Posted: Mon Aug 04, 2008 8:53 pm Post subject: OSH RV-10 Nose Wheel Pants & Fairing |
Thanks everyone at OSH that made this year special.
I neglected to photograph a mostly white -10 (from North or South
Dakota) on the flight line that had some spectacular yet subtle
fiberglass work. I am specifically referring to the Nose Wheel Pants and
Leg Fairing. This builder changed the geometry of the leg fairing as it
intersected the wheel pants giving the transition a flat surface for the
wheel to pivot vs. the standard Vans look. The builder also built up the
leading edge of the Nose Wheel Pant for a smooth transition to the Leg
Fairing.
If anyone took a picture that assembly would you please forward me a
copy?
Robin
Robin(at)PaintTheWeb.com
bldanrv9a(at)yahoo.com Guest
Posted: Tue Aug 05, 2008 6:32 pm Post subject: OSH RV-10 Nose Wheel Pants & Fairing |
Robin,
That 10 is based here in Rapid City, SD and is owned by Curt Grote. The work your referring to was done by Gaylen Wilts of Sioux Falls, SD. I will forward your request to Curt in hopes he will contact you. If not let me know and I will get you some pictures.
Jerry Petersen
jpeter(at)rushmore.com
--- On Mon, 8/4/08, Robin Marks <robin1(at)mrmoisture.com> wrote:
| Quote: | From: Robin Marks <robin1(at)mrmoisture.com>
Subject: OSH RV-10 Nose Wheel Pants & Fairing
Date: Monday, August 4, 2008, 11:50 PM
South
subtle
Wheel Pants and
fairing as it
surface for the
built up the
to the Leg
Fairing.
forward me a
copy?
Robin
Deems Davis
Posted: Tue Aug 05, 2008 6:42 pm Post subject: OSH RV-10 Nose Wheel Pants & Fairing |
Robin,
I've got a picture of it, and will post it and all of the other OSHpics when I return next week.
Deems Davis
in Souix City enroute to Long Island
---- jerry petersen <bldanrv9a(at)yahoo.com> wrote:
Robin,
Jerry Petersen
> To: rv10-list(at)matronics.com
> South
> subtle
> Wheel Pants and
> fairing as it
> surface for the
> built up the
> to the Leg
> Fairing.
> forward me a
> copy?
> Thanks,
> Robin
> Do Not Archive
Kelly McMullen
Posted: Tue Aug 05, 2008 6:56 pm Post subject: OSH RV-10 Nose Wheel Pants & Fairing |
That SUX
You are missing the best of the monsoon season...........
On Tue, Aug 5, 2008 at 7:41 PM, <deemsdavis(at)cox.net (deemsdavis(at)cox.net)> wrote:
[quote]--> RV10-List message posted by: <deemsdavis(at)cox.net (deemsdavis(at)cox.net)>
Robin,
Deems Davis
A&P/IA, EAA Tech Counselor
KCHD |
