Lubrication
jlfernan
PostPosted: Fri Aug 15, 2008 6:48 am    Post subject: Lubrication Reply with quote
Looked around but can't find an answer. Getting to the point where I'll be attaching big parts and have a question on lube. Which is the preferred type/brand for areas like the elevator pivots?
Jorge Fernandez
Supersport
Fuselage/Forward Controls
http://websites.expercraft.com/jlfernan/
Float Flyr
PostPosted: Fri Aug 15, 2008 5:31 pm    Post subject: Lubrication Reply with quote
I used to use a very light coating of light engine oil ( wipe off the excess ) when I worked on certified planes. Things like flap tracks on small Cessna aircraft was done with a very thin layer of high pressure grease... again all excess was wiped away so it wouldn't pick up dust. Most of the time when planes came in for their next scheduled maintenance there would be huge gobs of grease well impregnated with dirt on the flap tracks. It’s a wonder they ever worked.
My personal preference for my Kitfox pulleys etc is to use 3 in 1 for electric motors (Sewing machine oil?) it gives good lubrication, once the excess is wiped off it doesn't run and it doesn't seem to pick up too much dust.
I'm interested in what the rest of the people around here think on this topic.
Noel Loveys
Campbellton, NL, Canada
CDN AME intern, PP-Rec
C-FINB, Kitfox III-A
Aerocet 1100 floats
[url=noelloveys(at)yahoo.ca]noelloveys(at)yahoo.ca[/url]
 Filesize:  7.29 KB
 Viewed:  5297 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
hansedj
PostPosted: Fri Aug 15, 2008 7:24 pm    Post subject: Re: Lubrication Reply with quote
In the very back of our manual is where i found the recommended lubrications. It said lps-1 and tri flow. Tri flow you can pick up at bike shops.
Dj, Series 6
Rex Hefferan
PostPosted: Sat Aug 16, 2008 8:19 am    Post subject: Lubrication Reply with quote
I agree with Noel about minimal oil on the parts. There are lubes that
claim minimal dirt attraction. Often these are features of chain lubes
for bicycles or motorcycles. I have O-rings chain lubes which claim this
feature which I figure would work well on flap tracks. They are
formulated not to attack the rubber of the O-rings and the plastics used
as guides and guards around chain drives. I've also never seen chemical
damage to paint from these lubes flung onto painted parts. As DJ said,
LPS-1 and Tru Flow (which I believe he meant to write as Tri-Flow) are
great choices and I use them too. A good hardware or auto parts store
should have them also. The trouble with spray lubes are you usually
can't control the pressure well and it oversprays onto areas you don't
want oil on.
Rex Hefferan
SE Colorado / K-II / 582-C / still waiting repairs
too much dust.
this topic.
Sigtaturea
*Noel Loveys*
Aerocet 1100 floats
Rex
N740GP - M2/582
Colorado
