		pwmac(at)sisna.com Guest
				 Posted: Mon Aug 04, 2008 5:34 am    Post subject: epoxys |
				Correct. For structural purpose the strongest additives would be
 chopped or strands of  Fiberglas then cotton flox. Much of the other
 fillers are just thickeners and definitely weaken the resin.The
 question is do you want to use epoxy resin for structural purposes?.
 Its pretty substandard for anything structural.
 In the case of our rib to spar epoxy joint the epoxy just holds the
 rib in place. Works fine if one uses a generous filet. That is not a
 good place for a small amount of epoxy. At that location plain powder
 filler or beads work just fine. Just use a syringe and a caulking
 gun, then use a pop stick to reach the places where the caulk gun
 does not reach.
 Lots of good books out there to get up to speed on the use of epoxy
 and Fiberglas composites.
 Paul
 At 06:00 AM 8/4/2008, you wrote:
 as i understand it glass beads are not just like flox. beads are
 used to stiffen the mix , say to use as filler, but they weaken the
 mix and should not be used in a structural application.  bob noffs
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Tom Jones
				 Posted: Mon Aug 04, 2008 5:49 am    Post subject: Re: epoxys |
				Jorge,
 I have used both the 3M epoxy and the Hysol.  I did not put flox in the 3M on the wing ribs I installed and had to push it back into place about every 30 minutes until it set up enough to not sag.
 I built another complete wing using Hysol and found that it did not sag, stays in place well, and needed no flox.
 Flox can be added to Hysol to make it cure very hard.  It is useful this way to coat the foam used to make flaperon tips and such.  Mix up some Hysol with flox added, spread it on the foam wing flaperon tips and rasp, file, and sand to shape and smooth when cured.  Hard as a rock!
 I also used Hysol with flox to fill and shape PVC wing strut fairing where they are trimed on the trailing edge to provide clearance to fold the wings.  The aluminum fairing cuff was riveted right into the harded flox/hysol mix.
 If you do find you need to thicken up some hysol, go slow adding the flox.  By volume start with about 1/8th the volume of the total hysol mixed up.  Mix it in well, then mix in a 1/2 a teaspoon or teaspoon at a time until it is the consistency of peanut butter and holds its shape when you make a peak like whipped cream with it.
 I use a set of cooking measuring spoons and eyeball the volumes when mixing.
  _________________ Tom Jones
Classic IV
Ellensburg, WA |
		Lynn Matteson
				 Posted: Mon Aug 04, 2008 4:45 pm    Post subject: epoxys |
				In models, we used the glass beads (Microballoons) to allow the epoxy
 to be sanded more readily. The milled fiberglass (chopped fiberglass)
 really adds strength.
 Lynn Matteson
 Kitfox IV Speedster
 Jabiru 2200
 Status: flying...oops...holding short at 561.8 hrs
  _________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
		Float Flyr
				 Posted: Tue Aug 05, 2008 5:02 am    Post subject: epoxys |
				I have used silicon powder as a filler on my boat.  It is not nearly as
 strong as flox but a lot smoother and harder than microballoons.  It's also
 a lot heavier than either.
 Noel
  _________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
