GrummanDude
Posted: Sat Aug 30, 2008 11:15 am Post subject: Cowling update |
Now, it looks like I need to validate the climb performance from the POH. Great. The plane has a 65 inch pitch prop. This should be fun.
Why do I need to do a climb test? Just incase I increased the drag on the plane with my new cowling.
Get the MapQuest Toolbar. Directions, Traffic, Gas Prices & More!
| | - The Matronics TeamGrumman-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?TeamGrumman-List |
_________________ Gary
AuCountry Aviation
Home of Team Grumman |
flyv35b(at)minetfiber.com Guest
Posted: Mon Sep 01, 2008 12:32 pm Post subject: Cowling update |
What about the data from the climb cooling test? Shouldn't that be sufficient? Wasn't it done at Vy?
Cliff
GrummanDude
Posted: Mon Sep 01, 2008 7:42 pm Post subject: Cowling update |
Hi Cliff,
Yes, it was done at Vy, but, we didn't time the climb for each increment in the POH. It's BS, I know. But, what can I do?
AuCountry Aviation
ski2little(at)AOL.COM Guest
Posted: Tue Sep 02, 2008 3:10 am Post subject: cowling update |
Not surprised FAA requires a climb test - presumably to confirm the plane can still climb at least as well as stock plane - at gross weight. I'm more surprised this was a surprise.Get the MapQuest Toolbar. Directions, Traffic, Gas Prices & More!
GrummanDude
Posted: Tue Sep 02, 2008 11:45 pm Post subject: cowling update |
Climb performance is more of a function of excess horsepower and weight than drag. At Vy, induced drag is more of a player in overall drag than is parasitic drag. Induced drag would be more of a function of airfoil design than cowling design.
The questions should be: (1) do any of the planes climb at book values?
(2) what prop was used for the book values? 61 inch, 62 inch, 63 inch, 64, inch or 65 inch pitch?
(by-the-way, the POH has climb performance for various weights, not just gross weight)
(3) what were the conditions under which the tests were performed. i.e., were the numbers in the POH
A. extrapolated from a continuous climb at Vy to various altitudes?
B. evaluated for climb rate from a stabilized level flight condition and a maximum airspeed
to a specified altitude then re-stabilizing level flight and repeating?
Why am I surprised? The only issue should be if I increased the drag on the cowling then climb performance would come into question. A more indicative test would be fuel flow at various altitudes and airspeeds. A test like this would indicate if the cowling affe cted the overall drag.
AuCountry Aviation
Posted: Wed Sep 03, 2008 4:47 am Post subject: cowling update |
I think where the ball got dropped is that the FAA should have outlined and specified what tests were required at the beginning of the program. Not done it piecemeal and at the last minute said 2oh, by the way, you need to do a climb test 2! Although they can do this, it isn't the way they are supposed to handle these STC programs. You should have been notified about this test requirement a long time ago and the test could have been incorporated with the cooling climb test.
Cliff
aa1bflyboy
Posted: Wed Sep 03, 2008 5:02 am Post subject: cowling update |
Hey Cliff we are talking about the government remember... LOL
We shall not cease from exploration.
And at the end of all our exploring
Will be to arrive were we started
And know the place for the first time - T. S. Eliot
Steve Roberts - AA-1B N641HY (at) ILG
----Original Message Follows----
Reply-To: teamgrumman-list(at)matronics.com
To: <teamgrumman-list(at)matronics.com>
Subject: Re: re:cowling update
Date: Wed, 3 Sep 2008 05:47:20 -0700
done it piecemeal and at the last minute said "oh, by the way, you need to
do a climb test"! Although they can do this, it isn't the way they are
Cliff
_________________ Steve Roberts |
Posted: Wed Sep 03, 2008 5:08 am Post subject: cowling update |
Years ago I was TDY in San Louis Obispo and attended an EAA chapter
meeting. The speaker used the numbers in a Piper owners manual to show
how using the numbers in certain situations could ruin your whole day.
It turns out that he was one of Bedes test pilots on the AA-1. I think
that test methods used way back when probably aren't applicable to
todays environment. But that observation comes from limited exposure to
the FAA as I can.
Linn
teamgrumman(at)aol.com wrote:
| Quote: | Climb performance is more of a function of excess horsepower and
just gross weight)
the overall drag.
Posted: Wed Sep 03, 2008 5:50 am Post subject: cowling update |
I can tell you one thing: If you believe the takeoff distance (ground roll
and over a 50 ft obstacle) performance numbers in an AA-1XX POH for higher
density altitude takeoffs you are in for a rude awakening unless you leave
LOTS of reserve.
Cliff
robsherwin(at)AOL.COM Guest
Posted: Tue Sep 16, 2008 7:59 pm Post subject: cowling update |
The same is true of the AA5 (and AA5A) POH's. The Tiger POH is much more realistic. The high, and especially the high and hot, for the Cheetah's take distance get increasingly ridiculous. Compare the take off distance over 50' at standard temp at 8,000. For the Cheetah, it's 2,700 but for the Tiger it's about 3,450. How can that be? The Cheetah takes longer at sea level to take off and has a significantly lower service ceiling. There is no way that it is magically that much better than the Tiger just when it's high (and/or hot). We all know that's when those of us that have 150 bhp wish for 160 (or more).
By the way, Gary, I now own Kevin Loftus 9853U (since '04). She flies like a champ still (except for that density altitude thing).
Rob
mkaratsonyi(at)hotmail.co Guest
Posted: Wed Sep 17, 2008 10:05 am Post subject: cowling update |
hello all C
i have a 1978 grumman aa1-c with the original 0235 L2C i am located in southern ca. my question is i recently flew with a passenger with only using 365lbs of my 489 useful load minus 6-8 gal of gas. i departed van nuys and slowly climbed to 2300' after about maybe 10 min of flight i noticed oil temp was 290 or so ..close to yellow/red on gauge so i leveled out full rich and pull rpm back to 2100rpm it slowly cooled but what i noticed and what my question is ...is that cabin heat was off and vents full open(oh by the way i had canopy open) it was 70 degrees outside nice and cool but vents were blowing out hot air i verified and cycled cabin heat it got hotter shut it off but still warm....does anyone anything about this...thanks michael
Date: Tue C 16 Sep 2008 23:57:39 -0400
The same is true of the AA5 (and AA5A) POH's. The Tiger POH is much more realistic. The high C and especially the high and hot C for the Cheetah's take distance get increasingly ridiculous. Compare the take off distance over 50' at standard temp at 8 C000. For the Cheetah C it's 2 C700 but for the Tiger it's about 3 C450. How can that be? The Cheetah takes longer at sea level to take off and has a significantly lower service ceiling. There is no way that it is magically that much better than the Tiger just when it's high (and/or hot). We all know that's when those of us that have 150 bhp wish for 160 (or more).
By the way C Gary C I now own Kevin Loftus 9853U (since '04). She flies like a champ still (except for that density altitude thing).
Rob
JHOSLER(at)epri.com Guest
Posted: Wed Sep 17, 2008 10:25 am Post subject: cowling update |
With that kind of oil temp I would remove oil filter and check for metal.
John
From: owner-teamgrumman-list-server(at)matronics.com [mailto:owner-teamgrumman-list-server(at)matronics.com] On Behalf Of Michael Karatsonyi
Sent: Wednesday, September 17, 2008 2:05 PM
Subject: RE: TeamGrumman-List: re:cowling update
hello all,
Date: Tue, 16 Sep 2008 23:57:39 -0400
Rob
GrummanDude
Posted: Thu Sep 18, 2008 10:10 pm Post subject: cowling update |
I'm sorry, but, I don't understand the question(s?).
(1) What I understand is: You had hot air coming out of your fresh air vents with an OAT of 70 degrees.
(2) What I understand is: When you open the cabin heat, the air from the fresh air vents gets hotter.
(3) What I understand is: You were trying to climb a 2-seater at near gross weight with the canopy open.
(4) What I understand is: Your average rate of climb to 2300 feet was 230 fpm.
(5) What I understand is: You had oil temps at 290 degrees.
(1) Check for a leak from your cowling
(2) There is no connection between the cabin heat and fresh air unless someone has modified the ventilation system
(3) Opening the canopy in flight increases parasitic drag. Climbing with it open is a sure way to get behind the power curve. Ask me how I know.
(4) You need some serious engine work.
(5) You need some serious engine work. Then, install a quality digital oil temp sensor. By quality, I mean, don't buy a Westac or some other cheap, non-approved, instrument.
AuCountry Aviation
Posted: Fri Sep 19, 2008 5:02 am Post subject: cowling update |
I'll add some comments to Gary's (shown below)
1. The AA-1C POH says the plane should climb ABOUT 700 fpm at 77 kts between SL and 2000 ft at 1500 lb and 68 F with the cruise prop.
2. Opening the canopy greatly increases the drag and there is no data for climb in that condition. Needless to say the ROC would suffer considerably. Also the airflow around the cowling and windshield likely changed such that hot air escaping from the engine compartment was getting sucked into the NACA fresh air ducts. This happens some anyhow with air that leaks out the cowl latches.
3. 290 F oil temp is way above the 245 F redline! What makes you say you had 290 F?? Even 245 F is very hot for your ambient temp and the AA-1C which has an oil cooler, especially after only 10 min. Climbing at a slow speed with the canopy open most likely adversely affects both oil and cylinder head temperatures.
4. If you don't have a good digital 4 cylinder CHT instrument, I would buy one as you may be cooking your cylinders as well. Also at least check the accuracy of your oil temp instrument per the maintenance manual or install a good digital instrument.
5. Don't climb with the canopy open if you want decent ROC and don't want to cook your engine. And climb at a high speed than the POH says for best ROC, probably about 90 kts.
6. Check your cylinder compression to see what the ring leakage is. Excess blow-by past the rings will overheat the oil.
Cliff A&P/IA
(Original Post)
hello all,
| Quote: | (Gary's Post)
| Try [quote][b]
