pjdisher(at)bigpond.com Guest
Posted: Mon Aug 25, 2008 12:17 am Post subject: CHT probe - 2 pictures for you |
Hi Ron Shannon,
What I did Ron was use the hole in-between the two spark plugs to place a 10/32 screw.
I then drilled a hole 1/8 to slide the probe into, then fasterened it with the screw.
I called Jabiru here in OZ and they said the hole can be used for this purpose or was some time ago.
The reason I went this way was that the ring dia. for the sparkplug is too large and did not fit good in my opinion only.
I did need to remove the rings carefully from the leads which went well and they do record well also.
Pictures attached.
Pete Disher
kit 30
VH-PDI
OZ
You have been sent 2 pictures.
These pictures were sent with Picasa, from Google.
Try it out here: http://picasa.google.com/
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
46.41 KB |
574 Time(s) |
46.74 KB |
603 Time(s) |
Clive J
Posted: Mon Aug 25, 2008 12:51 am Post subject: CHT probe - 2 pictures for you |
Another good idea Pete, I'm assuming the end of the T/C is what you find when you cut it out the crimp? Do you do anything to it?
CJ
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of Peter and Jan Disher
Sent: 25 August 2008 09:15
To: jabiruengine-list(at)matronics.com
Subject: CHT probe - 2 pictures for you
Hi Ron Shannon,
Pictures attached.
Pete Disher
kit 30
VH-PDI
OZ
Posted: Mon Aug 25, 2008 1:34 am Post subject: CHT probe - 2 pictures for you |
No CJ. I just take the ring off the wire and there it is the pair joined as they should be. I then poke the pair of wires it inio the hole that I drilled to the depth where the screw will pick it up and hold it in position, done job, too easy.
Pete D
