rj_todd(at)yahoo.co.uk Guest
Posted: Sat Aug 09, 2008 4:03 am Post subject: Removal of u/c brackets from QB fuselage |
Hullo Everyone,
Is there anyone out there who has successfully managed to remove the main under carriage brackets from their QB fuselage?
There was a link some time ago where the question was asked how people had managed to remove the bolts and after many hours I have succeded in that. Apparently most were defeated and gave up any idea of inspecting under those floors, installing insulation/wiring/whatever there. My QB came with the front cabin floors temporarily in place. To be able to remove them you need to remove the u/c brackets.
Now the bolts are out, I find that I am unable to get the u/c brackets out because you need to pull them forwards whilst at the same time dropping the front attachment bar of the u/c bracket below the level of the front floor which is clearly impossible. Hence the question, has anyone managed to solve the puzzle short of destroying the front floors - Tim's log stated that his floors were not supplied with his kit and he did not have this problem.
I'm dreading the reconstruction ............!
Many thanks,
Rodger 40437
__________________________________________________________
Not happy with your email address?.
Get the one you really want - millions of new email addresses available now at Yahoo! http://uk.docs.yahoo.com/ymail/new.html
davelammers(at)mchsi.com Guest
Posted: Sat Aug 09, 2008 5:06 am Post subject: Removal of u/c brackets from QB fuselage |
Roger,
It is possible! I did it so as to put sound insulation in that area.
I do remember it took a lot of head scratching and a few (at)#$%^& words helped, but I don't remember the specifics.
Sorry no pictures. Wish I could help more, but the answer to your question is yes, it can, and has, been done but is not easy.
Dave Lammers
Finishing forever
Rodger Todd wrote: [quote] | Quote: | --> RV10-List message posted by: Rodger Todd <rj_todd(at)yahoo.co.uk> (rj_todd(at)yahoo.co.uk)
Hullo Everyone,
| [b]
Tim Olson
Posted: Sat Aug 09, 2008 6:15 am Post subject: Removal of u/c brackets from QB fuselage |
I feel your pain. Those gear brackets aren't fun to take
in and out. I did remove mine after I had them in though, so
I know how irritating it is. As you've already heard, one
good reason to pull them is to put sound insulation under
there. I have 3/4" foam under my front panels and in the
front sidewalls.
Rodger Todd wrote:
Hullo Everyone,
Many thanks,
Rodger 40437
effectus(at)rogers.com Guest
Posted: Sat Aug 09, 2008 6:16 am Post subject: Removal of u/c brackets from QB fuselage |
Roger,
I went through the arduous process of removing the undercarriage
brackets to get the front floor panels out. There was much swearing and
numerous skinned knuckles. Not a fun project.
To keep from having to do this ever again should the need arise to get
under the front floor panels I decided to modify the outboard aft corner
of the floor panel. I cut the panel diagonally at a 45 deg. a couple of
inches out from the corner and attached it permanently under the gear
leg bracket brace. I then fashioned an aluminum brace under the floor
that I could pop rivet the two floor pieces to along the seam.
I can't say that I would relish the thought of doing it again but at the
time I rightly decided to gain access to the area under the front floors
so that I could put the sound insulation in and to inspect the work done
overseas.
Dave 40164
Rodger Todd wrote:
Hullo Everyone,
Many thanks,
Rodger 40437
johngoodman
Posted: Sat Aug 09, 2008 12:00 pm Post subject: Re: Removal of u/c brackets from QB fuselage |
| Quote: | Hullo Everyone,
Is there anyone out there who has successfully managed to remove the main under carriage brackets from their QB fuselage? |
I didn't bother. I used a reamer for the match drilling, and you can vacuum out through the lightening holes on the aft side. I did check the torque on the bolts. I'm giving all my business to Bose when it comes to sound.
John
_________________ #40572 Phase One complete in 2011 |
Lenny Iszak
Posted: Mon Aug 11, 2008 6:08 am Post subject: Re: Removal of u/c brackets from QB fuselage |
I'm doing the same thing. I removed one of them already and got one more to go.
After much cursing I managed to get the mount past the fuselage bulkhead that's in the way and then it just came out.
What I'm worried about though is how do I torque those bolts. My monstrous torque wrench will not fit in there. Is it OK to torque them with the torque wrench on the bolt side instead of the nut side? It looked as if the phillippinos did not bother torquing them. Some got lose very easily...
The bolts looked pretty whacked by the time they came out, so I replaced all of them. All bolts and nuts cost about $20
Lenny
#40803
