numskull99(at)netzero.net Guest
Posted: Tue Aug 26, 2008 3:34 pm Post subject: Rattle Can Primers |
I have seen that several people are using NAPA 7220 self etching primer, and I started using it. But NAPA is 20 min farther than several other hardware stores. Has anyone used any other rattle can primers? If so, How has it worked? Also is 6061-t6 considered galvanized?
Derek Lewis
DO NOT ARCHIVE!
____________________________________________________________
Click here to find Medical Transcription Training programs.
http://thirdpartyoffers.netzero.net/TGL2231/fc/Ioyw6ijmaKOPGCngAHYgMQAl3YoUZ0lM0XctRCZsA9Vc9n27dqrOjw/
Posted: Tue Aug 26, 2008 3:58 pm Post subject: Rattle Can Primers |
Derek,
6061-T6 is just aluminum, really corrosion resistant as aluminums go,
but still no etch or plating.
Suggest you continue with the self etch primer if it seems to work for you.
Derek Lewis wrote:
Derek Lewis
DO NOT ARCHIVE!
psm(at)att.net Guest
Posted: Tue Aug 26, 2008 4:46 pm Post subject: Rattle Can Primers |
Hi Derek,
Self etch primers contain acid to eat through the aluminum oxide that
forms almost instantly on pure aluminum. This oxide is impossible
for paint to stick to. There are several different approaches to
deal with this and the self etch primer is ideal (in my opinion) when
you are doing small areas at a time.
I don't think it is possible to galvanize aluminum. This is a
process used primarily on steel. A pure zinc coating is placed on
the steel to prevent rust. To my knowledge there is no way to
successfully paint the zinc and it is nearly impossible to
remove. It also causes great difficulties for welders.
Good luck,
Paul
XL getting close
At 04:32 PM 8/26/2008, you wrote:
| Quote: | I have seen that several people are using NAPA 7220 self etching
Derek Lewis
leinad
Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
Posted: Tue Aug 26, 2008 5:09 pm Post subject: Re: Rattle Can Primers |
Derek,
I've been using Dupli-Color self etching primer. It sticks great to the aluminum. I first scuff it with a little scotch bright, and wash it well with a solvent to remove any residue and sharpee marks. I spray it outside with a dust mask. You can find this stuff almost anywhere that sells spray paint in rattle cans.
Dan
ch601xl/corvair plans builder
| numskull99(at)netzero.net wrote: | I have seen that several people are using NAPA 7220 self etching primer, and I started using it. But NAPA is 20 min farther than several other hardware stores. Has anyone used any other rattle can primers? If so, How has it worked? Also is 6061-t6 considered galvanized?
Derek Lewis
DO NOT ARCHIVE!
http://thirdpartyoffers.netzero.net/TGL2231/fc/Ioyw6ijmaKOPGCngAHYgMQAl3YoUZ0lM0XctRCZsA9Vc9n27dqrOjw/ |
_________________ Scratch building XL with Corvair Engine |
professor71(at)HOTMAIL.CO Guest
Posted: Tue Aug 26, 2008 6:03 pm Post subject: Rattle Can Primers |
.hmmessage P{margin:0px;padding:0px}body.hmmessage{FONT-SIZE: 10pt;FONT-FAMILY:Tahoma}Derek
I used rust-oleum primer and paint rattle cans for the whole plane. It is still on after 3.5 years. I did do what Dan did as far as scuffing the surface and washing it down with lacquer thinner before priming. Everyone that has seen the plane cannot believe I did the plane with rattle cans. I am not an expert painter by any means but it came out looking pretty nice. (see pic) Inexpensive too.
601HD-912ul-315hrs
| Quote: | Subject: Re: Rattle Can Primers
Date: Tue C 26 Aug 2008 18:09:43 -0700
--> Zenith-List message posted by: 'leinad' <leinad(at)hughes.net>
Derek C
I've been using Dupli-Color self etching primer. It sticks great to the aluminum. I first scuff it with a little scotch bright C and wash it well with a solvent to remove any residue and sharpee marks. I spray it outside with a dust mask. You can find this stuff almost anywhere that sells spray paint in rattle cans.
Dan
> I have seen that several people are using NAPA 7220 self etching primer C and I started using it. But NAPA is 20 min farther than several other hardware stores. Has anyone used any other rattle can primers? If so C How has it worked? Also is 6061-t6 considered galvanized?
> Thanks C
> Derek Lewis
> DO NOT ARCHIVE!
http://forums.matronics.com/viewtopic.php?p=200793#200793
Get thousands of games on your PC C your mobile phone C and the web with Windows®. Game with Windows |
397.92 KB |
328 Time(s) |
Afterfxllc(at)aol.com Guest
Posted: Tue Aug 26, 2008 6:29 pm Post subject: Rattle Can Primers |
Auto zone sells a good etching primer also.
Jeff
It's only a deal if it's where you want to go. Find your travel deal here.
