orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Sat Sep 06, 2008 1:51 pm Post subject: GPS Antenna Mounting |
I am to the point of needing to mount or at least drill the holes for the 430W GPS antenna. I want to put it on top of the cabin but it looks like I have 2 options.
On the cabin top center line for/aft; One is just behind the aft door posts where the top is rather thin. The second location is centered between the door hinges where the top is very thick.
Using the aft location, I don't think I would have any problems with screw length or attaching the coax.
If I were to use the location between the door hings, I am concerned about getting the coax connected and to a lesser extent the screws and what I would have the nuts tighten up against.
Where are others mounting their antenna and any thoughts?
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
ron.mcgann(at)baesystems. Guest
Posted: Sat Sep 06, 2008 2:53 pm Post subject: GPS Antenna Mounting |
G'day Gary,
I mounted mine on the top cabin centreline aft of the door posts in the thinner material. Even there, the thickness of the cabin is close to 1/2" and the GPS antenna studs were not long enough. The studs are no where near long enough to penetrate the forward (thicker) part of the cabin. I made some extensions out of steel tube tapped for the antenna studs, and threaded on the outside for the nuts. A bit of work but came out great. Antenna lead passed through the windshield support brace and through a small cover strip down the cabin top.
I think you can buy an alternate antenna that has a flange mount rather than the studs. This (and some rivnuts)is probably a better option if you want to mount the antenna to the lid.
cheers,
Ron
Posted: Sat Sep 06, 2008 3:02 pm Post subject: GPS Antenna Mounting |
I don't know why you'd want to go to all that trouble unless your 430W
is mounted to the cabin top too. I'm nowhere near the point of mounting
anything electronic, so bear with me. Why not mount the GPS antenna
(and any other satellite antenna) on the glareshield???? The signal
attenuation due to the windshield is negligible. You could hide it
under the cowl (I think even under the cabin top) as long as the carbon
fiber isn't above it. Mine will probably go on the glareshield.
Linn
orchidman wrote:
Gary Blankenbiller
RV10 - # 40674
Instrument Panel, Fiberglass - SB
(N2GB registered)
http://forums.matronics.com/viewtopic.php?p 2951#202951
mckervey(at)charter.net Guest
Posted: Sat Sep 06, 2008 4:17 pm Post subject: GPS Antenna Mounting |
For mounting between the doors you can use aluminum tube standoffs. drill
the top skin the diameter of the screw and the inner cabin top for a snug
fit of the standoff.
Hope this helps
Joe
orchidman
Posted: Sat Sep 06, 2008 6:33 pm Post subject: Re: GPS Antenna Mounting |
| pitts_pilot(at)bellsouth. wrote: | I don't know why you'd want to go to all that trouble unless your 430W
Linn
Linn,
In the archives there is a rather large number of people experiencing problems mounting on the glare shield or under the cowl.
I don't want to risk having a problem and having to 're-do' it.
Gary
RV10 - # 40674
(N2GB Flying) |
orchidman
Posted: Sat Sep 06, 2008 6:43 pm Post subject: Re: GPS Antenna Mounting |
| mckervey(at)charter.net wrote: | For mounting between the doors you can use aluminum tube standoffs. drill
Hope this helps
Joe
I think my next step is to get the coax connector and go from there. Guess I will be making a call to Stein Monday.
RV10 - # 40674
(N2GB Flying) |
daveleikam(at)wi.rr.com Guest
Posted: Sun Sep 07, 2008 5:40 am Post subject: GPS Antenna Mounting |
Any problem mounting the GPS antennas on the top of the tailcone?
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
rene(at)felker.com Guest
Posted: Sun Sep 07, 2008 6:24 am Post subject: GPS Antenna Mounting |
That is where I mounted mine. It has worked great.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
orchidman
Posted: Sun Sep 07, 2008 12:18 pm Post subject: Re: GPS Antenna Mounting |
| daveleikam(at)wi.rr.com wrote: | Any problem mounting the GPS antennas on the top of the tailcone?
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
That has been added to the list of possible locations.
I dug out the installation manual and the one I have been using for the 430W is REV B. paragraph 3.10.1
It lists a max coax length of 35 feet and you have to calculate the minimum length. It comes out to about 15 feet. However, I have an updated version REV E and checking it, the text has changed. I have a GA35 antenna and the new text places this antenna in a new category only requiring a minimum length of 6.5 feet and the max still at 35 feet.
All of this is based on a dB signal loss that is required for the receiver.
If I mount it on the first AL skin on top, that would put me right in the middle of the dB loss range based on 2 connectors and the coax length and having a full view of the heavens. The only down side is that it would be within 19" of my magnatomitor. Guess I will need to call Rob tomorrow and see if they have any feeling about the amount of mag distoration the GPS antenna emits.
All thoughts are appreciated. Nothing is locked in stone yet.
RV10 - # 40674
(N2GB Flying) |
Posted: Sun Sep 07, 2008 12:36 pm Post subject: GPS Antenna Mounting |
Your magnetometer is not much over 18" from your auto pilot servo. I
don't think the GPS antenna emits anything. I think it is just a
receiver. 19" should be fine, but it wouldn't hurt to verify that
with Rob.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
On Sep 7, 2008, at 4:18 PM, orchidman wrote:
> Dave Leikam
> RV-10 #40496
> N89DA (Reserved)
> Muskego, WI
still at 35 feet.
receiver.
Gary Blankenbiller
RV10 - # 40674
(N2GB registered)
http://forums.matronics.com/viewtopic.php?p 3083#203083
orchidman
Posted: Sun Sep 07, 2008 3:03 pm Post subject: Re: GPS Antenna Mounting |
| jesse(at)saintaviation.co wrote: | Your magnetometer is not much over 18" from your auto pilot servo. I
with Rob.
Jesse Saint
The battery + lead (closest part of the battery) and the AP servo are right at 23". The one thing that might be a problem is the strobe power supply which is 28" away.
RV10 - # 40674
(N2GB Flying) |
Dave(at)AirCraftersLLC.co Guest
Posted: Sun Sep 07, 2008 5:22 pm Post subject: GPS Antenna Mounting |
Gary,
My battery and TruTrak servo are in the stock locations. I have my GPS
antenna just aft of the cabin roof on the tail boom, a little to the right
side. My AFS magnetometer is mounted high in the tailboom just forward of
the first former aft of the battery. I mounted it on a little 7* tray to
align it vertically with the panel. The thing I worried about most was a
cabin speaker mounted high on the left side of the baggage compartment rear
wall. I was prepared to move it if it affected the magnetometer, but
everything (mentioned) works perfectly. I think you're on the right track.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
