Corrosion protection
Goto page 1, 2  Next
Alf
PostPosted: Thu Jul 31, 2008 6:49 pm    Post subject: Corrosion protection Reply with quote
Hi,
I am new to this forum. After searching for info. about corrosion protection I have a question.
Cortec seems to be favored by ZAC but I noticed in one post that it was dissolved by fuel. Does anybody knows how would it react with Corrosion-X?
I ask this because that is the sequence of protection I have in mind, i.e.: use Cortec first (interior surfaces, spars, etc...), then apply Corrosion-X every year or two.
Does it makes sense?
Thanks for any help.
601-XL
Thruster87
PostPosted: Fri Aug 01, 2008 2:06 am    Post subject: Re: Corrosion protection Reply with quote
VpCI™-373Description: VpCI™-373 is a water-based wash primer. VpCI™-373 is used for bonding other primers and coatings such as VpCI™-386 to a variety of metal substrates. Cortec VCI 373 to my understanding is NOT a corrosion prevention coating such as alodine is, but a surface adhesion coating so that other primers/coatings bond to it.Also remember NOT to use etch primers with alodine as it will damage the protective coating. That's why I decided to use the Aluprep,Alodine and Zinc Oxide coating system on the inside structure other then the skins where I use Ardrox spray [dimitrol].For the outside skins I'll use Pre-Kote then a two part primer then a two part top coat [automotive paint made by Valspar] Cheers
chuck_maggart
PostPosted: Fri Aug 01, 2008 8:16 am    Post subject: Corrosion protection Reply with quote
Alf, I don't know about Corrosion X, but I used Cortec and it does a good job and easy to apply. However; I have one issue with it because it remains soft and sticky. Small metal shavings and filings and dirt are impossible to vacuum up and items, like seat cushions, will melt to it. If I did it again I would consider zinc oxide.
Chuck M.
601XL ready to fly
Chuck Maggart
Alf
PostPosted: Fri Aug 01, 2008 9:15 am    Post subject: Re: Corrosion protection Reply with quote
Thanks. It clarifies a lot about Cortec 373 but also brings some more confusion. You mention NOT to use etch primers but it is my understanding that Aluprep is an etching solution. In your case you would be etching the aluminum before the Alodine.
Please correct me if I am wrong.
Thruster87
PostPosted: Fri Aug 01, 2008 2:15 pm    Post subject: Re: Corrosion protection Reply with quote
Hi Alf The reason you use aluprep is to remove any oxide etc from the surface so that the alodine will work.You can tell if the surface is clean enough by pouring water on the surface and it will adhere /run nicely on it.Alodine produces a chemical reaction with the aluminum surface a bit like electro plating and this layer would be removed or damaged if you then use an etch primer. Cheers
Alf
PostPosted: Mon Aug 04, 2008 9:18 pm    Post subject: Re: Corrosion protection Reply with quote
Got it. Thanks for the info.
Alf
PostPosted: Tue Aug 05, 2008 1:47 pm    Post subject: Re: Corrosion protection Reply with quote
Alf wrote:
Got it. Thanks for the info. again, but when I went to order it I found TWO types of Aluprep, the BP Cleaner and the BP Zincate II. Logic tells me it is the Cleaner the one I need. Am I right?
Thanks again for your help.
jimandmandy(at)yahoo.com
PostPosted: Tue Aug 05, 2008 2:16 pm    Post subject: Corrosion protection Reply with quote
Metal Prep #79 or Alumiprep #33 (for corroded aluminum) are the recommended clean and
etch agents to use before Alodine. I tried Alodine without using a prep, just a solvent wipe, and it didnt "take".
--- On Tue, 8/5/08, Alf <alebron(at)bellsouth.net> wrote:
[quote]From: Alf <alebron(at)bellsouth.net>
Subject: Re: Corrosion protection
Date: Tuesday, August 5, 2008, 2:47 PM
[quote]--> Zenith601-List message posted by: "Alf"
the Cleaner the one I need. Am I [quote][b]
Thruster87
PostPosted: Wed Aug 06, 2008 3:12 am    Post subject: Re: Corrosion protection Reply with quote
Howdy, As mentioned earlier Alumiprep 33 is the go, it's my choice.It works like a charm using it with the green Scotch bright pads. Cheers
dalemed
PostPosted: Wed Aug 13, 2008 6:11 pm    Post subject: Re: Corrosion protection Reply with quote
Why are people using primer on 6061T6? Do they live near the ocean?
Dale
Flying Cessna 170B
Building Zenith CH650
Alf
PostPosted: Wed Aug 13, 2008 6:27 pm    Post subject: Re: Corrosion protection Reply with quote
I live about 30 miles from the Gulf Coast and any flying would be much less than that distance from salt water should I decide to go to East or West.
Only a few drops of sweat were enough to start some corrosion on the surface of my stabilator. That was enough for me to start considering protection.
carlossa52(at)gmail.com
PostPosted: Wed Aug 13, 2008 6:31 pm    Post subject: Corrosion protection Reply with quote
Not necessarily - people have seen corrosion on stored sheets in many different occasions, see archives.
Look at it this way: you will not regret having your plane primed, while not having it primed may cause regret.
Cheers
Carlos
CH601-HD, plans
Montreal, Canada
2008/8/13 dalemed <dalemed(at)gmail.com (dalemed(at)gmail.com)>
[quote] --> Zenith601-List message posted by: "dalemed" <dalemed(at)gmail.com (dalemed(at)gmail.com)>
Dale
Flying Cessna 170B
Building Zenith 601XL
PostPosted: Wed Aug 13, 2008 7:11 pm    Post subject: Corrosion protection Reply with quote
dalemed
PostPosted: Thu Aug 14, 2008 7:33 am    Post subject: Re: Corrosion protection Reply with quote
I'm not so sure of that. I've used primer on my tail surfaces - zinc oxide brushed on some and a self etching spray on some others. I have some regrets because I'm not sure I've done it properly. Have I properly prepared the surface? Have I put on the proper thickness? These are nagging questions that I wouldn't have if I hadn't primed.
I've heard that airplane manufacturers used to be (back in the 40s and 50s at least) prohibited from priming surfaces before they were mated. Surfaces were primed after assembly or not at all. These days, we seem to be encouraged to prime before assembly.
I guess this is all part of the educational aspects of homebuilding!
Cheers,
Dale
Flying Cessna 170B
Thruster87
PostPosted: Thu Aug 14, 2008 1:18 pm    Post subject: Re: Corrosion protection Reply with quote
I've heard that airplane manufacturers used to be (back in the 40s and 50s at least) prohibited from priming surfaces before they were mated. Surfaces were primed after assembly or not at all. These days, we seem to be encouraged to prime before assembly. I 'm part of an old farts club that restores vintage a/c like the C47 and most of the parts were primed prior to assembly.In the next hangar they are restoring warbirds like the P47 and they were primed.One interesting thing was the way they de-burred the parts by just using a sanding disc as you can still see the scratches [looks like 80-100 grit].Seems like they were in a hurry and it appears [they havn't come across any]they didn't develop any stress fractures due to this method of de-burring.
planecrazydld(at)yahoo.co
PostPosted: Thu Aug 14, 2008 2:11 pm    Post subject: Corrosion protection Reply with quote
just remember that they did not understand fatigue well until after the war in the beginning of the jet era. Also, the old transports and fighters were "throwaway" hardware with very short specification lives. I don't think I would allow a bad practice then to define/over ride todays understanding and evidence.
David L. Downey
Harleysville (SE) PA, USA
--- On Thu, 8/14/08, Thruster87 <alania(at)optusnet.com.au> wrote:
[quote]From: Thruster87 <alania(at)optusnet.com.au>
Date: Thursday, August 14, 2008, 5:18 PM
[quote]--> Zenith601-List message posted by: "Thruster87"
I 'm part of
appears [they havn't come across [quote][b]
Thruster87
PostPosted: Thu Aug 14, 2008 9:20 pm    Post subject: Re: Corrosion protection Reply with quote
Early 50's models of the de Havilland Comet suffered from catastrophic metal fatigue, causing a string of well-publicised accidents. As they found out how stress risers are a lot more critical on pressurized aircraft but do not under estimate there importance.
z601(at)anemicaardvark.co
PostPosted: Fri Aug 15, 2008 12:14 pm    Post subject: Corrosion protection Reply with quote
I could be mistaken, but I believe the metal fatigue in the case of the Comet
was due to a structural aerodynamic problem. That is, there was structural
resonance within the airframe. The additional energy imparted by the (then)
much higher airspeeds caused the resonance to surface, which in turn flexed
the metal, causing the fatigue, and ultimate failure.
Jim B. Belcher
BS, MS Physics, math, Computer Science
A&P/IA
Instrument Rated Pilot
General Radio Telephone Certificate
craig(at)craigandjean.com
PostPosted: Fri Aug 15, 2008 12:36 pm    Post subject: Corrosion protection Reply with quote
http://en.wikipedia.org/wiki/De_Havilland_Comet
"Engineers subjected an identical airframe, G-ALYU ("Yoke Uncle"), to
repeated re-pressurisation and over-pressurisation and after 3,057 flight
cycles (1,221 actual and 1,836 simulated), Yoke Uncle failed due to metal
fatigue near the front port-side escape hatch.[13] Investigators began
considering fatigue as the most likely cause of both accidents and initiated
further research into measurable strain on the skin. Stress around the
window corners was found to be much higher than expected, "probably over
40,000 psi," and stresses on the skin were generally more than previously
expected or tested. This was due to stress concentration, a consequence of
the window's square shape.
The problem was exacerbated by the punch rivet construction technique
employed. The windows had been engineered to be glued and riveted, but had
been punch riveted only. Unlike drill riveting, the imperfect nature of the
hole created by punch riveting may cause the start of fatigue cracks around
the rivet.
The principal investigator concluded, "In the light of known properties of
the aluminium alloy D.T.D. 546 or 746 of which the skin was made and in
accordance with the advice I received from my Assessors, I accept the
conclusion of RAE that this is a sufficient explanation of the failure of
the cabin skin of Yoke Uncle by fatigue after a small number, namely, 3,060
cycles of pressurisation."[14]
Before the Elba accident, G-ALYP had made 1,290 pressurised flights and at
the time of the Naples accident, and G-ALYY had made 900 pressurised
flights. Walker said he was not surprised by this, noting that the
difference was about 3 to 1 and previous experience with metal fatigue
suggested a total range of 9 to 1 between experiment and outcome in the
field could result in failure. Thus, if the tank test result was "typical,"
aircraft failures could be expected at anywhere from 1000 to 9000 cycles. By
then, the RAE had reconstructed about two-thirds of G-ALYP at Farnborough
and found fatigue crack growth from a rivet hole at the low-drag fiberglass
forward "window" around the Automatic Direction Finder, which had caused a
catastrophic breakup of the aircraft in high altitude flight."
-- Craig
PostPosted: Fri Aug 15, 2008 12:40 pm    Post subject: Corrosion protection Reply with quote
All of the data published since the mid 60s points to very specific fatigue critical geometry around the windows. Speed was not even involved, pressurization cycles were the specific cause identified in the failure of the fuselage surrounding the windows and escape hatches.
David L. Downey
--- On Fri, 8/15/08, Jim Belcher <z601(at)anemicaardvark.com> wrote:
[quote]From: Jim Belcher <z601(at)anemicaardvark.com>
Subject: Re: Re: Corrosion protection
Date: Friday, August 15, 2008, 4:16 PM
[quote]--> Zenith601-List message posted by: Jim Belcher
found
Jim B. Belcher
BS, MS Physics, math, Computer [quote][b]
Goto page 1, 2  Next
Page 1 of 2
