jfgilmore
Posted: Sat Sep 06, 2008 1:51 pm Post subject: Finish Kit |
I have decided to use an engine other than the IO-540 and am ready to order the finish kit. My selected engine comes with a custom cowling and other components specific to the engine. I don't want to order a finish kit from Van's that comes with parts that I will not use. Does anyone have a shipping list for the finish kit who might also identify the parts I won't need? I would settle for just the finish kit inventory list.
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Sat Sep 06, 2008 1:54 pm Post subject: Re: Finish Kit |
Call Van's on Monday and request they FAX you a copy of a current packing list. That way you be assured of getting an up to date list.
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
rv10(at)sinkrate.com Guest
Posted: Sat Sep 06, 2008 2:20 pm Post subject: Finish Kit |
Here is the current up to date list as of 8/15/2008 direct from Van's
1.00 FF-10 IO-540 F.WALL FWD.KIT IO-540
3.00 CT A-740 BLACK PUSH PULL CABLE BLACK
2.00 DUCT CBT-5/8 COOLING BLAST TUBE
2.00 EA 4" DUCT HOSE CLAMP 4" HOSE CLAMP
1.00 EA CV HOSE 7545 BREATHER HOSE -540
6.00 EA GASKET 77611 BLO-PROOF EXHST GASKT
4.00 EA DYNA VI I(O)-540 VIB.ISO. RV-10 ONLY
1.00 EA OIL COOLER 20006A OIL COOLER I(O)-540
1.00 ES ALTERNATOR DELUXE 60A KIT W/OV PROTECT
1.00 FAB-360/540 FLTRD A/BOX-360 FI320
1.00 FF-1005 BREATHER TUBE
1.00 IE VMP INSTALL KIT FITTINGS/HOSES
1.00 PROP GOV MT P-860-3 I(O)-540 LYCOMING
1.00 VA-102 FUEL PRES. HOSE 15.5
1.00 VA-133 OIL PRESS. HOSE 27.25
1.00 VA-135 OIL COOLER HOSE 16.5
1.00 VA-168 SENDER MOUNT
1.00 VA-186 OIL COOLER BOX ASSY.
1.00 VA-187 4" FLANGED DUCT
1.00 VA-190 OIL COOLER HOSE 27"
1.00 BAF-10-540 BAFFLE KIT IO-540
1.00 PT-035X1/4X4' LO PRES-BRKE RES.TUBE
1.00 SS304-26GAX1/2X9 SCAT CLAMP !!SHARP!!
1.00 VENT SCAT 2X3' RED 2" SCAT 3' LONG
1.00 VENT SCAT 2X6' SCAT TUBE X 6 FT
1.00 VENT SCAT 4X16" 4" DIA. RED SCAT HOSE
1.00 EA DYNA BOLT I(O)-540 MOTOR MOUNT BOLT KIT
1.00 BAG 516 RIVET AN426AD3-3.5
1.00 BAG 517 RIVET AN426AD3-4
1.00 BAG 518 RIVET AN426AD4-4
1.00 BAG 519 RIVET AN426AD4-5
1.00 BAG 520 MISC. AN BOLTS
1.00 BAG 521 MISC. WASHERS
1.00 BAG 522-1 MISC. FITTINGS/CLAMPS
1.00 BAG 523-1 FITTINGS/MISC.
1.00 BAG 524 MISC. CLAMPS
1.00 BAG 525-1 MISC/BEARINGS
1.00 BAG 526-1 CABIN HEAT SHUTTLE HW
1.00 PT-062X1/4X24" HIGH PRESSURE
1.00 CT BLK THROTTLE 47.5 10 (I(O)-540)
1.00 CT BLUE VPROP 72.5 10 (I(O)-540)FWD GOV
1.00 CT RED VMIXTURE 51.5 10 (I(O)-540)
1.00 VA-182-PC KIT THR/MIX BKT IO VERT
1.00 VA-189 FUEL LINE IO-540 25.5
1.00 DOC FF-IO-540 TEXT/DWGS RV-10 F.FWD
1.00 EA EXH 10 I(O)-540 I(O)-540 VETTERMAN
1.00 VA-138 FUEL SUPPLY HOSE 14.0
wcurtis(at)nerv10.com Guest
Posted: Sat Sep 06, 2008 3:18 pm Post subject: Finish Kit |
You stated the Finish Kit but did you mean the Firewall Forward Kit? Seems you would want the Firewall Forward Kit as listed below. Not too much in the Finish Kit is specific to the engine. Get a current FF or Finish kit contents from Van's
William
http://nerv10.com/wcurtis/
kearney(at)shaw.ca Guest
Posted: Sat Sep 06, 2008 5:27 pm Post subject: Finish Kit |
Hi
What engine are you using? I am using an Eggenfellner E6TI (3.6l)
Cheers
Les Kearney
#40643 - some assembly required
On 6-Sep-08, at 3:51 PM, jfgilmore <jfg(at)aol.com> wrote:
http://forums.matronics.com/viewtopic.php?p 2952#202952
jfgilmore
Posted: Sat Sep 06, 2008 11:51 pm Post subject: Finish Kit |
Thanks Gary.... I guess the direct approach is best!
Jim Gilmore, #40317
RV10 Wings/Empennage complete about to start fuse
Looking for spoilers and reviews on the new TV season? Get AOL's ultimate guide to fall TV.
jfgilmore
Posted: Sat Sep 06, 2008 11:52 pm Post subject: Finish Kit |
Actually, I was referring to the finish kit. I won't need anything from a Van's FF FWD kit, as my engine package comes complete.
Jim Gilmore, #41317
RV10 - Wings/Empennage complete
- about to start fuse
jfgilmore
Posted: Sat Sep 06, 2008 11:53 pm Post subject: Finish Kit |
I'm using a Vesta Inc. engine/prop package. I will probably start or at least contribute to a storm of dialogue on the topic, but I like the idea of a non-air-cooled engine and parts that are readily available at local auto parts stores at non-aviation part prices. Also, not giving up anything to power and relying on a company that produces millions of engines rather than thousands is very appealing.
Jim Gilmore, #40317
RV10 - Wings/empennage complete
woxofswa
Posted: Sun Sep 07, 2008 12:29 pm Post subject: Re: Finish Kit |
What is the current price for the Vesta package and what do you get for that price?
_________________ Myron Nelson
Mesa, AZ
Flew May 10 2014 |
