		Steven Green
				 Posted: Sun Sep 14, 2008 9:26 am    Post subject: resonance 912 |
				Ted,
 Is the noise cyclicle in amplitude?  If so there may be two fundamental
 frequencies creating a "beat".  Is the wing fabric noticable tighter on one
 wing than on the other, in the prop area?
 If I remember correctly you said that the noise was independant of engine
 speed.  What about air speed, does it change with air speed?  Does it do it
 in a high speed decent with the engine at idle.
 Did you say it would do it during a static run up?
 Steven Green
 Hope to see ya'll in London soon
  _________________ Steven Green |
		tc1917(at)bellsouth.net Guest
				 Posted: Mon Sep 15, 2008 2:08 am    Post subject: resonance 912 |
				Okay, the easy answer first.  Yes, first time out the gate, at Miss Lite, a
 year ago October, I suspected that was it.  Was told by Ronny Smith that it
 was not the carbs, it needed the expensive four inch spacer (which I had but
 not installed).  I installed it.  Same-O.  Later, purchased vacuum gauges
 and went after the carbs.  Set them and checked them -- four times in so
 many months.  No joy.  Took off the four inch spacer and bought another two
 inch spacer (needed different bolts of course) still no joy.  balanced
 better for flying though and left it on.  Thought maybe it was noise from
 the prop hub and bought another expensive play pretty spinner.  Looks good.
 No workie.
 Now, it makes the noise on run up from about 3500 on, on the ground!!!!
 Makes no difference how fast I am flying, it is there.  I have it on decent
 for landing, feathered back, just not as loud, same beat though.  Taking
 off, full throttle, I dont notice it cause of all the extra noise but as
 soon as I pull back -- it says "I'm baaaack!".
 On to the fabric.  Although it maybe coming from there, why would it not
 change in beat?  I have taped up the wing area approximately where it should
 be on both wings, no change in sound.  I padded the back, sides, top inside
 and around, no change, just maybe not as loud to me in the cabin.  It is not
 a thumping sound.  It is a metallic sound to me as gears meshing or washers
 running.  I am so convinced it is in the gear box, I will PAY someone to
 check it (must be a qualified rotax mech) and then if it is in there, I can
 get it on warrantee.  Just wait and hear it yourself next week.  Going to be
 an expensive run from here to there but I just hope I will be able to get
 gas along the way.  See ya there.  Ted Cowan, Alabama, Slingshot 912UL
				 Posted: Mon Sep 15, 2008 6:01 am    Post subject: resonance 912 |
				Ted, this is a long shot, but are your cylinder compressions equal?
 BB
 On 15, Sep 2008, at 6:07 AM, Ted Cowan wrote:
  Lite, a year ago October, I suspected that was it.  Was told by
  Ronny Smith that it was not the carbs, it needed the expensive four
  inch spacer (which I had but not installed).  I installed it.  Same-
  O.  Later, purchased vacuum gauges and went after the carbs.  Set
  them and checked them -- four times in so many months.  No joy.
  Took off the four inch spacer and bought another two inch spacer
  (needed different bolts of course) still no joy.  balanced better
  Looks good. No workie.
  ground!!!! Makes no difference how fast I am flying, it is there.
  I have it on decent for landing, feathered back, just not as loud,
  same beat though.  Taking off, full throttle, I dont notice it
  cause of all the extra noise but as soon as I pull back -- it says
  "I'm baaaack!".
  it not change in beat?  I have taped up the wing area approximately
  where it should be on both wings, no change in sound.  I padded the
  back, sides, top inside and around, no change, just maybe not as
  loud to me in the cabin.  It is not a thumping sound.  It is a
  metallic sound to me as gears meshing or washers running.  I am so
  convinced it is in the gear box, I will PAY someone to check it
  Going to be an expensive run from here to there but I just hope I
  will be able to get gas along the way.  See ya there.  Ted Cowan,
		Dana
				 Posted: Mon Sep 15, 2008 8:38 am    Post subject: resonance 912 |
				One bit of useful data to solve the resonance problem is to know the
 frequencies.  When you hear a "beat frequency" resonance, like a twin
 engine airplane with the engines out of synch, the beat frequency is equal
 to the difference in the primary frequencies.  For example, if one engine
 is turning 3000 rpm and the other is at 3060 rpm, that's a 60 rpm
 difference or 1 cycle per second, i.e. the beat frequency would have a 1
 second period.
 Timing the beat period and comparing it to the other various speeds (engine
 rpm, exhaust pulse frequency, reduction ratio, etc.) may lead to a match
 which points to the source.
 -Dana
   He's dead, Jim.  Grab his tricorder and his wallet.
