Albert Gardner
Posted: Sun Aug 10, 2008 5:00 pm Post subject: tires |
Scott-what tubes are you using?
Albert Gardner
Yuma, AZ
_________________ RV-9A N872RV
RV-10 N991RV |
pascal(at)rv10builder.net Guest
Posted: Sun Aug 10, 2008 5:23 pm Post subject: tires |
Scott's in California so I'll respond for him:
I just recently replaced my main tires and tubes with Goodyear Flight Custom III 15/6.00-6 and Leak Guard Tubes 15/6.00-6. I'm not sure about the difference in size but there is a difference in weight capacity between a 6.00 and a 6.00-6. So far, so good on the tubes but I have only had them for one month. The tires are defiantly more beefy.
I bought everything through Desser and received them very quickly.
Tires and tubes is one area where I really didn't mind spending extra money. My old tires went almost 300 hours and they say the compound on the Goodyear tires are 20% more wear resistant and the rubber thickness is quite a bit more. Here is some data that Dresser posts on their site.
[url=wlmailhtml:{FBB49873-8627-4A3A-841A-E133FD78863A}mid://00000050/!x-usc:http://www.desser.com/gy_perform.html]http://www.desser.com/gy_perform.html[/url]
[url=wlmailhtml:{FBB49873-8627-4A3A-841A-E133FD78863A}mid://00000050/!x-usc:http://www.desser.com/airtubes.html]http://www.desser.com/airtubes.html[/url]
[url=wlmailhtml:{FBB49873-8627-4A3A-841A-E133FD78863A}mid://00000050/!x-usc:http://shop.desser.com/IW_Products.m4p.pvx?;MULTI_ITEM_SUBMIT]http://shop.desser.com/IW_Products.m4p.pvx?;MULTI_ITEM_SUBMIT[/url]
Good luck.
Scott Schmidt
scottmschmidt(at)yahoo.com
Sent: Sunday, August 10, 2008 5:58 PM
Subject: tires
Albert Gardner
Yuma, AZ
-----Original Message-----
On a side note, my Goodyear Flight Custom III are wearing so much less than the stock tires.
I now have over 125 hours on these tires and can hardly tell they are wearing at all. I'm very impressed.
Scott Schmidt
scottmschmidt(at)yahoo.com (scottmschmidt(at)yahoo.com)
Kelly McMullen
Posted: Sun Aug 10, 2008 5:38 pm Post subject: tires |
You can get just as much wear, if not more on a standard Desser recap,
and get 2 or 3 tires from the price of one of the GY FCIII tires. The
savings will let you buy fuel for 2-3 hours of flying.
On Sun, Aug 10, 2008 at 6:21 PM, pascal <pascal(at)rv10builder.net> wrote:
[quote] Scott's in California so I'll respond for him:
Good luck.
Scott Schmidt
Subject: tires
Albert Gardner
Yuma, AZ
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Sun Aug 10, 2008 7:56 pm Post subject: tires |
Check out Tim's site on that review and his impressions-
http://www.myrv10.com/N104CD/maintenance/20080503/index.html
Pascal
Sent: Sunday, August 10, 2008 6:36 PM
Subject: Re: tires
> Custom
> the
> quite
> Good luck.
> Scott Schmidt
> From: Albert Gardner
> To: rv10-list(at)matronics.com
> Subject: tires
> Albert Gardner
> Yuma, AZ
Kellym
Posted: Sun Aug 10, 2008 8:32 pm Post subject: tires |
I purposely did not mention the Monster Retread, as there are issues
when you put more tread on a tire than it started with.
I have been using Desser retreads for almost 15 years on both a Cessna
170 and on a Mooney M20E with no vibration or balance issues. That is
about 4 sets of them. Since both the above aircraft have gear that move
laterally depending on the weight on the gear, it is easy to get more
wear on one side, but never have had to rotate them. Y'all can buy
Goodyear$ or what ever you think is best for you.
KCHD |
scottmschmidt(at)yahoo.co Guest
Posted: Sun Aug 10, 2008 9:20 pm Post subject: tires |
I have no comparison to any other tire but it was very obvious that the Goodyears are wearing much better.
I have to believe that the Goodyear tires have stiffer sidewalls and possibly better puncher resistance but I have no data on that.
If Goodyear is good enough for Jeff Gordon and Dale Jr., they will be good for me.
Scott Schmidtscottmschmidt(at)yahoo.com
partner14
Posted: Sun Aug 10, 2008 10:16 pm Post subject: tires |
You threw out the names, but you must not have watched the NASCAR race at Indy a couple of weeks ago. NASCAR had to throw competition yellows every 10 to 15 laps or the tires would blow! Just a little ribbing.
Info on oil changes; on our catamaran, we have twin volvo diesels, and when I change either the oil or fuel filters, I slip a freezer bag all the way over the filter. Usually no mess at all.
Don McDonald
#40536 Finishing
--- On Sun, 8/10/08, Scott Schmidt <scottmschmidt(at)yahoo.com> wrote:
[quote]From: Scott Schmidt <scottmschmidt(at)yahoo.com>
Subject: Re: tires
Date: Sunday, August 10, 2008, 10:19 PM
40636 |
Tim Olson
Posted: Mon Aug 11, 2008 12:02 am Post subject: tires |
Monster retreads are not available in the size we need for the -10,
so the ones I have are High Performance Retreads. Our size is
specific: 15-6.00-6
So far, the retreads are working out well, but personally I think
they're far from built as nicely as a new pair of goodyears. Mine
were built on goodyear bases, but the tread wasn't applied perfectly
straight and consistent. other than having a lot of weight to
balance one of the 2 tires out, and the crooked tread, I haven't
noticed a big problem in their use.....I just won't do it again
though as I'd rather pay more and have something closer to
perfection.
Kelly McMullen wrote:
Posted: Mon Aug 11, 2008 8:06 am Post subject: tires |
I did miss the race at Indy but watched the highlights. Yae, Goodyear really blew it there. (pun intended)
I do plan on using retreads in the future but did not want to put them on the stock tires. My plan is to have a couple of Goodyear bases I can send out and have done.
But the way these things are wearing I feel like I'm going to get 3 times the wear that my stock tires had.
Dan Checkoway recommended a retread in the link below that he has been very happy with.
[url=http://www.vansairforce.com/community/showthread.php?t 784&highlight=tire]http://www.vansairforce.com/community/showthread.php?t 784&highlight=tire[/url]
I have always been a firm believer that you get what you pay for and have wondered if anyone out there has had any bad experiences with them?
It sure seems like 90% of the aviation community use them though. I just don't want to be away from my airport and have a tire separate. The savings might be $200 every 400 hours of flying by going with a retread and if there is a 5% greater risk of having an issue it just isn't worth it to me.
I am still new to the RV compared to many and new to flying as much cross country as I have been doing and I just don't know alot about retreads and their quality. I do know that I sure am dodging them alot on my motorcycle. I unfairly associate the two.
With the Goodyears if I do have a problem, those two guys in the blimp will see the issue and send out a tire right away. Pretty cool customer service. (If you haven't seen their commercial you won't get that one)
With Tim on one set and me on another it will be a good comparison.
Speaking of Dan Checkoway, today is a free day for me in California and I might fly over to Chino and check out the museum.
I believe that Chino is his home airport. http://www.planesoffame.org/
BTW: On my most recent flight I did drop the air pressure in my left main by 1/4 psi to free it up in the corners J/K
Posted: Mon Aug 11, 2008 9:34 am Post subject: tires |
Scott Schmidt wrote:
| Quote: | I did miss the race at Indy but watched the highlights. Yae, Goodyear
very happy with.
<http://www.vansairforce.com/community/showthread.php?t 784&highlight=tire>
I've never had ANY issues with the retreads ..... either on my car or my
airplane. The only discernible difference is the way the sidewalls
look. I've never been concerned with whether the grooves were true or
not .... so no data there. I wear them out and replace them.
| Quote: | The savings might be $200 every 400 hours of flying by going with a
Quantifying the risk is almost impossible (unless you're Rick Sked
) but I've not heard of any problems at all with retreads.
| Quote: | I am still new to the RV compared to many and new to flying as much
Almost 99% of the tire debris on the highway is truck tires ..... and
they destroy themselves due to low tire pressure that's missed by the
trucker. There are, of course, blowouts on cars ..... but I doubt that
they take care of their tires like you do.
| Quote: | With the Goodyears if I do have a problem, those two guys in the blimp
that one)
That was a good one!
| Quote: | With Tim on one set and me on another it will be a good comparison.
Not really ..... tire wear is all about how you land, and what you land
on. And comparisons are only good over the long term ..... too many
variables.
Linn
[quote] Speaking of Dan Checkoway, today is a free day for me in California
Scott Schmidt
timrvator(at)comcast.net Guest
Posted: Tue Aug 12, 2008 12:10 am Post subject: tires |
| Quote: | Dan Checkoway recommended a retread in the link below that he has been very happy with.
| I've used a set of the Wilkerson tires (retreads) for several hundred hours on my RV-6A. No problems, and they sure do appear to exhibit longer tread life than I experienced using new tires. I'll use Wilkerson tires again.
[quote]--
Tim Lewis -- HEF (Manassas, VA)
RV-6A N47TD -- 1000 hrs
RV-10 #40059 under construction[b]
