johnd(at)data-tech.com Guest
Posted: Sun Aug 10, 2008 4:10 pm Post subject: Middle Balance Fairlead |
Hi All,
I'm working on finishing the rigging on my quickbuild 601XL and have a problem with the middle balance fairlead. On my quickbuild it appears to be mounted too high on its support such that the balance cable contacts the right rudder cable where it passes under it.
Looking at the plans (6-b-22) it shows the balance cable some distance below the rudder cable. I have looked at that page several times now and cant find any details on how high the balance fairlead should be mounted above the bottom skin.
Has anyone else encountered this issue or how high did you mount your fairlead ?
John Davis
601XL QB & Jab 3300
Burnsville, NC
Davcoberly(at)wmconnect.c Guest
Posted: Sun Aug 10, 2008 4:48 pm Post subject: Middle Balance Fairlead |
I just ran a string from one side to the other where it exits the sides and pushed it down enough to have good clearance to locate where to put my fairlead. While were on this subject I have question. The cable that runs to the lower elevator control that passes through between the seats' the upper fairlead' my cable rubs the lower part of the fairlead and the plans call for it to rub the upper part of the fairlead the reason for offsetting the fairlead on the hole drilled in the seat back to lower part of the hole. I cannot for the life of me find where I went wrong. This is a dual stick set up. Has anybody else had this happen? David [quote][b]
Posted: Mon Aug 11, 2008 7:40 am Post subject: Middle Balance Fairlead |
I had the issue, Just move it to where it does not touch anything. No need for the perfect spot mathematicall gyrations, just move it to where is does not touch other cables.
Juan
