Roger Lee
Posted: Sat Aug 16, 2008 8:51 am Post subject: carb ice revisited |
Hi Guys,
FYI
I know I had a hard time convincing some that the Rotax 912's with the altitude compensating variable-venturi carbs are not susceptible to carb ice.
Here is a quote from "Aircraft Powerplants" by Bent/McKinley a recognized text approved by the FAA. (Light reading when I have nothing better to do. )
" The variable-venturi and pressure injection carburetors are relatively free from carburetor carb icing troubles."
This is the big difference that pilots have to come to understand when they come from GA aviation that have a standard carb verses a variable-venturi carb. A few authors I have read recently would like to hear from anyone that has had a documented carb icing with these carbs. Fixed venturi carbs are far more susceptible to icing.
That said a doctor teaching me a class once said, "Never say Never".
So, if you want to spend the money for a fix for the the improbable carb ice issue you can buy one of two types. These are heated rings that go between the carb and the intake mount. One is an electrically heated ring. The other is hooked into your hot water/coolant and circulates through the ring. The water one is better as it does not put a hit on your electrical system.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
imap8ntr(at)cox.net Guest
Posted: Sat Aug 16, 2008 9:30 am Post subject: carb ice revisited |
Roger
One day when I did my run up on the ground, I got a progressive drop of
over 150 in RPM at idle. I repeated this twice. I figured that after a
long taxi at low throttle set me up for carb ice. I turned on the carb heat
and the rpm soon went back to normal. Waited about 10 seconds or so and
turned off the carb heat again and again the idle dropped. I turned on the
carb heat again for about 20 sec or so and then turned off the heat. The
idle then remained steady at the proper idle rpm. Had no further
occurrances that day.
I also had the above scenario occur one other day and the heat worked like a
charm.
Ivan
Phoenix, AZ
JimT
Posted: Sat Aug 16, 2008 5:23 pm Post subject: carb ice revisited |
OKay , a very timely post. Is there any data that the electric ones work. One only draw 1.5 amps per carb.
http://www.ulparts.com/SearchResult.aspx?CategoryID=94
Another is listed from ireland, http://www.xairireland.com/access-h.htm#carbheat
I am ready to buy some kind of carb heat for my searey project with a 912s, but would love a little guidance.
Jim Timoney
Roger Lee
Posted: Sat Aug 16, 2008 6:52 pm Post subject: Re: carb ice revisited |
Hi Tim,
Good question. The electric ones do work, but you still have the amp draw and managing the wires and making sure it is always working. The coolant hot water are better and more consistent and easier to manage over time. You can buy them through CPS.
Tucson, Az.
Cell 520-349-7056 |
Thom Riddle
Posted: Sun Aug 17, 2008 3:32 am Post subject: Re: carb ice revisited |
Roger,
In the nearly three years we've operated our Allegro 2000 w/ 912UL, I've had carb ice develop twice in flight. Both times it was at normal cruise power around 5,000 rpm on warm humid days. Noticing it quickly, it is easy enough to clear by cycling the throttle open/close a couple of times. If you don't notice it quickly and don't clear it out, it can build up pretty fast and lead to serious loss of power.
It is not a bad idea to install carb heat but we chose not to do so... yet.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
peteohms
Posted: Mon Aug 18, 2008 9:12 am Post subject: carb ice revisited |
Roger,
My 912 does the same thing every time I do my run-up on the first flight of
the day. I really don't think it is ice. I think because the carb heat
bypasses the air filter that the carbs are getting more air. If I run the
engine at 3500 rpm for a half minute the problem clears up.
Pete
Hell Paso, TX
_________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
Posted: Mon Aug 18, 2008 12:51 pm Post subject: carb ice revisited |
Roger, Pete
Also to consider is the fact that my carb is an altitude compensating carb.
Because of that there is normally no drop in RPM when turning on carb heat
in the absence of ice. The two times presumable ice occurred was on a medium
temp day, humid, at low throttle setting. If that is not a set up for
carb icing I dont know what is.
Ivan
peteohms
Posted: Mon Aug 18, 2008 2:11 pm Post subject: carb ice revisited |
Ivan ,
Well, every day is humid here lately. Guess you could be right. It never
happens after the engine gets good and warm.
Pete
Hell Paso, TX
Kitfox III, sn 1000, 912, Grove
Leander, TX
Posted: Mon Aug 18, 2008 4:03 pm Post subject: carb ice revisited |
That venturi in the carb can get pretty cool with evaporation of the fuel
inlet and it would not take that much to close off the opening. I would not
think that Rotax would have carb heat if it was not necessary or useful. In
my flying if I suffer a power loss I would definitely try carb heat. I
never had the problem during the warm weather in AZ. I can remember that
the day it happened it had been foggy, 100% humidity and expected the carb
ice. When I did my run up and the RPM dropped for the first time ever, I
just said OH there it is. I did recheck doing the run up twice to make sure
it did not ice up again and all was ok. I was especially vigillant on my
final.
Just to make sure I have the Bing Altitude compensating carburetor.
Ivan
avid2008
Posted: Fri Sep 19, 2008 12:09 pm Post subject: Re: carb ice revisited |
Roger, I have always been told that R912 is pretty much ice-proof. Last winter I discovered the contrary although it must be said in all fairness that conditions were prone to icing.
I purchaised a Rotax 912 powered Avid Flyer and was ferrying it accross Europe in the company of the previous owner. It was around 0°C and very humid; the guy was running it at 4500rpm. After about 20min of flight I noticed that revs were around 4200 and quite uneven; I pushed in some more throttle with no effect, then after some 30-60secs suddenly revs came up to 5000. We kept it at 4800-5000 for the rest of the day( 6hrs/2 landings) without any further problem.
The next day the valley where we stopped for the night was filled with stratus and occasionally there were some drops of rain. Hardly a VFR type of weather but we decided to try to take off. While warming up the engine I noticed that it was running VERY rough - I couldn't check above 3500rpm as the brakes were not strong enough to hold the plane, but anything below 3500rpm was very uneven. Not being certain if there is everything OK with the engine and having marginal weather we decided to postpone the takeoff.
Next day I called a local FBO mechanic (I had to go back home by train) and asked him to check the engine. The weather was fine and he didn't have any problem.
I feel very strongly we must have experienced carb icing.
I did 70hrs with this plane since that day and I must say that on a couple of occasions I had a suspicion of icing (not as apparent as described above, but a slight irregularity below 4000rpm) in humid conditions. Adding power has always improved the situation.
I must say that the Avid Flyer has huge air intakes on both sides of the prop, so presumably there is no wam air stagnating under the cowl (as it is frequently the case of modern planes with sleek cowlings). Warmer air in the carb area can probably help, although it is not a 100% solution (FAA wants to see, if memory serves me well, at least 70F air temp increase to be considered as an efficient carb heat).
Martin
Roger Lee
Posted: Fri Sep 19, 2008 4:47 pm Post subject: Re: carb ice revisited |
Hi Guys,
Please don't take my next comment as being a smart ass, but how do you guys know if it was really icing without any confirmation and have you ruled out all other possibilities? Without confirmation it still is speculation. These are not standard carbs like the ones we were raised with during our life, but quite different. These are variable venturi carbs. That in itself makes them less prone to standard icing effects.
Tucson, Az.
Cell 520-349-7056 |
Thom Riddle
Posted: Sat Sep 20, 2008 3:21 am Post subject: Re: carb ice revisited |
Roger,
You are not a smart ass. You just live in a place where 50% humidity seems like a steam bath. Back east, where we have enough rain to allow trees to grow, 50% humidity seems down right arid.
I've been flying since 1966 and I know the symptoms of carb ice. That is how I know I've had it. It is true that the Bing carbs are LESS LIKELY to ice up but they can and do under high humidity conditions. I've had it happen to me on two separate occasions, both of which were in conditions highly conducive to carb ice. Although it is rare enough that I don't bother with a carb heat system, it does happen here in the land of "normal" humidity .
Buffalo, NY (9G0)
- Anonymous |
Roger Lee
Posted: Sat Sep 20, 2008 6:39 am Post subject: Re: carb ice revisited |
Hi Thom,
If you ever make it down to the Tucson, Az. area give me a call. I'll be happy to take you and whom ever up in my Flight Design CT for a flight around the area in some of that dry air.
I have a friend that lives in New York that I'm sure he would be happy to take you for a cruise in his CT.
Invites good any time.
Tucson, Az.
Cell 520-349-7056 |
Thom Riddle
Posted: Sat Sep 20, 2008 12:17 pm Post subject: Re: carb ice revisited |
Thanks for the offer, Roger. If I get down your way again, I'll look you up.
Buffalo, NY (9G0)
- Anonymous |
Float Flyr
Posted: Sat Sep 20, 2008 1:28 pm Post subject: carb ice revisited |
So true. But sho0rt of landing immediately and pulling off the air screens
there is no other way to verify ice in the carb other than through symptoms.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
avid2008
Posted: Sat Sep 20, 2008 11:45 pm Post subject: Re: carb ice revisited |
Roger, the reason I related the circumstances of my trouble(s) was to let you guys estimate if it was or if it wasn't carb icing. I don't see what else it could have been.
your statement that Bing carb is ice-proof is also a speculation without confirmation, it works both ways.
Martin
