Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27562 Location: Livermore CA USA
Posted: Sat Aug 23, 2008 3:53 pm Post subject: Elevator Skin Trailing Edge Bowing... |
Dear Listers,
Backing into the garage today I noticed the elevator skin bowing at
the trailing edge in the review mirror because of the way the light
was hitting it. Basically what the deal is I think is that I bent
the trailing edge of the elevators more than necessary. So, when I
pulled the leading edge apart to fit it over the spar, I now have a
concave bowing effect between some of the bays. Van's goes to great
lengths in the manual to make sure that bend the elevator trailing
edges *enough*, but doesn't make mention of what is "too much". The
radius of the trailing edge is still within spec and there is no
cracking or stress marks. Its just bent too much and looks like of
stupid. Somehow, I did the rudder perfectly, but both elevators
suffer from the effect. I've included some pictures below.
What the common thought on this issue? Are the safety/flutter issues
with over-bending as I have done? What to do...?
Thanks!
RV-8 #82880
RV-8 Fuse/Wing QB Kit Delivery Next Week! (Ordered May 20 2008)
92.39 KB |
303 Time(s) |
88.98 KB |
324 Time(s) |
75.74 KB |
350 Time(s) |
_________________ Matt Dralle
nukeflyboy
Joined: 05 Jan 2008 Posts: 162 Location: Granbury, TX
Posted: Sun Aug 24, 2008 3:12 am Post subject: Re: Elevator Skin Trailing Edge Bowing... |
Matt,
On the RV-10, the elevator is a 3-piece rivited trailing edge. I am not that familiar with the RV-8 but it looks like my RV-6. I have never heard of any flutter issues on the elevator due to this condition and your problem appears to be primarily esthetic. Bending the trailing edges is always a little tricky and on the ailerons, too little (or too much) can cause one wing to be "heavy". Van talks about this in the manual and you can correct the heavy wing by pinching the trailing edge, ie, make the radius smaller. The slight bowing on the skin is also of no concern, and under flight loads the skins will do this regardless.
Since your radius is within spec, I don't see a safety issue here. The only problem is is whether or not you can live with it.
_________________ Dave Moore
RV-6 built and sold
RV-10 built and flying |
wcurtis(at)nerv10.com Guest
Posted: Sun Aug 24, 2008 7:20 am Post subject: Elevator Skin Trailing Edge Bowing... |
Yeah, this happened to my first trim tabs. Fortunately, or un, the trim tab is the only flying surface of the -10 that uses this construction technique. Us 9 & 10 builders have the AEX extrusion and Proseal to contend with for our flying surfaces with their own "got ya's." With the trim tabs, I created a brake from 2X4 to provide a more continuous mold while curing than the V brackets called for in the plans.
William
http://nerv10.com/wcurtis/
