		jdm(at)wideworld.net Guest
				 Posted: Mon Mar 06, 2006 4:14 pm    Post subject: BRS 5 Installation on Original Firestar |
				OK, now that you've got my attention, where is the best place to but the BRS 5 750 canister?  I had a BRS 4 500 inside the cage under the tank. I took it out because the BRS was 12 years out of date and not big enough for the fat airplane and pilot.  Unfortunately the larger canister won't fit inside the cage, which is why it is on the shelf in the hanger.
 I've seen them in front of the engine and I've seen them on the landing gear.  I don't particularly like either. Any suggestions? Pictures?
 Perhaps the flat pack for on top of or under the gap seal?  If so I need to sell my current BRS.  It's only a year old and has never been registered, so it is considered new.  I think they are good for ten years, but I don't have the manual here at home.
 Thank you in advance.
 John Murr
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Possum
				 Posted: Mon Mar 06, 2006 6:38 pm    Post subject: BRS 5 Installation on Original Firestar |
				At 07:14 PM 3/6/2006, you wrote:
 I put mine here:
 http://www.mindspring.com/~possums/BRSsys.jpg
 http://www.mindspring.com/~possums/Rubberduckanten.jpg
 But ask BRS - they know the plane real well.
 Just remember, no matter which way you fire it
 (up, back and down under the tail or sideways)- it will end up
 directly behind the plane when it opens.
 Hopefully it will come up over the top after it opens.
		John Jung
  Joined: 10 Jan 2006 Posts: 108 Location: Surprise, AZ, USA
				 Posted: Tue Mar 07, 2006 3:42 pm    Post subject: Re: BRS 5 Installation on Original Firestar |
				 	  | jdm(at)wideworld.net wrote: | 	 		  | OK, now that you've got my attention, where is the best place to but the BRS 5 750 canister? John Murr |
 John,
 I have a soft pack in the gap seal. But if I had already owned a canister, I would have mounted it in front of the engine, like so many others have. BRS should have instructions for how to mount it on a Firestar.
  _________________ John Jung
Firestar II N6163J
Surprise, AZ |
		ulflyer(at)verizon.net Guest
				 Posted: Wed Mar 08, 2006 9:26 am    Post subject: BRS 5 Installation on Original Firestar |
				I mounted a VLS 750 on top of a FireFly - modified the wing root gap
 cover to partly cover the front part of the box case (opens at the
 rear) - cut and hemmed the opening with elastic rope (3/16" if I
 recall right)  so it would pull up snug over the top front edge
 veeing out towards and over the sides about half way back on the case
 -  the elastic rope makes it pull up snug against the sides, the
 rocket and around the back.  Turned out and worked pretty good.
 jerb
 At 05:42 PM 3/7/2006, you wrote:
 John,
 on a Firestar.
 John Jung
 Firestar II N6163J
 Surprise, AZ
 http://forums.matronics.com/viewtopic.php?p=20213#20213
				 Posted: Wed Mar 08, 2006 10:41 am    Post subject: BRS 5 Installation on Original Firestar |
				Thanks!
