Posted: Wed Sep 10, 2008 6:37 am Post subject: fuel line? |
I admit to a less than perfect system. My tanks are 20 year old chem
jugs from my old employer.
Probably held coil cleaner or cooling tower additive. Most likely
should get new ones
If I were to install a metal tank it would drain from the bottom
too. With a plastic one
I prefer not to weaken the floor with a hole.
I also have forgotten to shut power in emergency landings. Seem to
get too busy looking for
a good spot. Last time the pump was squirting fuel straight out of
the line. May have cleaned
the prop a little.
The thought offered about the exhaust direction possibly creating a
resonance will be considered.
BB
On 10, Sep 2008, at 10:09 AM, John Hauck wrote:
Quote: |
> To keep my tank pickups simple I have only straight dip tubes
with no
> floppy devices at the bottom.
> I cut the ends at an angle. I think they end about 3/8" from the
> bottom. I have some unusable fuel
> but I wouldn't be trying to get that last few ounces anyway.
> BB
Bob B:
I have always pulled fuel from the bottom of tanks, US, FS, and
mkIII. I don't want the engine to quit and still have a gallon of
gas in the tanks to crash with.
Never did like multiple tanks and dip tubes, but that is strictly
personal.
My engine driven pump does a good job of pulling fuel (flown at
14,500 feet MSL wide open throttle), although I help it along with
a Facet electric pump on takeoff, landing, and during low level
flight, which is most of the time. Would probably never get the
standby pump turned on if I lost an engine due to fuel pump on
takeoff, landing, or low level flying.
I figure if I get myself into an impending crash I can turn off the
master switch and alternator switch which will shut down the
electrical system, and isolate it all the way back to the battery.
However, don't think I have ever remembered to do this on any of my
crashes to date. Hardly ever hear of a post crash fire in a Kolb,
but there is always that one time. I don't want to be the victim.
Posted: Wed Sep 10, 2008 6:57 am Post subject: fuel line? |
Bob B:
I haven't used a plastic jug tank since 1990. Back then the wall thickness
of the jugs seemed to be quite a bit thicker than the jugs that are being
utilized today.
Popular in the UL world was a push in "elbow" pulling fuel out the bottom of
the tank. Used a large neoprene grommet. These worked well for me. Never
experienced any problems with them.
I am still scratching my head trying to figure why folks use plastic fuel
lines, when "good ole" black neoprene is readily available, cheap, durable,
and reliable. Only reason anyone has come up with is to see the bubbles in
the line. I think one of our fuel experts on the Kolb List some time back
offered that gasoline "gases". When placed in a vacuum, i.e., pulling fuel
uphill, it pulls gas out of the fuel that looks just like air bubbles. Back
in the good ole days when I was running UL fuel line like everyone else, my
fuel lines were always pulling bubbles. Used to drive me crazy. Pulling
air through the fuel system, yet no fuel was leaking out when the engine was
shut down or running. Now...I don't see it and am not bothered with it.
I have, during preflight inspections of my US and FS, pulled on a fuel or
pulse line and have it fail. Never had that problem with black neoprene.
_________________ John Hauck
Titus, Alabama |
JetPilot
Posted: Wed Sep 10, 2008 7:16 am Post subject: Re: fuel line? |
If you run a fuel pump below the level of the fuel and pressure feed it up to the engine, you will not have bubbles to worry about. It is possible to have an engine failure from pulling fuel up to much of a distance, and it will most likely happen during full power = Takeoff. The powerful fuel pump on the Rotax 912 does a pretty good job of pulling fuel uphill, but the gas can vapor lock under certain conditions which would lead to engine failure.
It is good practice to run an electric pump on takeoff and landing to pressure feed your engine driven pump. We had someone post that is so paranoid about fire, he says not to run an electric pump on takeoff which is wrong, he is more likely to induce an engine failure and crash by doing this. A fire after a crash can happen with or without an electric fuel pump running... It is foolish to be so paranoid about the remote possibility of a fuel pump causing a fire, that you create a much greater hazard of an engine failure. The best way to avoid a fire is to keep your engine running on takeoff and avoid a crash altogether.
Mike
Kolb MK-III Xtra, 912-S |
Dennis.Kirby(at)kirtland. Guest
Posted: Wed Sep 10, 2008 7:55 am Post subject: fuel line? |
<< Dennis, what kind of Tygon was it? Their yellow "Fuel and Lubricant
Tubing"? Or something else? -Dana >>
Dana - No, it was not the yellow-colored Tygon F4040 that Thom Riddle
describes.
Just some (mostly) clear "Tygon" that I ordered from Aircraft Spruce a
few years ago - I don't recall the exact description, besides that it
was advertised as fuel line.
Dennis Kirby
New Mexico
Posted: Wed Sep 10, 2008 8:04 am Post subject: fuel line? |
russ kinne wrote: << Dennis -- only way to fly safe is to check
EVERYTHING you can, whether you think it needs checking or not. Sounds
as tho your attention to detail avoided an in- flight engine-out. Good
man , nice going >>
Thanks, Russ!
After my preflight blunder of last summer (where I did not tighten my
oil cap and it went thru the prop, and I chose to execute a
precautionary landing on a "dry" lakebed - that wasn't exactly dry - and
I ended up having to haul my aircraft from the muck with a helicopter),
I guess I'm paying a little closer attention to the details of my
preflight check!
Dennis K.
Possums
Posted: Wed Sep 10, 2008 2:52 pm Post subject: fuel line? |
A lot of the degradation of the "blue fuel line" has to do with the sun.
If you'll notice - the bottom fuel line (maybe coming out
of your tank) inside the fuselage, will last a lot longer
than the fuel line going to your carbs that are exposed to direct sunlight
all the time.
_________________ Possum |
lucien
Posted: Thu Sep 11, 2008 5:49 am Post subject: Re: fuel line? |
John Hauck wrote: | Bob B:
the line.
mkIII |
The hazard with the fuel line from the auto parts store is that it's layered, usually with a webbing of some kind seperating the pleats. The idea here is it's designed for fuel systems that are under pressue, not under vacuum.
The problem is that the pleats can seperate over time; the inner pleat can then collapse under vacuum with the expected results.
This is a personal experience item, nothing I read off the Internet. The first time it happened to me was on one of my 503's (on my trike years ago, fortunately caught at a maintenance interval before it actually put me down in a field) was enough for me to make it the last time.
I've used only the tygothane clear line from the usual a/c suppliers ever since.
I'd love to run Aeroquip line as well, but I havn't researched how to deal with the fittings on my tank and on the Rotax fuel pumps for a good attachment.
The tygothane lasts a long time and is a proven good solution on our light Rotax powered a/c. Works for me...
LS
_________________ LS
Titan II SS |
lucien
Posted: Thu Sep 11, 2008 5:59 am Post subject: Re: fuel line? |
[quote="lucien"] John Hauck wrote: | Bob B:
the line.
mkIII |
Oops forgot my second point.
The other HUGE advantage, the main advantage I'd say, of the clear line is the ability to inspect it. Being able to inspect critical systems is the life blood of flying those systems through the air.
Opaque lines like the black neoprene lines cannot be inspected for problems without actually removing them and even then it's difficult to spot problems with the inner pleats in longer runs. So generally it just never is inspected except on the outside and it's quality has to be taken on faith. Not good......
The clear tygothane lines, on the other hand, can be easily and thoroughly inspected with it still on the plane and defects are easy to spot.
Don't ask me why I know this...
Having to change it out from time to time is, in my experience, a very small trade-off compared to the ability to inspect the lines conveniently and effectively. Well worth it...
LS
Titan II SS |
smlplanet(at)msn.com Guest
Posted: Thu Sep 11, 2008 6:13 am Post subject: fuel line? |
Some black fuel lines start breaking down when an oil mix is run thru them
after awhile and you can find small black pieces in the filer. The best
black fuel line would be a marine grade used for gas and oil mixes.
Sent: 2008-09-11 09:49
To: <kolb-list(at)matronics.com>
Subject: Re: fuel line?
Quote: |
John Hauck wrote:
> Bob B:
> durable,
> in
> the line.
> mkIII
under vacuum.
since.
attachment.
LS
LS
Titan II SS
http://forums.matronics.com/viewtopic.php?p 3797#203797
Dana
Posted: Thu Sep 11, 2008 8:55 am Post subject: fuel line? |
At 09:49 AM 9/11/2008, lucien wrote:
Quote: | The hazard with the fuel line from the auto parts store is that it's
under vacuum...
Not necessarily. Although most if not all newer cars have fuel injection
and an electric pump located in or near the fuel tank pushing the fuel,
there are lots of older cars out there using only an engine driven pump
pulling the fuel from the tank. I've owned some old cars with rubber fuel
line looking so crispy that you'd think a feather touch would make it
disintegrate, but it held even while the metal lines rusted out.
But I'll still use clear line on my various flying machines.
-Dana
Sometimes you're the windshield, sometimes you're the bug.
Beeman
Joined: 10 Jan 2006 Posts: 3 Location: Central MD Maryland
Posted: Fri Sep 12, 2008 6:16 am Post subject: fuel line? |
Hi everyone I just wanted to post some \ info I know about fuel line.
many years ago there was the blue fuel line which was suppose to be the
best.
and in many cases it was, until someone introduced some blue crap that
looked and felt the same as the
good stuff. I suggest throwing it all away. I made the mistake of
putting some of the bad crap in my
dip type fuel tank on trike. the hose broke off inside the tank It
didnt take long to go bad.
the yellow fuel line tubing is tygon 4040 and is NOT TYGOTHANE but
can be used for fuel but NOT recommended.
there are 2 types of fuel line I only use.
Tygothane C210 ESTER is formulated for all type of fuel
Superthane ESTER is supposed to be a near equivalent.
EITHER base will not hold up and will be a mistake.
this stuff can be colored if you buy a million or more feet. Probably
no one will buy
but generally the good stuff will be nearly clear
I personally use Superthane ester. I have an account with new age
Jackof mosttrades.
aslsa.rng(at)gmail.com Guest
Posted: Fri Sep 12, 2008 8:32 am Post subject: fuel line? |
I don't want to be the spelling Nazi here, just want to clarify. Did you mean ether based tubing as not being good to use when you mentioned Tygothane C210 and Superthane as being ester based and good to use? Thanks for the clarification.
Rick
On Fri, Sep 12, 2008 at 9:16 AM, trader(at)fotoubuff.com (trader(at)fotoubuff.com) <trader(at)fotobuff.com (trader(at)fotobuff.com)> wrote:
[quote]--> Kolb-List message posted by: "trader(at)fotoubuff.com (trader(at)fotoubuff.com)" <trader(at)fotobuff.com (trader(at)fotobuff.com)>
many years ago there was the blue fuel line which was suppose to be the best.
and in many cases it was, until someone introduced some blue crap that looked and felt the same as the
good stuff. I suggest throwing it all away. I made the mistake of putting some of the bad crap in my
dip type fuel tank on trike. the hose broke off inside the tank It didnt take long to go bad.
the yellow fuel line tubing is tygon 4040 and is NOT TYGOTHANE but can be used for fuel but NOT recommended.
this stuff can be colored if you buy a million or more feet. Probably no one will buy
Jackof mosttrades.
Beeman
Posted: Fri Sep 12, 2008 9:18 am Post subject: fuel line? |
I purchase quantities from the company, New age and
there is a difference in the formulation
Both The makers of Tygothane
and the makers of Superthane
recommend:
ESTER BASE Formulation for GASOLINE and fuels.
Either base is not as good.
Jackofmosttrades
RE
Tygothane C210 and Superthane as being ester based and good to use?T
Rick
Steve Boetto
Posted: Fri Sep 12, 2008 6:08 pm Post subject: fuel line? |
Lucien, If you follow this link you can see how I did it. I used Yamaha Outboard fuel line on the flex areas. I have used this type of line for years due to it's durability. If you opt to used the squeeze bulb, it is the best around. Part # 6Y1-24306-55. I have an old one that is ten years old and has always been used with oil mix.
http://www.sportpilot.org/magazine/feature/2008%20-%2007%20July%20-%20Building%20a%20Grand%20Champion%20Ultralight.pdf
Steve B
Firefly 007/Floats
Firefly 0040/ Floats 2008 SnF Grand Champion
In a message dated 9/11/2008 9:50:12 A.M. Eastern Daylight Time, lstavenhagen(at)hotmail.com writes:
Quote: | --> Kolb-List message posted by: "lucien" <lstavenhagen(at)hotmail.com>
the line.
LS
LS
Titan II SS
http://forums.matronics.com/viewtopic.php?p=203797#203797
Psssst...Have you heard the news? There's a new fashion blog, plus the latest fall trends and hair styles at StyleList.com.
Dave Bigelow
Joined: 29 Jan 2006 Posts: 103 Location: Kamuela, Hawaii
Posted: Sat Sep 13, 2008 12:21 am Post subject: Re: fuel line? |
Jack, do you have a source for these two types of fuel line?
Thanks.
_________________ Dave Bigelow
Kamuela, Hawaii
FS2, HKS 700E |
Thom Riddle
Posted: Sat Sep 13, 2008 4:01 am Post subject: fuel line? |
I copied the following from New Age's website. Note the bit about
water and about modern fuel additives. I could find nothing about
ethanol tolerance.
Notes
^^Hydrolytic Stability -- For resistance to moisture and fungus,
SUPERTHANE ether is recommended (Ester polyurethane does not react
well with water, prolonged humid conditions, or attack from fungus.)
The ether-based formulation is listed by the National Sanitation
Foundation (NSF 61). It also resists attack from ultra-violet rays
making it a good material for outside use.
SUPERTHANE PU tubing is much more resistant to pressure and vacuum
applications than corresponding sizes of PVC or rubber.
^Although polyurethane is commonly used in fuel applications, due to
additives in today's gasoline and petroleum products, field testing
should be performed.
Thom in Buffalo
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
lucien
Posted: Sat Sep 13, 2008 8:04 am Post subject: Re: fuel line? |
Now that's a super nice fuel system setup there.......
Personally, like I said I like to be able to inspect fuel line, at least any that isn't something I know has a very low chance of deteriorating like aluminum lines connected by AN fittings... So my personal preference is clear line.
Now that said, I wouldn't worry about something like aeroquip line which even tho it's opaque, it's also not the rank stuff from the auto parts place either .
Last line change on my plane I was trying to figure out how to go aeroquip, but I couldn't figure out how to get AN fittings on the fuel pump, carburettor and tank outlets. At least not without major mods and without just clamping the hose on there which would have been a little lame.....
I had also tried to work up a metal line up to where it needed to flex at the engine, but couldn't come up with a good solution.....
Yours is really nice tho...
LS
Titan II SS |
Posted: Sat Sep 13, 2008 9:18 am Post subject: fuel line? |
| LS
LS:
I got into UL'ing initially because it was the only way I could figure
out how to fly again after retiring as an Army aviator. I chose to
live on my retirement beginning at the ripe old age of 40. So far,
nearly 29 years later, I have survived and have thoroughly enjoyed my
last 24 years of experimental flying.
If I deleted all the items on my airplane that were obtained from
Wal-Mart and "rank stuff from the auto parts place", I would be
permanently grounded.
I find if a builder uses his head, he can obtain safe, reliable,
efficient hardware to keep his bird flying, at much less expense than
buying expensive aircraft stuff because it looks slick, and real
airplanes are Federally mandated to be equipped that way. Thank God
for a little freedom of choice. I am not knocking Steve B's
beautifully finished FF that walked off with the S&F Grand Champion UL
2008 trophy. However, I was able to bring home the same trophy in
1988 for my FS, plus two Gold Lindy Trophies from OSH, 1989 and 1993,
using my old philosophy of using good quality stuff that will get me
there and back without worrying whether it will or not, for half the
price.
I think the record of my airplanes indicates it can be done.
Been thinking about inspecting clear fuel line vs my black neoprene
fuel line. First, I can't see all my fuel line. Most of it is hidden
inside the fuselage. Based on my experience with plastic line, in
most cases, one could not tell if it was serviceable or not by looking
at it. Took a hand and a pull to see if it was going to fall apart or
not. Sometimes the pulse line or a fuel line would do just that.
The beauty of our system of experimental airplanes is, for the most
part, our freedom to equip and fly our aircraft the way we want to.
Personal choice means a lot to me and I respect others freedom for
personal choice.
However, I am still looking for a valid requirement to see the little
bubbles in my fuel line.
john h - Glad to hear everyone, so far, is ok down Texas way.
Titus, Alabama |
Steve Boetto
Posted: Sat Sep 13, 2008 3:35 pm Post subject: fuel line? |
Buddy John, No knock taken. Bryan and I were just showin off. It is far and above what is required for an Ultralight. It sure was fun doing it that way though. Much of what I do I have learned from the pioneers of UL like yourself. Past Trophy winners have set the Bar pretty high so you have to work hard to keep up. However, I do worry about the use of Gates Auto Fuel Line when you run oil mix through it. Had some break down on me.
Steve B
Firefly 007/Floats
In a message dated 9/13/2008 1:19:35 P.M. Eastern Daylight Time, jhauck(at)elmore.rr.com writes:
price.
Posted: Sat Sep 13, 2008 3:56 pm Post subject: fuel line? |
Steve B:
I have heard of folks having problems with fuel/oil mix and neoprene fuel line. However, it has been many years ago. Probably have not heard of problems now because I do not pay that much attention to two strokes and their inherent problems, unless I am going to be flying one at an air show.
I think this problem is like others we encounter. Its a one in a thousand or million thing. I imagine today there is good fuel line, line Yamaha Marine, that will get the job done. Must be.� Look at the thousands of jet skiis and snow machines that used neoprene fuel line and mixed fuel/oil in the old days.
Still looking for valid reasons to look at the little bubbles in the clear plastic line. No one has come up with a good reason yet. I think it is a carry over from the early days of UL'ing when everybody used it. Hell, I thought we were supposed to use it, when I got into UL'ing.
john h - with a freshly cut 750 feet of Gantt International Airport. Smoothed out the cow crap too!
[quote] Steve B
Titus, Alabama |
