		dan(at)azshowersolutions. Guest
				 Posted: Tue Aug 05, 2008 3:23 pm    Post subject: Firewall sealant |
				I was wondering what any of yous guys (or gals) have used to seal small holes in the firewall? Certainly looking for as high a heat resistance possible. RTV? Gasketseal? Not sure what would be the best. In looking around the net I found a ceramic sealant that when cured would resist 2100 degrees, yet I think it would be too brittle and just crack under vibration.
   Oh wise ones who have gone before?
   Dan B
   Mesa, AZ
   KF-IV, 912s
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		N81JG(at)aol.com Guest
				 Posted: Tue Aug 05, 2008 3:59 pm    Post subject: Firewall sealant |
				I used Firestop Putty Pads to seal the wires, edges and passages through  the firewall in my RV7A. It is available from industrial electrical stores for  sealing junction boxes in walls. The putty is about the consistency of thick  chewing gum and stays pliable until hit by fire, then it chars and hardens  rather than melting or burning through. The pliability allows removal if you  need to open the hole or remove wires or cables. Check Google.com for different  types and manufacturers. I think I used Hilt, but 3M makes it also.
  John Greaves
  RV7A and VariEze
  Redding, CA
   In a message dated 8/5/2008 4:24:02 P.M. Pacific Daylight Time,  dan(at)azshowersolutions.com writes:
   	  | Quote: | 	 		     I was wondering what any of yous guys (or gals) have used to seal small    holes in the firewall? Certainly looking for as high a heat resistance    possible. RTV? Gasketseal? Not sure what would be the best. In looking around    the net I found a ceramic sealant that when cured would resist 2100 degrees,    yet I think it would be too brittle and just crack under vibration.
    Dan B
    Mesa, AZ
    KF-IV, 912s
 f="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronics.com/Navigator?Kitfox-List
 .matronics.com/">http://forums.matronics.com
 ://www.matronics.com/contribution">http://www.matronics.com/contribution
 Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos.
		Lynn Matteson
				 Posted: Tue Aug 05, 2008 4:17 pm    Post subject: Firewall sealant |
				You mean like pop rivet small?...hint, hint....
 Lynn Matteson
 Kitfox IV Speedster
 Jabiru 2200
 Status: flying...oops...holding short at 561.8 hrs
  Dan B
  Mesa, AZ
  KF-IV, 912s
  www.matronics.com/Navigator?Kitfox-List _-
  www.matronics.com/contribution _-
  _________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
				 Posted: Tue Aug 05, 2008 4:35 pm    Post subject: Firewall sealant |
				Not sure of your hints Lynn, but not really. I am working on a KF-IV and installing the Rotax 912s which requires one to make a recess in the top of the firewall to accept the oil can. I chose to make the firewall out of a solid piece of Stainless and then made a box (see attached link)http://www.azshowersolutions.com/Engine1.html
   I ended up with a few small holes in the corners and yes, I was thinking of filling the rivet holes as well. Something I missed in the manual?
   Dan B
 Lynn Matteson <lynnmatt(at)jps.net> wrote:
   [quote]--> Kitfox-List message posted by: Lynn Matteson
 Lynn Matteson
 Kitfox IV Speedster
 Jabiru 2200
 Status: flying...oops...holding short at [quote][b]
		Guy Buchanan
				 Posted: Tue Aug 05, 2008 4:38 pm    Post subject: Firewall sealant |
				At 04:22 PM 8/5/2008, you wrote:
   	  | Quote: | 	 		  | I was wondering what any of yous guys (or gals) have used to seal small holes in the firewall? Certainly looking for as high a heat resistance possible. RTV? Gasketseal?  |
  The construction industry uses a great intumescent putty from 3M. ( http://tinyurl.com/6flp2l ) It never hardens, is really sticky (messy,) and is good to at least 675F. You can get it on-line or at most construction supply houses. I've been using it, but haven't tested it yet.
  Guy Buchanan
  San Diego, CA
  K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar.    [quote][b]
Deceased K-IV 1200
A glider pilot too. |
		Tom Jones
				 Posted: Tue Aug 05, 2008 5:26 pm    Post subject: Re: Firewall sealant |
				 	  | Quote: | 	 		  | I was wondering what any of yous guys (or gals) have used to seal small holes in the firewall? |
 I use Red RTV.
  _________________ Tom Jones
Classic IV
Ellensburg, WA |
		Dick Maddux
				 Posted: Wed Aug 06, 2008 5:28 am    Post subject: Firewall sealant |
				Preparation H ?? (bad I know but couldn't resist0
                                  Dick Maddux
                                  Pensacola Fl
		mikeperkins
				 Posted: Wed Aug 06, 2008 6:34 am    Post subject: Firewall sealant |
				Permatex High Temperature RTV sealant (red) is rated from -75 to +650 F (intermittent) and resists fuel and oil. I’ve seen it gooped on muffler springs where it seems not to degrade. To plug firewalls, however, I’d be inclined to use rivets for small holes. For bigger holes I’d use riveted metal plates with a little red Permatex to create a seal against fumes.
 Mike Perkins
 Model I s/n 175
