ch701builder
Joined: 07 Feb 2006 Posts: 119 Location: N38.9947,W105.1305,ALT. 9,100'
Posted: Sat Sep 13, 2008 9:33 am Post subject: 701 Cabin side measurement |
701 builders,
Quick question, What is the length along the front of part 7F9-1 to the intersection of 7F9-7 (front upright)?
Can some of you scratch builders that have already been past this, or kit builders that have a side to measure help me out.
Here is my problem. On page 7F9, the plans show 7F9-7 intersects/meets 7F9-8 at 280mm from the front of the cabin side (center of the page drawing)
If I place 7F9-7 at that point, the top edge doesn't line up with the edge of the cabin side, (between the two R47 radius curves)
If I use 7F9-4 length of 132mm, then 7F9-7 intersects/meets 7F9-8 at 288mm, or if I use the length of both 7F9-4 and 7F9-5, then 7F9-7 intersects/meets 7F9-8 around 868mm.
Hope this is making sense.
I guess, another way of measuring might be, if somebody has a kit-built cabin side, how far out the front of the cabin side, and up from the bottom, to the end of a 730mm-7F9-7?
Keith
CH701--scratch (with questions)
This e-mail and any files transmitted with it may be proprietary and are intended solely for the use of the individual or entity to whom they are addressed. If you have received this e-mail in error please notify the sender.
Please note that any views or opinions presented in this e-mail are solely those of the author and do not necessarily represent those of ITT Corporation. The recipient should check this e-mail and any attachments for the presence of viruses. ITT accepts no liability for any damage caused by any virus transmitted by this e-mail.
rvickski(at)yahoo.com Guest
Posted: Sat Sep 13, 2008 10:39 am Post subject: 701 Cabin side measurement |
Just went and measured mine (plans built) the F9-7 intersects at 284-5 and is flush with the side between 47 radius curves. The top of 7F9-7 dies onto the .040 cabin side doubler 7F14-6SP and is not critical to assembly (wiggle room) except maybe when the cabin frame 7F18-1SP butts down to it, I think I had to trim the bottom of the frame tubes a little when I fit it. Do you have your cabin cage built?
Roy
ch701builder
Posted: Sat Sep 13, 2008 11:13 am Post subject: 701 Cabin side measurement |
Roy & Stan,
Those measurements are about where I am ending up at. and... No sir Roy, I do not have my cabin cage built. I am thinking about ordering 4130-welded parts from Zenith. I just wasn't sure how much room I had at the firewall end to wiggle. Stan's measurements where also what I was coming up with, but things just didn't seem to be working out.
Thanks again,
Keith
ch701builder
Posted: Sat Sep 13, 2008 12:47 pm Post subject: 701 Cabin side measurement |
All,
I found my "erorr"(oops) A bad measurement on my part, good thing I didn't cut any metal until I checked!!!!
Everybody have a good weekend!!!!
Keith
CH701 -- scratch
