Z-19/RB Question
mrspudandcompany(at)veriz
PostPosted: Sun Jul 27, 2008 9:45 am    Post subject: Z-19/RB Question Reply with quote
In reviewing the Z-19/RB drawing, I have a question regarding the endurance bus feed. There is a diode feed from the main bus, with which I have no problem. However, if the alternator fails and the low voltage module opens the engine battery contactor, there is no way to power the endurance bus from the engine battery. In this case both paths to the endurance bus come from the main battery. Did you intend for this wiring to be this way or should the EBUS ALT FEED connection be made to the engine battery bus instead of to the main battery bus?
Roger
nuckolls.bob(at)cox.net
PostPosted: Sun Jul 27, 2008 10:50 am    Post subject: Z-19/RB Question Reply with quote
At 01:42 PM 7/27/2008 -0400, you wrote:
No, the normal feed is from the main bus which
(in normal operations) is powered from the main
bus supported by the alternator and two batteries.
In case of alternator failure (and with the engine
battery switch in the AUTO Mode), the engine battery
is automatically separated off to support only
the engine. The main battery is still supporting
the main bus . . . until the pilot elects to drop
to an endurance mode (main battery contactor OFF,
alternate feedpath closed).
Normally, you would never want to power the endurance
bus from the engine battery unless you've suffered
multiple-failures (main battery craps). Even then
you're probably better off reverting to the J-3 mode
with stuff from the flight bag as opposed to burdening
the engine battery with keeping the fan running
-AND- powering up stuff on the panel.
So your observations are correct, there was never
any intention of powering the e-bus from the engine
battery.
However, you ALWAYS have the option of closing both
battery contactors and running the whole airplane
from both batteries in parallel. The set of
circumstances that would make this necessary/attractive
are exceedingly rare. If it were my airplane, I'd
have to be really hard pressed (and probably il-prepared)
to burden the engine battery with more than running the
engine.
( -Thomas Paine 1776- )
mikefapex
PostPosted: Sun Jul 27, 2008 2:40 pm    Post subject: Re: Z-19/RB Question Reply with quote
In normal operations of a Z-19, would you have the EBUS ALT FEED switch turned ON (closed)? Seems that would keep the emergency switch manipulation to just one, the Master OFF. The ENGINE BAT switch in the AUTO position would already disconnect the Engine Battery.
Do I have this right? Thanks,
PostPosted: Sun Jul 27, 2008 6:29 pm    Post subject: Z-19/RB Question Reply with quote
At 03:40 PM 7/27/2008 -0700, you wrote:
You can if you wish. However, it's an ALTERNATE feed
path and needs to be pre-flight tested. I'd turn
it ON first thing and get the ATIS and clearance
delivery. Then shut it OFF, start the engine, and leave
it off until such time as needed to mitigate
the effects of an alternator failure.
mikefapex
PostPosted: Mon Jul 28, 2008 6:19 am    Post subject: Re: Z-19/RB Question Reply with quote
Understood, that EBus switch is ALTERNATE path to powering the EBus. And as you said, turn it on, check ATIS are all good preflight procedures to test this path.
I just wanted to confirm that once you are started and the alternator is running smoothly, it would do no harm to leave the EBus switch turned on (closed) during normal operations.
PostPosted: Tue Jul 29, 2008 5:08 pm    Post subject: Z-19/RB Question Reply with quote
At 07:19 AM 7/28/2008 -0700, you wrote:
test this path.
No harm at all. This part of the design philosophy. No
mis-ositioning of switches places any part of the
system at-risk for failure.
bicyclop(at)pacbell.net
PostPosted: Wed Jul 30, 2008 9:43 pm    Post subject: Z-19/RB Question Reply with quote
Mike,
That's exactly how I've operated our RV for years. My reasoning for
doing so is that I only have to turn off one switch (the master) in case
of alternator failure. I don't have to worry about turning on the alt
feed before doing so to avoid rebooting stuff. In fact, when my
alternator quit working on my way to British Columbia last spring,
that's what I did. Flipped one switch and kept going. Had enough battery
for an hour's flight, landing at a towered airport for gas, a start and
departure and another 45 minutes of flight and still had enough in the
battery for a start after replacing the alternator. I turned off stuff
we didn't need, but kept the electronic ignition, transponder and GPS
going. Turned on and used the Com when I needed to and didn't worry
about maintenance till we stopped at our intended destination for the night.
I turn on the alternate feed, check atis while I'm inserting my ear
canal headset to make sure I've got them in right then I turn on the
master, start and operate normally. My voltmeter is on the E-Buss so, if
I do turn the alt feed off, I'm reading a voltage somewhat lower than
the actual charging voltage. I don't have to do any math to see what the
alternator is up to.
Pax,
Ed Holyoke
mikef wrote:
http://forums.matronics.com/viewtopic.php?p=195343#195343
mikefapex
PostPosted: Thu Jul 31, 2008 6:14 am    Post subject: Re: Z-19/RB Question Reply with quote
Thanks Ed, That is a helpful confirmation of my understanding. I am building my preflight/postflight checklists for this new z-19 system. I too don't want things to go 'offline' if the alternator dies.
PostPosted: Thu Jul 31, 2008 9:18 pm    Post subject: Z-19/RB Question Reply with quote
Just one more thing, Mike. I periodically test the diode feeding the
E-Buss by turning on the master only or turning off the E-buss switch
first and making sure that the stuff on the E-buss is hot. I don't want
the alternate feed switch to be the single point of failure.
Pax,
Ed Holyoke
http://forums.matronics.com/viewtopic.php?p=195860#195860
PostPosted: Fri Aug 01, 2008 5:08 am    Post subject: Z-19/RB Question Reply with quote
The e-bus alternate feed switch cannot be a single point
of e-bus failure since it's the second of two independent
feed paths to the e-bus. If the alternate feed path is
pre-flight tested and then "put away unless needed" then
probability of it being available as needed is very high.
This was the spirit and intent of the alternate feed path
philosophy re-enforced by the notion that it was a good
thing to shut battery contactors off during battery only
operations.
PostPosted: Fri Aug 01, 2008 5:20 am    Post subject: Z-19/RB Question Reply with quote
The only thing that happens when the alternator quits
is that bus voltage drops from a nominal 14.2 volts down
to about 12.6 volts. If you did NOTHING at this point in
time, you would be no worse off than if you were flying
a C-172 except that your options for load shedding
for battery only ops are more limited in the C-172.
If you were typical of C-172 drivers, you would have
no idea how long the battery would carry the minimum
loads you were able to achieve because not one C-172
driver in 1000 has any first hand knowledge of (1)
battery capacity and (2) how long his minimized loads
will run from that capacity.
If you did not have the alternate e-bus feeder
installed (replace the diode with an avionics
master switch) you MIGHT still have a leg up on a
C-172 driver in that you could conduct the experiments
to KNOW how much battery only endurance you had with
that particular architecture.
Now, having added the alternate feed path and the
diode that prevents mis-routing of energy, you
have an opportunity to craft a confident plan-b
for dealing with alternator failure. The plan-b
removes all loads not necessary for en route operation
of the airplane . . . which can be quite small.
This INCLUDES energies need to keep the battery
contactor closed. Once you are cleared to land
you can turn the battery master back ON and run
any number of additional goodies you wish. Whether
or not they continue to run to the parking spot
is immaterial to the outcome of the flight.
There is no compelling reason to fly with the alternate
feed path closed. Even if your ships voltmeter feeds
from the e-bus, it reads about .7v lower than
main bus . . . so what? That value becomes the
NORMAL operating point for the e-bus. The fact
that it does not represent main bus voltage is
of no consequence to you as a pilot in the operation
of the airplane.
Checked by AVG - http://www.avg.com
6:37 PM
PostPosted: Fri Aug 01, 2008 10:37 am    Post subject: Z-19/RB Question Reply with quote
What I was saying is that I use the "alternate feed switch" (labeled
"E-Buss") as the primary feed to the E-buss, sort of like an avionics
master, and that the diode on the master is now a backup and as such, I
need to make sure it hasn't failed leaving only one feed path available
to my essential equipment. I do test the feed path, but I don't put it
away until needed, as you say, because I feel having it on simplifies
the process of load shedding (including the contactor and alternator
field) in case of alternator failure (or ground ops). I chose this
method because I don't want to risk inflight re-booting of my EFIS and
autopilot by flipping switches in the wrong order. That I don't have to
do (admittedly easy) math with the .7 volt diode drop is gravy, not the
deciding factor.
It strikes me that, if one didn't mind having an extra switch, the diode
could be eliminated as well, leaving the E-Buss as a separate entity
from the main buss. The philosophy of having independent feed paths and
being able to simply shed unnecessary loads would still be served.
Pax,
Ed Holyoke
Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)cox.net>
> <bicyclop(at)pacbell.net>
> want the alternate feed switch to be the single point of failure.
operations.
PostPosted: Fri Aug 01, 2008 12:50 pm    Post subject: Z-19/RB Question Reply with quote
At 11:33 AM 8/1/2008 -0700, you wrote:
need to make sure it hasn't failed leaving only one feed path available to
my essential equipment. I do test the feed path, but I don't put it away
until needed, as you say, because I feel having it on simplifies the
process of load shedding (including the contactor and alternator field) in
case of alternator failure (or ground ops). I chose this method because I
don't want to risk inflight re-booting of my EFIS and autopilot by
flipping switches in the wrong order. That I don't have to do (admittedly
easy) math with the .7 volt diode drop is gravy, not the deciding factor.
could be eliminated as well, leaving the E-Buss as a separate entity from
the main buss. The philosophy of having independent feed paths and being
The diode was considered necessary and useful to eliminate
the potential for having both switches closed at the same time
and having the main bus take power through the e-bus alternate
feed path . . . a bonus of using the diode IS the automatic
switching of one feed path and elimination of the switch.
Of course, how you choose to modify the system and its
operation is a personal decision.
