the source of noise is in the
high-energy portion of the system - as that seems most likely to radiate
offensive noise. That's why I'd guess the noise is from a high tension
lead.
If not dual plugs, does your system use a coil switcher? If so, maybe the
noise is in that portion of the circuit.
Good luck!
Matt-
<fox5flyer(at)idealwifi.net>
somewhere causing interference. I'll dig my s!
Thanks again,
Deke
NE Michigan
Fox5flyer
PostPosted: Fri Aug 01, 2008 4:35 am    Post subject: Re: AT150 Interrogation Light Reply with quote
Thanks, Matt. First, the engine uses one plug per cylinder. The two ignitions come together in coil joiners (isolation modules). I'd considered the possibility of a bad high tension lead, but sort of discounted that because the engine runs great from either ignition with no drop at all with mag checks. Then again, that's just my logic talking and it doesn't mean that it's not a high tension lead. I've changed plugs with the same result. If I could figure out what "might" be causing it, I could probably do a little wire sorting and find the culprit, but I'm just not knowledgeable enough to get a clear picture in my mind what is happening. Obviously, it's emanating from the left ignition circuit because when I turn off power to it, the noise in my headset stops and the interrogation light on the transponder goes out. I've already checked all of the high tension leads with an ohm meter and none are significantly different which leads me to believe the problem lies in the "placement" of my wiring bundles somewhere. Am I making sense?
Thanks again,
Deke
Deke,
lead.
Good luck!
Matt-
<fox5flyer>
Thanks again,
Deke
NE Michigan
PostPosted: Fri Aug 01, 2008 5:05 am    Post subject: AT150 Interrogation Light Reply with quote
different which leads me to believe the problem lies in th!
On the TC side of aviation's house, all appliances considered
for use on airplanes is evaluated for its stand-alone
characteristics with respect to noise emissions, noise
vulnerabilities, temperature limits, etc. The goal is
to offer smooth integration of that device into an
airplane where the installer does not need to accommodate
a shortfall in performance.
I presume that you have two identical ignition systems
of which only one causes noise. I'm presuming further
that few (if any) other builders have experienced the
noise issues with these systems. This leads me to
suggest that there is something "different" about the
two systems installed on your airplane. It might be
fixed by a wire installation revision . . . but if so,
then perhaps theses systems have not been sufficiently
refined sufficiently for smooth integration into aircraft.
I mention all this because it offers a mode of investigation
that looks for differences between the two systems. One
generates an unacceptable level of noise while the other
does not. How are wires routed differently between the two?
You might try swapping components between the two systems
to see if the problem follows the swap. You can use the
12 lantern battery experiment to power each system up
independently from ship's power . . . although this is
a very long shot for a noise that the transponder sees.
The transponder has already been qualified to tolerate
a lot of conducted noise into ship's wiring . . . the
energy that upsets it now is probably coming through
the antenna. So, try disconnecting the transponder
antenna for a short test to see if it stops triggering
on the noise.
This is a game of clue. You've identified the source
of noise and victim to that noise. Now you need to
ferret out the propagation mode. Once that's identified,
the fix will be easy.
Kellym
PostPosted: Fri Aug 01, 2008 5:59 am    Post subject: AT150 Interrogation Light Reply with quote
One cheap "tester" to find the source of the noise, is an old Walkman or
equivalent radio(yeah, those things about 2 generations older than the
Ipod), tuned away from any station, on the AM band, preferably near the
top...1650 or thereabouts. Then just move it about taking all necessary
precautions with regard to the prop slice/dicer up front. Wherever the
noise peaks, is the location of the offender. I've found bad voltage
regulators that way, among other things. Just a resistance reading
doesn't prove a high tension lead isn't leaking noise, only proves
continuity.
Fox5flyer wrote:
Thanks, Matt. First, the engine uses one plug per cylinder. The two ignitions come together in coil joiners (isolation modules). I'd considered the possibility of a bad high tension lead, but sort of discounted that because the engine runs great from either ignition with no drop at all with mag checks. Then again, that's just my logic talking and it doesn't mean that it's not a high tension lead. I've changed plugs with the same result. If I could figure out what "might" be causing it, I could probably do a little wire sorting and find the culprit, but I'm just not knowledgeable enough to get a clear picture in my mind what is happening. Obviously, it's emanating from the left ignition circuit because when I turn off power to it, the noise in my headset stops and the interrogation light on the transponder goes out. I've already checked all of the high tension leads with an ohm meter and none are significantly different which leads me to believe the problem lies in th!
Thanks again,
Deke
Kelly McMullen
KCHD
PostPosted: Fri Aug 01, 2008 6:46 am    Post subject: AT150 Interrogation Light Reply with quote
regulators that way, among other things. Just a resistance reading doesn't
prove a high tension lead isn't leaking noise, only proves continuity.
Good point! I've still got some pocket transistor
radios around that have been used for that purpose
years ago. In my case, I was tracking down arcing
insulators on power poles. The directional qualities
of their "loopstick" antennas can be exploited to
deduce direction of a received signal (as described
in the 'Connection's chapter on antennas).
I've not had occasion to use one of these radios
in many years. I heard of a more modern utilization
in a class on RFI/EMC issues about 15 years ago. The
speaker told how he boxed a pocket radio up in an
RF tight, aluminum enclosure. He brought a coax
connector through the box and tied it to a "primary
of a transformer" wound around the radio. I think
it was 5 turns of 22awg wire. He also brought out
the headphone circuit through RFI filters.
The radio was turned ON, tuned to the high end
of the band, volume up to max and the box closed.
A short piece of coax could be fitted at the end
with either magnetic or electric field probes
http://aeroelectric.com/Pictures/Tools/RF_Antenna_Test_Tools/Sniffer_Probes.jpg
I built these probes for use on a very broadband
spectrum analyzer. Another name for a fancy
receiver.
This poor man's electronic "stethoscope" was useful
for "sniffing" about the airplane for the purpose
of pinpointing the exit location for a radiated
noise source. This also assumes that the noise
source is also broad band with components in the
audible range. In other words, a relatively clean,
RF energy or energy at very high frequencies would
not produce a signal that one would expect to hear
with this tool.
In the case before us, the repetition rate for
ignition system currents are very much in the audio
range and have a base-band component that is at
or below the broadcast band detection range of
the pocket radio.
This system would not be useful for finding
conducted noise sources where the offending signal
stays pretty much in the wiring. Once it's absolutely
confirmed that the transponder's antagonist is
radiated (coming in through the antenna) then
perhaps Kelly's suggestion offers a useful tool for
further investigation.
