kdbelue(at)charter.net Guest
Posted: Mon Sep 08, 2008 7:56 pm Post subject: Garmin GPS496 Antenna & XM antenna mounting |
I put velcro on my XM antenna to hold it on the glare shield so I can swap
it between the RV-6A and RV-10.
Kevin
robin1(at)mrmoisture.com Guest
Posted: Mon Sep 08, 2008 8:04 pm Post subject: Garmin GPS496 Antenna & XM antenna mounting |
Mike,
You know that AirGizmos also sells an XM Antenna Dock that
allows you to remove & use the ($500) XM antenna else ware. I purchased
an Antenna Dock Premium at SNF 2 years ago.
http://www.airgizmos.com/antennadock.asp
Of course it's not as inexpensive as two M3x6 screws.
Robin
