Michel
Posted: Sat Aug 23, 2008 7:48 am Post subject: "Heavy" wing on Series 7 |
| Quote: | From: FlyboyTR [flyboytr(at)bellsouth.net]
Shortening or "turning in" the left rear will increase the wash out on the left wing
and create more lift on that side.
My understanding is that "Increasing the wash-out" means: make the AoA at the tip of the wing lesser than at the root thus ensuring that the root stalls before the tip. Hence ... reducing the lift on that side, right?
Cheers,
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200 ... grounded.
Lynn Matteson
Posted: Sat Aug 23, 2008 8:51 am Post subject: "Heavy" wing on Series 7 |
Remember when you guys added that little 1/2"(or more) block of wood
under the rear of the wing when you built them? That was to build in
washout, so I can't see how pulling on the front of the strut will
decrease the washout, rather it seems to me that shortening the front
spar (screwing the rod-end in) will INCREASE washout.....doesn't it?
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200, 562 hrs and holding for repairs
Status: "Condition grounded, but determined to try." (Pink
Floyd..."Learning to Fly")
On Aug 23, 2008, at 9:18 AM, FlyboyTR wrote:
darinh wrote:
> I think a turn or so in on the right front strut will to the
> trick. As John stated, it is better to increase wash-out than
> wash-in. Thanks for all the input.
Darin,
Unless my mind is a little twisted this morning, "turning in" the
right front will decrease the wash out in the right wing.
on the left wing and create more lift on that side.
Travis
Travis Rayner
Mobile, AL
Skystar Vixen, N-789DF
Continental IO-240, Prince P-Tip Prop
ADI-II Autopilot
AnyWhereMap Navigation with weather
http://forums.matronics.com/viewtopic.php?p 0070#200070
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
propellerdesign(at)tele2. Guest
Posted: Sat Aug 23, 2008 10:14 am Post subject: "Heavy" wing on Series 7 |
Right on!
Jan
RockyRim
Joined: 12 Sep 2006 Posts: 15 Location: Austin, Texas
Posted: Sat Aug 23, 2008 11:18 am Post subject: Re: "Heavy" wing on series 7 |
Hey Darin,
I had a heavy left wing on my Series 7 when I began flight testing. I'll skip a lot of what I did and go right to what the fix was.
I pulled the tips,and re-checked the washout with the "smart level".
As good as I thought I had it at set up, it was in a garage, and it needed just a hair for perfect.
And then a hair more for exactly level flight, hands off.
If you don't have a smart level, find one. If you can't find one, I'll loan you mine.
Good Luck,
Denise and Rocky Whitman
co-builders and pilots
Series 7 912S
darinh
Posted: Sat Aug 23, 2008 11:19 am Post subject: Re: |
Travis,
I may be wrong but the way I understand it is wash-out is a slight twist in the wing that essentially decreases the angle of incedence of the wing as you move from the root to the tip. This is to allow a stall to originate at the root and travel to the tip thus keeping the outward section of the wing flying at lower speeds. So, to adjust a wing strut for more washout, you would either turn in the front rod bearing (pulling the LE down) or turn out the rear rod bearings (raising the TE).
Basically wash-out in a wing places the outboard trailing edge slightly higher than the outboard leading edge in respect to the LE and TE at the root of the wing. Man, I have never tried to put that in words before and it is a bit difficult to explain.
Here it is in the word or Roy Vaillancourt (World famous RC modeler and kit designer):
Washout works like this: If a wing panel is twisted so that the trailing edge of the tip rib is slightly higher then the trailing edge of the root rib this will in effect reduce the angle of attack of the tip ribs. If this twist is gradual from the root of the panel to the tip each rib in this panel will progressively have a reduced angle of attack. This means that in flight as the airflow approaches the tip of the wing the tip ribs will stall later then the ribs closer to the root. This is good, as this will prevent "tip stall" at slower speeds when the angle of attack is generally higher then normal flight. This will help prevent the plane from snap rolling when you least want it. Like on landing approaches and slow fly-bys.
I think that is essentially what I said, just not so nicely. Let me know if I am in error here.
_________________ Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah |
darinh
Posted: Sat Aug 23, 2008 11:24 am Post subject: Re: |
Michel,
That is the way I understand it also. You did a much, much better job than I explaining it though....Are you sure English is not your first language?
Rocky,
I do have a smart level...but thanks for the offer to borrow yours. I am going out tonight to do exactly what you recommend. My roll is so slight I suspect it will only take a half to 1 turn to remedy it.
Series 7
914 Turbo
Kaysville, Utah
Fox5flyer Guest
Posted: Sat Aug 23, 2008 3:58 pm Post subject: "Heavy" wing on Series 7 |
Sounds pretty good to me. Well stated.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 393+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
FlyboyTR
Joined: 04 Nov 2006 Posts: 215 Location: Mobile, Alabama
Posted: Sat Aug 23, 2008 6:48 pm Post subject: Re: |
Well....??? The sad thing is I know what wash out is and what it does! I just had this reverse image in my mind. Thanks guys I stand corrected. Yep...Wash out is up!...so the wing tips will stall last.
If ya'll will excuse me...I will now slink away and have my crow for dinner...always best served cold with a glass of vinegar!
Thanks again for correcting me...sincerely appreciated.
Travis
PS...and that was a great explanation of the facts!
_________________ Travis Rayner
Mobile, AL
ADI-II Autopilot
www.enotam.net (My Flying Info Website) |
Michel
Posted: Sat Aug 23, 2008 11:46 pm Post subject: "Heavy" wing on Series 7 |
| Quote: | From: darinh [gerns25(at)netscape.net]
explaining it though....Are you sure English is not your first language? [Wink]
Darin, you make me blush so much that my new pacemaker stands out like a white spot on my chest!
I went flying as a passenger with my son, yesterday. Again I tested carefuly the plane: slight pressure on the right pedal to keep the ball in the center, level flight and cruise speed. Release the stick ... the plane slowly moves nose up and bank right.
The thing is: the measured angles at root and tip are exactly symmetrical and I am not sure it would be wise to change the wash-out. As I wrote earlier, I had a small tab bent down on the root of the left flaperon and it helped but ... I lost it. I am thinking to put a new one but ... nobody commented that practice so, ... do you have any other suggestion, guys? Should I try a tab on the rudder instead?
The thing is; this is only a tiny problem when I fly alone (whenever or if I get back my license!) and I want for example open a bottle of water using both hands. Previously I pressed the stick with my right leg but it would feel better if I could fly hands free for a short while.
Cheers,
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200 ... official passenger.
Lynn Matteson
Posted: Sun Aug 24, 2008 5:46 am Post subject: "Heavy" wing on Series 7 |
Do you have *any* form of elevator trim control? Either a ground-
bendable mechanical trim tab or servo-controlled trim tab? That would
be a way to control the nose up movement, and a similar trim tab on
the rudder would allow you to control the right banking tendency. If
you have both of those, you'll be able to pull a cork from a bottle
of wine with both hands AND cut the cheese as well. : ) (I'd wait
until on the ground before consuming any of the wine, however)
The way I understand it, the ground-adjustable trim tabs only work at
a specific airspeed...any faster or slower (within reason) than what
you have set if for, and it doesn't correct as much, or it corrects
too much....nothing very radical, just slight.
I can fly my plane hands off for several minutes at a time after
setting the elevator trim (electric) if the wind isn't too great.
Lynn Matteson
Kitfox IV Speedster
On Aug 24, 2008, at 3:45 AM, Michel Verheughe wrote:
| Quote: | > From: darinh [gerns25(at)netscape.net]
> job than
> language? [Wink]
instead?
Cheers,
Michel Verheughe
Norway
List">http://www.matronics.com/Navigator?Kitfox-List</a>
forums.matronics.com</a>
www.matronics.com/contribution</a>
</b></font></pre>
N369LM |
dan(at)azshowersolutions. Guest
Posted: Sun Aug 24, 2008 5:53 am Post subject: "Heavy" wing on Series 7 |
Again I tested
the center
MIchel, Sounds like a yaw problem...try the rudder tab.
Dan B
Michel
Posted: Sun Aug 24, 2008 10:34 am Post subject: "Heavy" wing on Series 7 |
Hello Lynn and Dan,
Well, I don't have any elevator trim but I trim pitch with the flaps handle whenever I feel for it. The plane is balanced to climb at full throttle and sink at idle. With the flaps handle, I can get it to fly level at cruise speed.
If I use the flap and keep level, whenever I free the stick, it still turns slightly right.
The need for right pedal is, I think, normal due to the propeller's torque. I need a substential push when I take off and can release it entirely on a descent at idle.
So far, I think the plane is well balanced as it is. If I put a tab on the elevator, ... I risk to have problem to do a three-points landing since that's the reason I never land with flaps on. If I put a tab on the rudder ... I risk to need left pedal when idling down a descent. My last idea is then to put a corrective tab to the flaperon. Doesn't it make sense?
Cheers,
Michel Verheughe
Norway
Posted: Sun Aug 24, 2008 12:05 pm Post subject: "Heavy" wing on Series 7 |
(The need for right pedal is, I think, normal due to the propeller's
torque.)
You are correct when on climbout (P-factor)...but if you need to keep your right foot in it in straight and level flight, then in my opinion, the rudder tab could help with the yaw. As for your pitch problem, I'm not familiar enough with the model 7 to help. On my IV I have 3 vertical attachment points for the leading edge of the HZ Stab. I might take a look at.
Dan B
Mesa, AZ
KF-IV 912s building
[quote] [b]
