fklein(at)orcasonline.com Guest
Posted: Fri Aug 01, 2008 3:38 pm Post subject: sight tube |
Greg...per your request, a couple of pixs of my installation. Note that
my intention w/ the tween-seats sight tube is to have a visual check
while refueling, and to meet a regulatory requirement for a 2nd means
of determining fuel on board; during flight, my expectation is to relay
upon the Europa-mod fuel gauge and digital instrumentation. Note that
the sight gauge in this location shows only fuel above top of tunnel.
Hope these help,
Fred
believed to be clean.
Roll 24 - 26
Roll 30 - 4
Roll 30 - 5
Description: |
Filesize: |
43.43 KB |
Viewed: |
480 Time(s) |
Description: |
Filesize: |
43.81 KB |
Viewed: |
482 Time(s) |
Description: |
Filesize: |
42.84 KB |
Viewed: |
526 Time(s) |
gregoryf.flyboy(at)comcas Guest
Posted: Fri Aug 01, 2008 5:51 pm Post subject: sight tube |
Thanks for the pics. Nice installation Fred, and a great way for a refueling
check. The extra bidding is a good way to keep the surface flat. It looks
like the end fittings are plastic, as well. Any ideas as to the type of
sealant to use on the pvc-pvc fittings? I wonder if the standard pvc cement
will work, that is if it acts as a solvent and melts the plastic together,
it might be doing the same thing as the heat welds. What did you use?
Since yours were turned, I imagine some sort of sealer?
There is a big possibility I will install the site gauge in the front of the
seat back area, between the two seats.
I have also heard of others placing it in the seat back area behind the
seats?? If anyone has a picture or link for that installation, let me know.
I would like to evaluate both, before committing.
Quote: | Greg...per your request, a couple of pixs of my installation.
Greg F A050
Posted: Fri Aug 01, 2008 7:42 pm Post subject: sight tube |
On Friday, Aug 1, 2008, at 18:48 US/Pacific, Greg Fuchs wrote:
Quote: | It looks like the end fittings are plastic, as well. Any ideas as to
the type of sealant to use on the pvc-pvc fittings?
Greg,
I tapped the tube ends to match up w/ a Nyloc nipple which threads into
an aluminum 90 degree fitting at the top which is barbed on the other
end to receive the vent tubing...the bottom of the pipe (not shown) is
threaded to receive a Nyloc straight fitting which is barbed on the
other end to receive the 5/16" teflon lined fuel injection hose which I
used for the balance of my fuel system (aft of the firewall). All
fittings from Acft Spruce; I used standard automotive thread sealant.
Fred
A194
Roger.Mills(at)btinternet Guest
Posted: Sat Aug 02, 2008 2:05 am Post subject: sight tube |
I am concerned about the number of correspondents referring to PVC sight
tubes - PVC hardens and becomes brittle over time! In the UK there was an
incident or accident some time ago due to a massive fuel leak in flight
through a cracked PVC fuel tube - not something any of us would want to
repeat!
For this reason, the factory changed to polyurethane tubing - which,
although it discolours over time, is still readable after 5 years and can be
replaced at the same time as the rubber fuel pipes.
For what it's worth, the original Europa routing isn't as bad as it's made
out to be - I find that on the ground it's perfectly accurate and repeatable
as long as you calibrate it properly. Although it's useless in level flight
at 120kts, by slowing down to 80kts and aligning (by sight) the passenger
front and rear door surrounds with the horizon, I get a reading
approximately the same as the static reading, as long as there's not too
much turbulence. (I wouldn't rely on it for critical remaining range
decisions - but you might have the same problem with a between the seats
routing due to parallax).
Roger Mills
Posted: Sat Aug 02, 2008 3:48 am Post subject: sight tube |
Quote: | ....I am concerned about the number of correspondents referring to PVC
sight tubes - PVC hardens and becomes brittle over time! ...
Thanks for your thoughts, Roger. I too have heard that pvc tubing will not
last long. Is there any clear tubing that will last over 5 years anyway?
However, the rigid pvc piping is supposed to last quite well. I say this
with not much experience however, and it is subject to change. Let me know
if you have direct experience with the piping. Is there anyone else holding
their breath, who could add to the discussion on pvc piping?
Quote: | ...For what it's worth, the original Europa routing isn't as bad as it's
madeout to be - ...
I think to original routing has its place -esp on the ground, but it does
not seem as practical to me as a sight gauge right next to the tank, which
won't suffer from attitude adjustments (I would need one of those, I expect,
after finding out the readings are not reliable in the air).
Thanks for your input. The goal is to make this thing as reliable as
possible, so any and all input is accepted and expected. Please re-add your
input on rigid pvc pipes, if you can.
Greg
Posted: Sat Aug 02, 2008 4:09 am Post subject: sight tube |
anyone considered silicon fuel line. Its not quite clear but seems to last
well.
loboloda(at)execulink.com Guest
Posted: Sat Aug 02, 2008 7:05 am Post subject: sight tube |
I wonder if there are some extra volatiles crammed into Canadian auto
gas.
The tubing supplied with the kit was rejected by my inspector as the
first tank of gas
caused it to discolour and show signs of crazing.
The replacement polyurethane quickly discoloured.
Then I tried Bing tubing, stands up well, but soon went from a nice
clear blue to a murky brown.
I've been using Shell or Petrocan premium, as I'm assured that they,
along with Esso, do not yet
contain ethanol.
Dave
On 2-Aug-08, at 6:02 AM, Roger Mills wrote:
Quote: |
<Roger.Mills(at)btinternet.com>
sight
was an
flight
want to
repeat!
and can be
Roger Mills
Posted: Sun Aug 03, 2008 2:57 am Post subject: sight tube |
Geez, with all the tubing that's changing to all different colors of the
rainbow from the 'who knows how it will effect it' gas, I am beginning to
think of using glass tubing for the sight gauge. Maybe fully encasing it in
plastic tubing that would take over in case it ever broke from vibration.
Glass should guarantee no color shift, if it is reliable enough in this
environment.
Posted: Sun Aug 03, 2008 3:15 am Post subject: sight tube |
Craig,
In the technical bulletin below, it would seem that silicone might be even
worse than some of the others at standing up well to fuel. It is listed as
"Not recommended, severe effects imminent"
That is, If this bulletin is credible...
It lists Teflon, Nylon, and Viton to be the best materials.
http://www.sentranllc.com/pdfs/tb_chem.pdf
regards,
Greg Fuchs (A050)
___________________
Quote: | anyone considered silicon fuel line. Its not quite clear but seems to last
well.
Posted: Sun Aug 03, 2008 3:57 am Post subject: sight tube |
Hmmm thats very interesting, we used to use it for racing when running high
octane 109+ gasoline type fuels and methanol
as it was about the only hose that wouldn't harden within a few days of
using it. It was about 15mm OD with about a 5mm wall Perhaps it wasnt
strictly silicone line. I will see
if I can find out exactly what it was and let you know. Mind you I did have
one lot of line that i threw out after it started deforming
the day after a race meet, perhaps that was true silicone line
mikenjulie.parkin(at)btin Guest
Posted: Sun Aug 03, 2008 7:00 am Post subject: sight tube |
Why not 'bin' the sight tube altogether and fit an alternative gauging
system. I have twin capacitance probes and they work brilliantly.
Posted: Sun Aug 03, 2008 10:24 am Post subject: sight tube |
Mike, Of course, this is an option. I cut two holes in the top of the tank,
between the two headrests, and placed a mechanical float in the pilot hole,
and the other one is for upgradeability of the passenger side with the same,
or other fuel-related extras (second tank input, last-chance backup, or
whatever). The goal is to have a flow rate meter to tell the pilot how much
fuel is left, unless the tank begets a leak. Although unlikely to not have
other sensory inputs like smell, the first backup would be the mechanical
float. From reading other emails, the poly tank topside might ripple over
time. Because of its narrowness, it wouldn't take much movement (whether it
be rippling, or tank-top sender nut becoming loose, from the vibration) for
the throw of the mechanical wand to stick on the sidewall of the lower tank.
If one knew this was happening, it would be an easy matter to re-adjust the
wand in the tank. On the off chance that it snuck up on the pilot during
flight, it could make it seem that there is more fuel in the tank than
actual. Thus I like the simplicity of a third backup system being a sight
gauge. You can pretty much trust that you have what you see, if it is
installed properly. And if installed into the passenger side, it would allow
inspection of the reserve fuel, which is information that my one-float
system doesn't currently have, in its non-upgraded state. A good inspection
frequency would mitigate one caveat of the sight gauge -possible leakage due
to breakdown.
Of course, one could argue that the capacitance meter would be a good
replacement for the mechanical gauge, and it is. It would not be susceptible
to slight tank swelling due to fuel. Originally, that was my plan. But
capacitance gauges don't seem to be without their problems, either, such as
being sensitive to the different fuel additives being put into the tank. For
example, the alcohol is more conductive than the non alcoholic mogas, and
from what I have read, different fuels will affect the reading, like
switching between avgas and mogas. This will hinder the accuracy of the
gauge, and one could argue that the float could be at least as accurate, if
not more so -if the user is not married to one fuel type. Of course, a float
is also cost-effective on the pocketbook.
I don't mean to be anal-ytical about it all, but maybe it has happened.
Anyway, that is why I wanted the sight tube. Everything is subject to
change, of course. I might just throw in a second float for the 3rd
redundancy, and be done with it. The second float may only get in the way
slightly to the fuel related extras that will probably be using the second
hole, so I am still looking at the site glass/tube solution for now.
Hopefully, this has answered your question adequately
Greg Fuchs (A050), over 800 hours into the beast
<mikenjulie.parkin(at)btinternet.com>
Posted: Sun Aug 03, 2008 10:30 am Post subject: sight tube |
Yes, it would be interesting to know. It could be worth using if the useful
lifespan is high enough. Let me know if you find out...
Greg
h&jeuropa
Posted: Sun Aug 03, 2008 10:59 am Post subject: Re: sight tube |
The factory supplied sight gauge tubing is polyurethane (see Chpt 30). We noticed it was getting hard to read because of yellowing and also very hard and brittle after about 2 years exposure to auto gas. Decided to replace it during our after ground loop rebuild.
Went to the Tygon web site (www.tygon.com) to find alternatives. F4040A is listed as fuel tubing. However Europa supplied a length of that with our Long Range tank. The F4040A was inside the main tank and exposed to gasoline. After about 2 years it not only was virtually opague but it was hard and brittle. Decided against F4040A.
Tygon Tech rep suggested Tygothane C210A or Tygon SE200. Tygothane C210A is polyurethane without plasticizers. It should hold up to gasoline well. SE200 is PVC with a teflon liner. A search of literature suggests teflon is one of the most gasoline resistant materials.
We cut short sections of F4040A, SE200 and C210A filled them with auto gas and plugged both ends. The gas eventually leaked out of all of them, but it was out of the F4040A in a day or two, C210A about a month and SE200 took 3 months. We also put short pieces in a jar of auto gas. F4040A has discolored and gotten much stiffer in 3 months. C210A is discolored but not stiffer and SE200 the PVC has shrunk but the teflon liner has not changed.
So we are using SE200 for our sight gauge. For the Long Range tank feed, we used C210A. We also measure fuel quantity with a pressure sensor similar to Tony K's system feeding an input to our GRT EIS and the EIS calculates fuel usage from flow transducers.
Attached is a photo of the sight gauge up the back of the cockpit module.
Jim & Heather Butcher
N241BW
Description: |
Filesize: |
162.06 KB |
Viewed: |
533 Time(s) |
Posted: Sun Aug 03, 2008 12:12 pm Post subject: sight tube |
Greg
The neatest float gauge is the one Europa used to sell, It has a magnet
attached to a cork and reed switches at 8 or 10 points to read level.
Very reliable.
Best advantage of capacitance is if there's any water about in the tank
they read full scale. As you say reading varies with fuel type.
Most elegant fuel gauge is Tony K's but you have to build it yourself.
Graham
Posted: Sun Aug 03, 2008 9:16 pm Post subject: sight tube |
Hi Graham,
Yes, this magnet/reed switch idea does seem very reliable. Too bad its not
avail anymore. Hmmm.... I suppose someone can make a homegrown cork with a
magnet inside of it for the site glass/pipe, with some reed switches in the
back of it, out of the way behind the sight card.
I think the way the cap. meter reads the water at the bottom of the tank is
a great point, and a very good reason to have at least one in the system!
Was thinking of going with the Tony K idea at one point, but do not know
where to go to get the schematic/build description/programming data. Yes it
is quite elegant soln. Let me know if you have this info.
Greg
Posted: Sun Aug 03, 2008 9:33 pm Post subject: sight tube |
Ahhhhhhhh..........Its like this information is just the prescription my
doctor ordered.
Sounds like SE200 and C210A are the clear-cut winners, depending on the
application! Thanks for the update on the experiment.
I got the picture link, and will print it out. Thanks for that. It will come
in handy.
I am looking for a 'packet' of info, or anything I can get about a fuel
'head' pressure measuring system (the time needed to completely reinvent
this wheel would force me to a new path, I admire the time some have spent
to create this soln). Let me know if you have info on this.
Thanks again,
Greg
....snip..........
N241BW
Posted: Sun Aug 03, 2008 10:08 pm Post subject: sight tube |
Jim,
BTW, I am surprised how much fuel escaped from the plugged tubes.
Could you describe how the ends were sealed? Do you think it is possible
that some fuel escaped around the seals?
Greg F
....snip..........
N241BW
rholder(at)avnet.co.uk Guest
Posted: Sun Aug 03, 2008 11:55 pm Post subject: sight tube |
Greg Fuchs wrote:
Quote: | Yes, this magnet/reed switch idea does seem very
reliable. Too bad its not avail anymore.
Shown on the Europa site as Mod 60.
Could be still available if it is shown
Quote: | Hmmm.... I suppose someone can make a homegrown cork
with a magnet inside of it for the site glass/pipe,
with some reed switches in the back of it, out of the
Quote: | I think the way the cap. meter reads the water at the
bottom of the tank is a great point, and a very good
Quote: | Was thinking of going with the Tony K idea at one
point, but do not know where to go to get the
schematic/build description/programming data. Yes it is
The capacitive meter reads differently for Mogas and Avgas
I believe.
Richard
G-OWWW
High Cross
Posted: Mon Aug 04, 2008 12:37 am Post subject: sight tube |
Greg
the reed switch device is available.
<http://www.avnet.co.uk/lts/fuelgauge.php> Talk to Gerry Davis and tell
him I told you.
Tony K might sell you the chip and details for his gauge, ask him.
<tonyk(at)kaon.co.nz>
The first stand alone gauge of this type was installed by Graham Clarke
in the earl;y days. He used an old ASI to sense the head. Tricky to
engineer but it did work. Our PFA weren't happy but Graham was a skilled
innovator who worked for Marconi on radar and stuff.
Graham
Greg Fuchs wrote:
Quote: |
Hi Graham,
Greg
