		keithmckinley
				 Posted: Wed Aug 13, 2008 8:04 pm    Post subject: CJ-6 oil thinning system |
				Can anyone give me the best method for disabling this system.
 Keith McKinley
		ChangDriver
				 Posted: Thu Aug 14, 2008 5:12 pm    Post subject: Re: CJ-6 oil thinning system |
				Keith:
 Isn't oil thinning activated by a switch?  Why not cut the wires or wire the switch in the off position.
 Craig
		wlannon(at)persona.ca Guest
				 Posted: Thu Aug 14, 2008 6:35 pm    Post subject: CJ-6 oil thinning system |
				Why not remove the entire system including wiring, cap off the fuel inlet at
 the pump "T" fitting and rivet or bolt a cover plate over the firewall hole.
 This leaves you an extra switch position, eliminates the possibility of a
 fuel leak in the solenoid valve and leaves only one fuel pressure hose to
 inspect or replace at annual.
 Walt
		keithmckinley
				 Posted: Thu Aug 14, 2008 7:41 pm    Post subject: Re: CJ-6 oil thinning system |
				little hesitant to disconnect or snip wires as something will still be live back there. I was thinking about yanking the solenoids during the next annual. has anyone actually done this mod?
 Keith
		pilko2(at)btinternet.com Guest
				 Posted: Fri Aug 15, 2008 1:27 am    Post subject: CJ-6 oil thinning system |
				Why take it out  at all ?
 You may never need it in your local climate but you may just one day sell
 your bird  to somebody in colder climes.
 Cheapest fix I can devise is a neat piece of duct tape over the switch !
		cjpilot710(at)aol.com Guest
				 Posted: Fri Aug 15, 2008 6:03 am    Post subject: CJ-6 oil thinning system |
				You can also use it for your smoke system.  I installed a a smoke oil  tank the same size as my old Chinese ADF and mounted it on the same rack.   I than used an old 24 volt fuel pump to pump the oil  from the tank to the  solenoid valve and hence to the exhaust stack.  I installed new switch near  the throttle, and hooked the solenoid in series with the pump.  Thus when I  close the switch the pump comes on and the valve opens.  Has worked fine  for about 1,500 now.
  Jim "Pappy" Goolsby
   In a message dated 8/14/2008 10:36:29 P.M. Eastern Daylight Time,  wlannon(at)persona.ca writes:
  [quote]-->    Yak-List message posted by: Walter Lannon    <wlannon(at)persona.ca>
 Walt
		keithmckinley
				 Posted: Fri Aug 15, 2008 6:06 am    Post subject: Re: CJ-6 oil thinning system |
				I live in a cold climate and I'd never use it. Prior to this winter I'll have a heater installed on my oil tank. Something the Chinese should have done.
 However, your point is a valid one.
 Keith
		keith(at)mckinley.us Guest
				 Posted: Fri Aug 15, 2008 6:16 am    Post subject: CJ-6 oil thinning system |
				good stuff!!
 K
 On Aug 15, 2008, at 9:58 AM, cjpilot710(at)aol.com (cjpilot710(at)aol.com) wrote:
 [quote]  You can also use it for your smoke system.  I installed a a smoke oil tank the same size as my old Chinese ADF and mounted it on the same rack.  I than used an old 24 volt fuel pump to pump the oil  from the tank to the solenoid valve and hence to the exhaust stack.  I installed new switch near the throttle, and hooked the solenoid in series with the pump.  Thus when I close the switch the pump comes on and the valve opens.  Has worked fine for about 1,500 now.
  Jim "Pappy" Goolsby
   In a message dated 8/14/2008 10:36:29 P.M. Eastern Daylight Time, wlannon(at)persona.ca (wlannon(at)persona.ca) writes:
				 Posted: Fri Aug 15, 2008 5:05 pm    Post subject: CJ-6 oil thinning system |
				Because it is a potential hazard from inadvertent operation or from a
 leaking solenoid valve.
 Disabling the switch will take care of the first. The second requires at
 least removal of the fuel feed hose.
 The need for oil dilution ended in virtually all climates with the advent of
 aviation multi-grade oils.
 It was a "necessary evil" in the "good old days" of bush flying in the
 Canadian North. The idea was borrowed from some of the truck operators and
 developed for aircraft use by a gentleman named Tommy Siers in 1928 who just
 happened to be my boss when I started with the airlines in 1951.  That
 earned Tommy the McKee Trophy in 1940 for outstanding contribution to
 Canadian aviation. By that time it had been incorporated into most of the
 larger military and civil aircraft worldwide.
 It served a useful purpose in those days but not without cost.  The sludge
 build up inside the engine and propellor dome became a major problem with
 later engines using 100/130 and 115/145 avgas due to the high lead (PB)
 content.  That was when the system was properly operated. When improperly
 operated the likely result was engine failure due to loss of lubrication.
 Walt
