Firewall pad
rmacpunk(at)netzero.net
PostPosted: Sun Sep 07, 2008 7:33 am    Post subject: Firewall pad Reply with quote
Anyone using a firewall pad on the inside of firewall. What kind?
cookwithgas
PostPosted: Sun Sep 07, 2008 1:45 pm    Post subject: Re: Firewall pad Reply with quote
I used some stuff I got from Jegs. It is made for sound and heat insulation and is easy to cut. It has some sort of felt material on the inside and the outside is reinforced with threads. I used it all over in front of the seats. (see the attached picture) I used aluminum tape (for HVAC work) where I had seams.
Scott Laughlin
www.cooknwithgas.com
601XL/Corvair
109 hours
 Filesize:  155.89 KB
 Viewed:  619 Time(s)
