B25Flyer
Posted: Mon Mar 06, 2006 6:41 am Post subject: Re: Minimum altitude to return to airport |
I am baaaack!!!!!!!
Kevin Horton told me this subject had raised it's head again.
There is NO DOUBT that the turnback after takeoff can be completed in an RV. There is also NO DOUBT that each year several people get killed trying to do it. This happens in all kinds of airplanes including RV's.
I am alive today because I overcame the incredible urge to turnback. I wrote this years ago when this topic came up. Please read the story at
http://www.petroblend.com/dougr/dnt-turn.htm
As the Defender of "Don't Turn Back" I remain!
Doug Rozendaal
Posted: Mon Mar 06, 2006 7:30 am Post subject: Minimum altitude to return to airport |
If you haven't read Doug's piece, then do it now. It's interesting
reading, and I couldn't agree more. Although both of my off-field
emergency landings occurred far from an airport, I went through much the
same steps that Doug did. But I handled my two emergencies
differently. When the prop on my Pitts departed in flight (the prop
flange failed due to fatigue), I spent valuable time trying to figure
out what happened, and actually tried twice to use whatever portions of
the prop were still there (the denial part!). I was in the 2200' to
2500' range when it happened. After I became an unlicensed glider
pilot, the safe landing on a road was uneventful, thank you very much.
The second incident was in my Traumahawk. At 1200', flying in a
corridor through some class B space, the engine started to run rough,
and finally lost enough power so we couldn't stay in the air. Over
older neighborhoods with lakes and huge oak trees, I assessed my landing
options rather quickly while doing my emergency cockpit procedures.
There was a large highway, but if I landed short, it would have been
nasty, so I discarded it immediately. Off my left wing I saw a white
oblong something amidst the green trees/houses. I picked it, and didn't
waver from my choice. I had to slip the Traumahawk a lot to lose
altitude and airspeed, and plopped the bird down ..... in the
percolation pond for the Winter Springs (FL) Reclaimed Water System.
they had built a 6' berm around ground level and put sugar sand in the
bottom. This was fortuitous as the Traumahawk was stopped is less than
300'. My best short field landing to date. The cause of this one was
the missing cotter pin in the arm that holds the carb float. The pin
backed out far enough for the float to cock, become jammed and allow the
free-flowing fuel to flood the engine in flight. The carb had been
rebuilt by an A&P prior to my purchase 6 months or so before.
In both instances, the airplanes were disassembled and made their way
home on a trailer to fly again.
If you've read this far, I have some personal observations.
You never know how you're going to handle the emergency until it becomes
real.
Every inflight emergency is unique and unlike anyone elses emergency.
You can learn from others thought processes, but your situation will
always be different is some or many ways.
Some people have been killed trying to save the airplane. That's the
only reason to compel someone to turn back to the airport. My airplanes
are expendable. I have had so much pleasure from all of them that they
don't owe me anything. That doesn't prevent me from trying to save both
of our butts!!!
I like the skin, tin, ticket quote. It ranks up there with 'fly the
airplane as deep into the crash as you can'. Priceless.
Thanks, Doug, for weighing in again. I missed you!
Linn
B25Flyer wrote:
I am baaaack!!!!!!!
Doug Rozendaal
http://forums.matronics.com/viewtopic.php?p=19895#19895
real.
of our butts!!!
Linn
B25Flyer wrote:
I am baaaack!!!!!!!
Doug Rozendaal
Neal.George(at)maxwell.af Guest
Posted: Mon Mar 06, 2006 8:32 am Post subject: Minimum altitude to return to airport |
>I am baaaack!!!!!!! <
Best news I've had in weeks.
Welcome back Doug!
Neal
RV-7 N8ZG (wiring)
gmcjetpilot(at)yahoo.com Guest
Posted: Mon Mar 06, 2006 11:26 am Post subject: Minimum altitude to return to airport |
>From: luckymacy(at)comcast.net (lucky)
| Quote: | Subject: Re: Minimum altitude to return to airport
The point wasn't to read more emails from folks who have never
done this practice in an RV and just rehashed their previous
soapboxes. It was to update the list with a real tried RV
>datapoint. It doesn't mean it will work for each pilot/plane combo
>every time but it does demonstrate that it CAN be done and
>BETTER yet it actually showed a bank amount and min
>airspeed amount and altitude loss amount. Real RV data beats
>soapbox.
Lucky:
First as far as soapbox and folks who have never done this in a
RV, you might like to know that several of the folks on this list
are literally test pilots and long time RV pilot and instructors.
Although I never have done a 400agl turn back in a RV, I am a
10,000 hr ATP, over a 1000 in RV's and 2000 hrs dual given as
a CFI (inst/me).
I do think it is important to point out that 400 agl COULD be
dangerous in (our) opinion, I understand your point. It is a data
point and is possible if you do XYZ. I got that, as well as those
who responded, but not everyone my get it, and I think it is
important that the emphasis be made. I know you might feel a
little ganged up on, I understand, but that is not the intent or
to take away from Jan's interesting DEMO.
It's a good thing to emphasise the danger for the average pilot
caught unaware, that making low altitude 60 degree BANK
turns are sporty. Quick what is your new stall speed at 60
degrees? Have you practiced an accelerate stall/recovery?
Steep turns at altitude? Power off glide to landing? I would
go for these at altitude first.
The average pilot is not prepared mentally or skill wise for
radical max performance maeuvers at any altitude (good, bad,
ugly it is true). We all get rusty. I fly a jet on autopilot. If I don't
kick it off and hand fly my stick and rudder suffer. So one good
thing out of this topic is practice and stay current, but you can
do it higher up in case you are human and make a mistake, you
have room to recover. For those with super human skill and can
do a power off go around (joke), you know who you are.
Every ones caution is valid. I don't agree with ALWAYS go
straight either. You say we all know. Not every pilot might know
why a 400 agl, 270 degree turn (225 left, 45 right to line up)
is hazards. Jan may be able to do it knowing the engine is there
but add a little distraction, oil on the windscreen, vibration he
might not be so smooth. Not everyone is named LUCKY! either
As a CFI, I and most CFI's teach what will work. One thing for
sure, controlled flight, wings level, at min speed is WAY more
survivable than a stall spin into the ground. Not every one has the
SKILL and practice as Jan does in this maneuver. As you and
everyone pointed out that every takeoff, airport, flight and aircraft
condition is differnt. Mental preparedness and practice of basic
skills (slow flight, stalls, accelerate stall, steep turns, pwr-off glide
to a landing) is critical. Most practice can be done at altitude. I
can't see practicing higher G banks near stall, near the ground is
really prudent. You can do this at 3000 agl.
One commercial maneuver is a steep descending spiral over a
point to a power off landing. I found that really confidence building
and increased my ability to divide attention from out/in side and
maintain while maintaining a higher G turn.
I agree with everything you said except the soapbox. I think
everyone has valid points, even if they never did a 400 agl turn
back in a RV. With that said, the day my engine quits on the
cross-wind at 500 agl and I see the runway is available, I may
make a decision to go for the runway. I will base that more on my
power off glide practice and steep turns and accelerate stall
recovery (awareness / avoidance) practice. A Demo by a skilled
pilot like Jan is an eye opener, but most RV pilots are not able to
do this maneuver as safely in a real stressful situation. Not that it
is a good thing, it is realistic. Be real, real safe and conservative.
FACTS:
Controlled flight (at min speed) into the ground = survivable
Uncontrolled flight (stall spin) into the ground = not survivable
Stall Spd: 60 deg bank=1.4 x stall; 76 deg bank = 2 x stall
"Ye will bust thy ass when ground cometh up and smite
thee mightily."
Be safe, and go practice all your private (student) pilot
maneuvers at altitude today. If commercial rated practice
those maneuvers as well.
George
Bring photos to life! New PhotoMail makes sharing a breeze.
cgreimer(at)mts.net Guest
Posted: Mon Mar 06, 2006 5:14 pm Post subject: Minimum altitude to return to airport |
I think we should also bring the subject of airspeed into this discussion.
As in, how fast are you going when the engine quits. Doing 120 knots at 500
feet a given distance from the runway threshold might give you enough energy
to make that 180 degree turn back to the runway, while doing 80 knots in the
same situation might not. This will depend on what speed you established on
the climb and your overall rate of climb (better for constant-speed prop of
course). It is total energy available to you that matters in a turn-back
maneuver, and that consists of kinetic (airspeed) plus potential (altitude)
energy. This is pretty clear in a fixed pitch RV-6 when you carry an extra
10 knots into the late downwind (doh!) and have to extend it a half mile or
use some other energy sapping maneuver, like dropping the flaps early.
Airspeed aside, the guy with the constant speed prop climbing at Vx is quite
likely to still be OVER the runway when the 500' engine failure occurs,
while the fixed pitch guy climbing at Vy is a half mile away from the
airport at the same altitude.
Curt
RV-6 C-GCAR
375 hours
hawk(at)digisys.net Guest
Posted: Mon Mar 06, 2006 7:07 pm Post subject: Minimum altitude to return to airport |
George ( gmcjetpilot(at)yahoo.com ) asked,
"Quick what is your new stall speed at 60 degrees?"
Since the stall speed is not related to bank angle in any way, the answer
is,
"just about anything you want it to be." You establish your stall speed by
setting your load factor.
Performing the turnback maneuver using 60 degrees of bank and +1.5 Gz will
result in a good rate of turn with a generally acceptable loss of altitude.
Even using +1.25 Gz will yield a pretty good result, although significantly
more altitude is lost in the turn, as compared to loading the aircraft up
closer to max available Gz at the chosen glide speed (If we use 100 KIAS as
our best glide speed, over +3.5 Gz is available). At the lower Gz levels,
IAS will also tend to increase at a higher rate during the turn, the
magnitude of the increase largely depending on the pitch angle at the entry
to the turn.
Achieving good turn performance without giving away all the stall margin is
certainly possible.
Hawkeye Hughes
Posted: Tue Mar 07, 2006 3:05 am Post subject: Minimum altitude to return to airport |
| Quote: | From: "REHughes" <hawk(at)digisys.net>
I had to reply.
Hawkeye: You could not be anymore wrong, and I will tell you
why. If you want to be correct you should say AOA is most
relevant to stall, ie critical angle of attack.
I was referring to a sustained 60 degree banked TURN. My point
is for anyone thinking of a low altitude, high bank angle turn, what
is your stall speed, ie, what speed are you going to maintain. If
you can't think of right now at your easy chair you will not know
it when the engine quits. That was the point of the question? I
guess I could have said what is your load factor? or AOA?
However to address you assertion that bank angle and stall speed
are not related, since they are, I will explain.
Below link is everything you want to know about Bank angle and Gs
and applies to RV's or the Space Shuttle, I worked as an engineer
before flying for the airlines, so let the equations below speak:
http://www.aerospaceweb.org/question/performance/q0146.shtml
(notice, stall speed and bank angle can be expressed. Also notice
the generic concept, min flying speed goes UP with bank. That's the
point. Notice over 60 bank stall speed goes up quickly.
Yes we all know that AOA is critical, but there is a bank angle
(airspeed) relationship. Obviously AOA is related to load factor,
however you don't fly staring at a G-meter (except may be during
aerobatics).
We fly indicated airspeed (IAS). Obviously an AOA instrument is
most relevant to stall (at any load factor) since you can be wings
level and pull all the Gs you want or attitude.
Unless you have an AOA, you fly a higher indicated airspeed for
a given bank angle to get an **approx** stall margin, typically
1.3 x stall.
You say bank angle is not related to load factor? I think you are
arguing a moot point relative to making a turn back to the
airport.
The rest of your point (below) about efficient turns and having Gz
available and **giving away stall speed**, makes no sense. I guess
you mean giving away stall margin?
Also when *pulling Gs" you will increase drag and loose airspeed
and/or increase rate of descent unless thrust is increased. Is this
what U want close to ground? (increased descent rate, low IAS)
Regardless it kind of muddies the waters from the main Q:
What are you going to do when the engine quits at the worst time?
Fly the plane, fly the plane and maintain control to the ground,
whether on the airport or off field.
Again stall margin and bank angle in a sustained turn ARE relative.
Discussion of "efficient" turns are not relevant. What is critical is
being in a steep bank, high descent rate near the ground.
Cheers George
>"REHughes" <hawk(at)digisys.net> also wrote:
| Quote: | answer is, "just about anything you want it to be." You establish
>your stall speed by setting your load factor.
>+1.5 Gz will result in a good rate of turn with a generally acceptable
>loss of altitude. Even using +1.25 Gz will yield a pretty good result,
>although significantly more altitude is lost in the turn, as compared
>to loading the aircraft up closer to max available Gz at the chosen
>glide speed (If we use 100 KIAS as our best glide speed, over
>+3.5 Gz is available). At the lower Gz levels, IAS will also tend to
>increase at a higher rate during the turn, the magnitude of the
>increase largely depending on the pitch angle at the entry to the
>turn.
margin is certainly possible.
Hawkeye Hughes
luckymacy(at)comcast.net Guest
Posted: Tue Mar 07, 2006 3:31 am Post subject: Minimum altitude to return to airport |
Again, the pre flight briefed and demo'd numbers:
120 mph climbout with fixed pitch prop, flaps up and at
400 feet AGL pulled power back to idle
rolled into 60 degree bank and not one degree more and
pulled elevator firmly but did not let the airspeed get down to his PRE ESTABLISHED ABSOLUTE MIN AND BRIEFED BEFORE FLIGHT 80 mph.
The RV had no trouble doing this.
We leveled off with ~100 foot altitude loss and probably more than 90 mph airspeed but the nose was kept low after level off to pick up best glide speed which allowed a lot off energy to pull to flare with. The runway displacement was maybe a couple of hundred of feet. We turned into the wind to to keep it that way. No obsticles to contend with on the way down on either side.
Lucky
>From: "REHughes"
I had to reply.
aerobatics).
1.3 x stall.
airport.
Cheers George
>turn.
>Hawkeye Hughes
Again, the pre flight briefed anddemo'd numbers:
We leveled off with ~100 foot altitude loss and probably more than 90 mph airspeed but the nose was kept low after level off to pick up best glide speed which allowed a lot off energy topull to flare with.The runway displacement was maybe a couple of hundred of feet. We turned into the wind to to keep it that way. No obsticles to contend with on the way down on either side.
Lucky
-- RV-List message posted by: <GMCJETPILOT(at)YAHOO.COM>
I had to reply.
Yes we all
aerobatics).
1.3 x stall.
airport.
you m
Cheers George
turn.
Hawkeye Hughes
JVanLaak(at)aol.com Guest
Posted: Tue Mar 07, 2006 4:23 am Post subject: Minimum altitude to return to airport |
My friend Hawkeye (former flight surgeon and naval aviator) was referring to
the point that you can be in 90 degrees of bank with one G on the airframe
and the stall speed is what it would be if level. Likewise, you could be in a
4 G pull wings level and the stall would be twice the 1 G value.
So in application, if you use a 90 degree bank but only 1 G the airplane
with large stall margin will turn rapidly but the nose will fall. If you have
the vertical room to permit that it might be a good trade.
Jim
RV-6 N79RL.
rv7(at)b4.ca Guest
Posted: Tue Mar 07, 2006 8:29 am Post subject: Minimum altitude to return to airport |
On 3:29:57 2006-03-07 luckymacy(at)comcast.net (lucky) wrote:
And again, as others have pointed out, this was a contrived situation. The
pilot briefed and prepared for an engine out on takeoff, and everything
went according to plan.
Try the same thing on a climbout when you're not expecting an engine
failure, when you're half-way through retracting your flaps, talking about
where you're going with your passenger, and playing with the GPS. I'm sure
you'll lose more than 100 feet getting from [engine failure] to [lined up
on the runway].
Yes, the RV can do this turn. No, we're not all going to be enough on the
ball to make it do that in an unexpected high-stress situation.
-Rob
jpl(at)showpage.org Guest
Posted: Tue Mar 07, 2006 8:56 am Post subject: Minimum altitude to return to airport |
It doesn't matter at what altitude the power fails. It matters at
what altitude you have sufficient control of the situation to make
any further decisions.
If it takes you a half second or 5 seconds to respond, it doesn't
matter. Once you have control of the situation, then you check your
altitude for your minimum turn-back altitude.
-Joe
On Mar 7, 2006, at 10:28 AM, Rob Prior (rv7) wrote:
situation. The
everything
talking about
I'm sure
[lined up
on the runway].
on the
-Rob
ogoodwin(at)comcast.net Guest
Posted: Tue Mar 07, 2006 11:35 am Post subject: Minimum altitude to return to airport |
That is the clearest and most well thought out post in this whole thread.
Olen
-------------- Original message ----------------------
-Joe
> situation. The
> everything
> talking about
> I'm sure
> [lined up
> on the runway].
> on the
> -Rob
halbenjamin(at)aol.com Guest
Posted: Tue Mar 07, 2006 2:14 pm Post subject: Minimum altitude to return to airport |
Hi Doug,
Glad to see you're back in fray...Hope you stick around!
Hal Benjamin
RV-4 Fuselage
Long Island, NY
rcrosley(at)adelphia.net Guest
Posted: Wed Mar 08, 2006 8:53 am Post subject: Minimum altitude to return to airport |
This thread on "returning to the airport" has been interesting but very academic. Maybe the average guy can do a 180 and not stall, but there is a lot more going on. First, the transition from power on climb attitude to power off glide attitude is HUGE. Having lost an engine in a C-120 climbing out of Meadowlark airport (closed now, Huntington Beach CA) I was surprised at how big that transition is. After getting the nose down it was very obvious that a 180 was out of the question. I turned 30 degrees left and landed in a plowed field. But here's the point, if you lose your engine after a normal takeoff roll and climbing to 500 feet, how much runway are you going to have left to land on after making this 180? Not much. Probably more ahead of you than behind. You can tell the guys, "Yep, I made a 180 back to the airport." Probably be best to leave out the part about running off the end of the runway. Now, put yourself in a Rocket or Pitts. If you are making that cool 3000 fpm climb and the engine decides to take a break there are altitudes at which it is impossible to get the nose down, establish a glide and land the airplane before hitting the ground, forget the 180 degree turn. If you just cut off that thrust vector, things happen fast. Anyway, just some more stuff to think about.
Rich Crosley
RV-8 N948RC
Rosamond, CA
rv8ch
Posted: Wed Mar 08, 2006 9:38 am Post subject: Minimum altitude to return to airport |
| Quote: | ... First, the transition from power on
So true! If you don't believe Rich, go out and try it, at
altitude. Simulate a climbout just after takeoff, then
chop the power. Wow. The more power you have, the more
dramatic the difference, assuming a Vx type climb.
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
_________________ Mickey Coggins
http://www.rv8.ch/ |
jjessen(at)rcn.com Guest
Posted: Wed Mar 08, 2006 9:54 am Post subject: Minimum altitude to return to airport |
Energy management and relative wind is what it's all about, besides having
the ability under extreme duress to figure it all out in time. For me,
it'll be upset training in the future when I can afford it, just to better
understand what all is going on. In the meantime, I will make sure I know
what my straight ahead options are and prepare for that. I'm not yet
skilled enough to even think about turning back given the scenario being
discussed on this thread.
A Navion that took off in full view of myself and a few others ran into this
exact situation. Lost engine around 500'. Two souls on board. Great
pilot. All kinds of hours and experience, but by the time he kicked into
mental gear there was no runway left to put it down. He managed to turn it
almost 180, but landed off airport in a nursery full of 3' high evergreen
trees. If he hadn't been skilled enough to do this, the souls would
probably have gone elsewhere, but as it turned out, he and his wife made it
okay, after multiple bones being broken and a stay in the hospital. I've
stood and looked at that end of the runway a great deal since then and have
come to the conclusion I would not have made it.
When flying out of White Plains, a check ride CFI asked what I would do if
we lost power on take off. I told him my plan that day would be to go
straight ahead, probably try to make the lake that was across a freeway and
slightly to the left of the runway. He said he'd rather the freeway, which
I thought rather selfish, given the traffic there would create more carnage.
Neither one of us said turn back.
I think that practicing such maneuvers is appropriate, at safe altitudes.
Practicing glides, too. Practice it all. Practice. Practice. Practice.
And when you take off have that engine out scenario and decision points
firmly in mind...in terms of your ability and skill. Mine for now is
straight ahead. Hopefully I'll be able to have a few other options as I
become a more skilled pilot.
John Jessen
40328 (empennage)
bartrim(at)gmail.com Guest
Posted: Wed Mar 08, 2006 5:26 pm Post subject: Minimum altitude to return to airport |
I've been resisting the urge to make a reply as I don't have the time to do
much more than lurk these days, but here goes....
I really appreciate the info and discussion on this topic as I too believe
there are no absolutes in this decision making process. I did most of my
flight training in my own RV9 with a good friend of mine as instructor. He
initially endlessly drilled into my head to always land straight ahead in
event of power failure on T/O, but as training progressed he began to throw
a few extra scenarios at me. The terrain in northern BC demands it. One
little grass strip that we practiced on has a deep ravine at the end of the
runway. Enough altitude and you can turn back or make it to the other side.
Not enough and your best hope was to turn and try to crash along the bottom.
Not very appealing.
But allot of thought has gone into a particular strip that I used to fly
out of (as a pax), when I was a hunting guide. 2000' grass with mountains on
3 sides and a glacial fed lake on the end. You always had to T/O over the
lake regardless of wind direction. This lake is very remote so possibility
of rescue from boaters is almost non-existent in case of a water landing.
Help from anywhere out there is unlikely. (kinda like in the movie "The
Edge"... lotsa grizz too!) Every trip I ever had out of there was in a fully
loaded C172 that seemed to use every available inch of runway before we
would struggle out over the lake for a few miles until we gained enough
altitude to safely fly through a mountain pass. Turning back there was
certainly not an option but all other alternatives were also extremely grim.
Fortunately it has never been an issue.
Time has been at a premium these last few years, preventing me from
returning there but as I'm currently just finishing up my 5th and final year
of tech school I expect to soon be resuming some of these activities, but
this time with my own plane. As my RV9 has far greater climb rate and uses
far less runway, I expect to have more options in case of emergency.
Everytime I fly out of there I will be expecting that engine to fail and
will include in my preflight the exact min. altitude required for a 180 back
to the strip or as close to it as possible.
If I keep my plane in top mechanical shape then hopefully it will never
happen, but it is an experimental plane with an experimental engine, so by
keeping myself in top physical and mental condition then god willing, I will
have the strength and skill to accomplish something that I would never do at
that perfect airport with a farmers field at the end of each runway (kinda
like my home field .
I have limited flight experience so I don't like to disagree with
experienced voices such as Doug, but I feel that everyone that fly's in
areas of rugged terrain should be aware of exactly how much altitude they
require to make a 180 and be mentally prepared for it at all times to reduce
the "oh s***" time lag, and the judgment to recognize that a straight in
approach is still better for most cases. But it's not absolute.
Todd Bartrim
Turbo 13B RV-9
| Quote: | It's a rehash. We all know it's risky and we all know in most
cases you'd be better off landing in that near mythically
perfect field that's almost always mythically conveniently
located right off the end of almost all airports in the world.
Nobody ever takes off having to fly out over open water
http://www.airnav.com/airport/KMCD
and nobody ever has to take off right over the dense city
http://www.airnav.com/airport/KVNY
yep, there's just no reason to ever want to kill yourself turning
back when you can sometimes just as easily kill yourself going
straight ahead....
Posted: Thu Mar 09, 2006 10:44 pm Post subject: Minimum altitude to return to airport |
Not very appealing.
Todd Bartrim "chance favours the prepared mind" Louis Pasteur
Turbo 13B RV-9
straight ahead....
