jmaynard
Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
Posted: Sat Aug 16, 2008 9:36 am Post subject: Crash |
On Sat, Aug 16, 2008 at 12:00:10PM -0500, Joe Scheibinger wrote:
| Quote: | Is it possible your shoulder may have hit the new canopy release lever the
factory put between the pilot and passenger?
I'm not going to speak for Jay, but I doubt it strongly. The location of the
latch lever, as well as its position when closed and locked, would make it
extremely difficult to open by bumping it with an elbow, much less a
shoulder. It takes a significant pull upwards on mine to unlatch the canopy.
| Quote: | Do you think the new canopy release lever should be moved to a different
location?
I can't think of another location for the latch lever on the inside that
would work any better without significant added complexity - which defeats
the purpose of the new style latch to begin with.
Jay Maynard, K5ZC http://www.conmicro.com
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC
_________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
hills(at)sunflower.com Guest
Posted: Sat Aug 16, 2008 11:08 am Post subject: Crash |
I have a 601 with the side opening canopy, and mine popped open during run
up on the ground, so I added slide locks to keep the latch from pulling away
from the canopy. After this story, I'm glad I did.
I would expect an open canopy to greatly, disturb the airflow to the tail,
perhaps even block it. The added drag would of course be tremendous,
staying in the air would probably depend a lot on the engine
installed and prop used.
Roger
Posted: Sat Aug 16, 2008 11:12 am Post subject: Crash |
Howdy all
When the prop broke off my 601 HDS, I did give me one advantage, without the
drag of the prop, the thing glided really well even into a head wind. In
fact, I probably set some kind of 601 glide record. (9 miles from 6000 ft
AGL)
(Every cloud has it's silver lining, yes?)
Roger
bryanmmartin
Posted: Sat Aug 16, 2008 1:24 pm Post subject: Crash |
I took a look at the new latching system on the 650 at Oshkosh and it
occurs to me that, with both latches directly connected together
through the torque tube, any attempt to re-latch one side would push
both latches farther out of engagement and probably cause both sides
to come unlatched. I'm guessing that's what happened in this case. At
least with the old system, attempting to re-latch one side isn't
likely to cause the other side to come unlatched since they latch
independently of each other. I think I like the old system better.
This incident should be a strong warning that no attempt should be
made to re-latch the canopy in flight if it has the new design
latching system. I'm glad it turned out as well as it did, it could
have been far worse.
On Aug 16, 2008, at 11:05 AM, Jay Maynard wrote:
I'm at a loss to explain how one side could be unlatched. I've tried
in my
airplane to latch just one side and not engage the hook on the bolt
on the
other, and just wasn't able to without it being obvious there was a
problem.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
_________________ --
Bryan Martin
do not archive. |
sdthatcher
Joined: 13 Mar 2008 Posts: 91 Location: Port Saint Lucie
Posted: Sat Aug 16, 2008 6:31 pm Post subject: Crash |
Hi Jay,
I'm real glad to hear you made it down safely with as few bumps and bruises
as you reported. That sounds like it could have gone real bad quickly. I
totaled an Aeronca Chief one time and it's amazing how quickly they come to
a stop yet how much you remember while it's happening! It looks like a
credit to the airframe and overall structure that it held together during
the impact.
BTW, I was wrong about the openings in the cowl... they are 4-7/8", not
3-7/8". I did have a leak in the Baffles that caused some of the cooling
air to miss the cylinder area but was fixed the next time I replaced the
cowling.
Hope you and your instructor recover quickly. I know I'm now going to make
a note to check the latches a lot more carefully now. I have a strap but I
have left it loose for the same reason as Larry... it was meant to keep the
canopy from flying open and slamming against the top forward skin. I think
I'll tighten it up before the flight just to be sure. I have a quick
disconnect if needed.
Scott Thatcher, Palm Beach Gardens, FL
601XL with WW Corvair, Registered as E-LSA
N601EL, http://placestofly.com, http://eaa203.com,
http://mykitlog.com/sdthatcher
Webmaster: http://zenvair.com
Time: 03:29:41 PM PST US
Subject: Crash
OK, a few facts from the horses mouth:
As most of you know, I have just completed a Zodiac CH 601XL (Lil
Bruiser). Both me and the insurance company wanted me to get at least
an hour in make and model before I solo my airplane. I discovered a new
service at McKinney Airport (TKI), for training and rental in a 601XLi.
This was a familiarization flight in a nearly new AMD built 601XLi.
The airplane originally had the old style canopy latches. The owner
was not satisfied with that mechanism and had the factory retrofit the
new style latches. The owner, Dennis Levy, who is also CFII. was in the
right seat, me in the left. We had gone through all the standard
maneuvers and were straight and level. I noticed that the right hand
canopy latch had come loose and the rail was up about 2 inches. I
pointed it out to Dennis. We were in sight of a private airfield, but
Dennis decided he was going to re-latch it - in the air! In doing so,
the latch on my side came loose and the canopy immediately shot up to
about 50 deg., and the nose went down about 60 deg. I immediately
pulled the power completely off. We both grabbed what we could on the
canopy but could only pull it down to about 30 deg. We both pulled
back on the sticks, with all our might, but never got the nose up to
level. I steered toward an open, plowed field. We hit the ground at
about 10 deg nose down and stopped immediately. No fire. The canopy
did not depart the airframe. Dennis was air lifted to Baylor Hospital
in Dallas. I was taken to the trauma suite at the Presbyterian
Hospital in Greenville. X-rays and CAT scans showed nothing out of
place or broken. I have a badly sprained right foot and ankle, a
bruised rib cage and lots of cuts and bruises on my arms. I also have
a slight vision problem. In pain, but still OK.
It is important to note that this had nothing to do with wings, but
with a new and improved canopy latching system.
Consequently, I am STRONGLY recommending that any 601 have a fail-safe
strap to the rear canopy bow, regardless of the latching system, to
keep this from ever happening again.
Alive and still with you - Jay
Bannister________________________________________________________________
_________________ Scott Thatcher, Port Saint Lucie, FL
601XL with Corvair, Registered as E-LSA
N601EL, EAA203 140 hours and not flying currently. |
s.clive.richards(at)homec Guest
Posted: Sun Aug 17, 2008 10:58 am Post subject: Crash |
Jay glad you are both ok
We have latches as designed by the Late Ed Walanda
which are spring loaded in a similar position to the new latches & easily
visible so reclosing the canopy would not affect the latched side I believe
the new latches are connected by a ridged bar will pulling the canopy closed
not actually release the latched side ?. We must admit to actually leaving
one side unlatched once having reopened the canopy & being distracted not
rechecking but were able to reclose on reaching circuit height & reducing
power. I wonder however how much the Gas strut pressure will affect the
ability to reclose, ours at the time had lost pressure & we have just
replaced. so will think out your idea to fit a safety strap.
Clive
Rays 601HD 233 Hrs 701 kit on order
ZodiacGermany
Posted: Fri Aug 22, 2008 6:12 am Post subject: Re: Crash |
I visited the Zenith booth at Oshkosh and was impressed with the 650 and new latch. I will for sure update to new canopy and latch. From what I gather, the latch is much over designed. The bar connecting the two latches is very tougher. it seems that Zenith put a lot of thought into this.
As to the Dennis crash, I cannot understand for life of me why anyone would want to open the canopy when aircraft was flying fine. That is quite unbelievable. Thank god that they landed without more damage. I just cannot understand what pilot was thinking. Open the canopy in any fast aircraft and you will be in trouble I think. There have been accidents in Germany with other type aircraft with canopy opening. However, I have never heard of anyone purposely opening the canopy in flight. Unbelievable.
One thing that I find good is that Jay stated that his side of the canopy was open about 2 inches. This is good to know because if I forget to latch one side of my canopy properly, I can reassured that the other side will not open. I do not know if I can say that with my present canopy latch system that was built by Czech company. I hear reports of other Zodiac aircraft in Europe flying very well with canopy open. It sees that its all about flying speed slow and focusing on the flying. Not trying to close canopy and forgetting how to fly. Unbelievable.
Again, thank God that accident was not worse.
