patrick.pulis(at)seagas.c Guest
Posted: Sun Aug 17, 2008 5:39 pm Post subject: Fuel Tank Earthing Point |
Posted: Sun Aug 17, 2008 7:25 pm Post subject: Fuel Tank Earthing Point |
Could anyone please tell me if they have installed (or are planning to
install) an earthing point on their wing tanks next to the cap, to
enable earthing of the fuel nozzle prior to commencing refuelling?
PATRICK PULIS
RV-10 #40299
Adelaide, South Australia
Email: patrick.pulis(at)seagas.com.au
ricksked(at)embarqmail.co Guest
Posted: Mon Aug 18, 2008 4:46 am Post subject: Fuel Tank Earthing Point |
I'm not, the fuel trucks use a clamp to bond the truck to the aircraft, I haven't seen any grounding points in the ramps except on military installations but then I really haven't looked that hard for them. If there were ramp grounding points then the trucks would be using a triangle grounding method, truck to ground, aircraft to ground, truck to aircraft. Which they may...self serve for me...nozzel bonds to the tank just like your car, through the metal on the nozzel.
Rick Sked
40185
bob.kaufmann(at)cox.net Guest
Posted: Mon Aug 18, 2008 4:59 am Post subject: Fuel Tank Earthing Point |
I just ground to the exhaust pipe with the grounding wire if fueling from truck.
Bob Kaufmann
40125
Kellym
Posted: Mon Aug 18, 2008 5:44 am Post subject: Fuel Tank Earthing Point |
I could be wrong, but it seems to me that the exhaust pipe is oxidized
and exhaust coated stainless steel(not near the top of the list of
conductors), connected through joints in the same condition to the
engine exhaust ports with a gasket to the cylinders, to the crankcase,
and then to your main ground point. My point being that sparks tend to
take the shortest path. I prefer to ground to my wing tiedown point,
which is attached to the spar that is part of my fuel tank. Maybe it
makes no difference, maybe it does. I've seen a lot of starting problems
that involved poor ground connections to the engine. Your mileage may vary.
Kelly
Bob Kaufmann
40125
KCHD |
