pfstelwagon(at)earthlink. Guest
Posted: Thu Sep 18, 2008 9:59 pm Post subject: CJ-6 Schematic |
Does anybody have an electrical schematic for a CJ-6A with the solid state regulator installed. It seems that the Generator monitor light system is different than a standard CJ-6A.
Frank
N23021
dougsappllc(at)gmail.com Guest
Posted: Fri Sep 19, 2008 7:42 am Post subject: CJ-6 Schematic |
Frank,
The solid state regulator was a mod which was done at the air bases and was not "stock" to new aircraft comming from the Nanchang factory, so all dwgs (that I know of) will show the older mag type regulator.
I have owned 2 factory new (flying) CJ6's and two others which were damaged (in a trucking accident), all were mfg'd in 2000 or later, all four had the older style mag regulator.
Always Yakin,
Doug
On Thu, Sep 18, 2008 at 10:58 PM, Frank Stelwagon <pfstelwagon(at)earthlink.net (pfstelwagon(at)earthlink.net)> wrote:
| Quote: | Does anybody have an electrical schematic for a CJ-6A with the solid state regulator installed. It seems that the Generator monitor light system is different than a standard CJ-6A.
Frank
N23021
Always Yakin,
Doug Sapp
Phone 509-826-4610
Fax 509-826-3644
Posted: Fri Sep 19, 2008 8:42 am Post subject: CJ-6 Schematic |
Thanks Doug. I was afraid of that.
Frank
Posted: Fri Sep 19, 2008 9:34 am Post subject: CJ-6 Schematic |
Has someone installed a B&C system on the aircraft, or something else of
the same ilk? Or does the aircraft still use the same generator but
with a solid state control system?
Mark Bitterlich
ReadeG(at)Cairnwood.com Guest
Posted: Fri Sep 19, 2008 10:12 am Post subject: CJ-6 Schematic |
Mark/Frank:
We just completed a B&C alternator/regulator install on the Wilga -
although it is the AI14 engine I believe it uses the same mounting plate
as the stock CJ engine. Contact Morten Stoverud at
mortsaero(at)comcast.net or (856) 495-3159.
Reade Genzlinger
Cairnwood Cooperative Corporation
mailto:readeg(at)cairnwood.com
215.914.0370
Posted: Fri Sep 19, 2008 11:50 am Post subject: CJ-6 Schematic |
Yes it still uses the 50 AMP generator but a solid state regulator mounted
behind the pilots seat.
Frank
Posted: Sat Sep 20, 2008 1:32 pm Post subject: CJ-6 Schematic |
Wow. If you ever get an answer to your query on this thing, I'd like to have a copy of it as well.
Mark Bitterlich
From: owner-yak-list-server(at)matronics.com on behalf of Frank Stelwagon
Sent: Fri 9/19/2008 3:49 PM
To: yak-list(at)matronics.com
Subject: Re: CJ-6 Schematic
Frank
Posted: Sat Sep 20, 2008 1:34 pm Post subject: CJ-6 Schematic |
Hi Reade, no... slight misunderstanding. I am very familiar with the B&C stuff. In this case we are dealing with a stock generator with a solid state regulator. I have never seen anything like this.
Mark
From: owner-yak-list-server(at)matronics.com on behalf of Genzlinger, Reade
Sent: Fri 9/19/2008 2:12 PM
Subject: RE: CJ-6 Schematic
Mark/Frank:
Reade Genzlinger
215.914.0370
Posted: Sat Sep 20, 2008 6:01 pm Post subject: CJ-6 Schematic |
I don't think there is an answer.
Frank
