ghinman(at)mts.net Guest
Posted: Thu Jul 31, 2008 6:24 pm Post subject: Starter gear won't retract |
The gear on my starter will not retract back
away from the flywheel gear.
It is not jammed against the flywheel because it will not retract
even when the flywheel is removed
Any ideas
It is a Lycoming O-360 with one of the larger starters.
George H. Inman
ghinman(at)mts.net
rv4ross(at)charter.net Guest
Posted: Thu Jul 31, 2008 7:29 pm Post subject: Starter gear won't retract |
George,
Spray some lubricant such as LPS1 onto the gear and the shaft that it
slides on. Rotate that gear until the lubricant
is worked back onto the shaft. If this does not free it up you may have to
replace the starter.
Good luck,
Ross Scroggs
RV4 Fuselage
Locust Grove, GA
Posted: Thu Jul 31, 2008 7:33 pm Post subject: Starter gear won't retract |
George Inman 204 287 8334 wrote:
<ghinman(at)mts.net>
retract
Any ideas
Two:
Remove the bendix and clean real good ..... do not grease. It may be
worn so bad it needs parts replaced.
Buy a skytec starter. No bendix to worry about.
| Quote: | It is a Lycoming O-360 with one of the larger starters.
My O-360 has a Skytec. You won't believe the difference!!!
Linn
Posted: Thu Jul 31, 2008 7:39 pm Post subject: Starter gear won't retract |
rv4ross wrote:
George,
it slides on. Rotate that gear until the lubricant
have to replace the starter.
You should still clean the LPS1 off. And you can take the starter to an
auto starter place and they'll replace the parts. If it were me ....
I'd just buy a Skytec. ..... and no, I don't get paid for my opinion. I
really like mine .... and hate anything with a bendix.
Good luck,
Ross Scroggs
RV4 Fuselage
Locust Grove, GA
jsflyrv(at)verizon.net Guest
Posted: Thu Jul 31, 2008 11:37 pm Post subject: Starter gear won't retract |
retract
Any ideas
Is this after starting? The starter gear will not retract untill it
reaches a certain RPM
If you engage the starter and the engine does not start they will
sometime not retract.
JFLEISC(at)aol.com Guest
Posted: Fri Aug 01, 2008 12:49 pm Post subject: Starter gear won't retract |
In a message dated 8/1/2008 3:38:31 A.M. Eastern Daylight Time, jsflyrv(at)verizon.net writes:
| Quote: | Is this after starting? The starter gear will not retract until it
Ditto. That has been my experience with those antiques. I welded a bracket to adapt a Mitsubishi starter (looks like a skytec but got it free off a junk car) and it has been great for the last 10 years.
Jim
Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos.
Jerry Grimmonpre'
Joined: 09 Jan 2006 Posts: 144 Location: Huntley, Illinois 60142
Posted: Fri Aug 01, 2008 1:14 pm Post subject: Starter gear won't retract |
Jim
[quote] Is it possible to submit a picture to the list showing what you have done to make the Mitsubishi starter useable? Maybe a word description?
Thanks ...
Jerry
RV4
In a message dated 8/1/2008 3:38:31 A.M. Eastern Daylight Time, jsflyrv(at)verizon.net (jsflyrv(at)verizon.net) writes:
Jim
Posted: Fri Aug 01, 2008 4:01 pm Post subject: Starter gear won't retract |
In a message dated 8/1/2008 5:15:24 P.M. Eastern Daylight Time, jerry(at)mc.net writes:
| Quote: | Is it possible to submit a picture to the list showing what you have done to make the Mitsubishi starter useable? Maybe a word description?
Thanks ...
Jerry
RV4
Jim
Jerry;
I looked through my files and this pathetic photo is the only thing I have. It is a permanent magnet gear reduction "nose-less" type of starter that I remember getting out of a Mitsubishi. They should be easy to come by because the engines and frames usually fall apart and all that's left is the starter. It has 2 mounting ears and I made a flat plate with holes, that mounts to the spot where the original starter went on my 0-360. I welded 2 ears onto the plate with a tube (for bolts) on each ear. You have to get this part right for the correct gear engagement. There is a small support "tang" on the back of the plate that rests on the back of the starter so the drive won't push out of the flywheel teeth when engaged. It weighs about half as much as the stock starter so keep weight and balance in mind. It spins the engine about twice as fast which may cause a problem as mine did. It spun just fast enough that the magneto impulse coupler would not engage. I had to lighten the fly weights in the magneto. Works great now.
One other thing; shortly after I put it in the starter drive clutch started to slip. A replacement drive was outrageous but the Mitsubishi drive can be disassembled. I removed the worn cam rollers and bought a drill blank a few thousandths larger. Cut it up and used them as replacement rollers. That was 10 years ago and it still works perfect.
Jim
62.82 KB |
280 Time(s) |
Jerry Grimmonpre'
Posted: Fri Aug 01, 2008 7:25 pm Post subject: Starter gear won't retract |
Thanks Jim ...
I follow your word description fairly good, Jim, and congratulate you on your creative problem solving. I'll try this in the future.
Jerry
