stein(at)steinair.com Guest
Posted: Tue Aug 26, 2008 2:32 pm Post subject: Rudder Pedal Measurements Needed |
<![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]> Hi All,
I'm wondering if one of you builders can do me a quick favor. I'm in need of the following measurements for the RV-10 Rudder pedals.
1) Overall width of the main upper bars from outside to outside.
2) Height/length that the pedals hand down from the main bars. Not the physical pedal itself, but the measurement of the actual tubing. Basically from the upper main tubes to the bottom of the smaller tubes that make up the rectangular mount for the pedals.
Overall I need to know the sizes as if one were going to possibly consider mounting these things in a plane. Need to know width and height!
Thanks a bunch,
Stein
Do Not Archive - it's useless to anyone else....
toaster73(at)embarqmail.c Guest
Posted: Tue Aug 26, 2008 3:58 pm Post subject: Rudder Pedal Measurements Needed |
<![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]> I get from top of tube to rudder pedal bottom tube 11 3/8 inch this outside of tube measurement not center to center or anything.
Then 41 1/8 inch over all tube length
-Chris Lucas
#40072 (pedal assembly sitting next to computer)
