ebbfmm(at)yahoo.com Guest
Posted: Sat Mar 04, 2006 7:46 am Post subject: Fuel Lube |
Larry and RV Listers, fuel lube equivalent is availble from Aircraft Spruce
under the brand name EZ Turn. I purchased mine from an A&P years ago so I
couldn't tell you the brand of the original, but he swore by it and it has
not let me down. At one point during my testing process I had a small fuel
leak in the fitting going to the fuel flow transducer. Knowing the fitting
was already torqued to specs, I backed out the nut and put a very small
amount on the flared tubing, re-torqued the nut to specs and no leaks since.
Fran Malczynski
RV6 - N594EF
Olcott, ny
cfi1513840(at)comcast.net Guest
Posted: Sat Mar 04, 2006 2:53 pm Post subject: Fuel Lube |
Should EZ Turn be used on the face of the tubing flare where it contacts the
fitting? I have previously been told it should only be used on threads.
Ken Howell
Glenwood Maryland
RV7 Wings
ptrotter
Joined: 10 Jan 2006 Posts: 28 Location: Westchester County, NY
Posted: Sat Mar 04, 2006 5:54 pm Post subject: Fuel Lube |
Ken,
Do not put anything on face of the tubing, it should be clean and smooth.
Paul
_________________ Paul Trotter
RV-8 82080 Fuselage Kit
N801PT (reserved) |
Posted: Sun Mar 05, 2006 8:58 am Post subject: Fuel Lube |
Paul,
Thanks for confirming that for me.
Ken
