		grantr
				 Posted: Mon Sep 22, 2008 12:01 pm    Post subject: 100LL use in rotax 503? |
				It seems lately ethanol free gas is becoming harder to find. The last 30 gallons I have run through my 503  contained 10% ethanol according to the pump sticker. I might be crazy but I swear I can tell the difference in smell between the regular and ethanol blended gas.
 Anyway I know rotax does not recommended ethanol at all over I think 5% and they do allow use of av gas some of the time.
 I have heard of some people using exclusively 100LL in 2 strokes with no problems. Then I have heard that the lead will flat spot the bearing and cause deposits in  cylinder and foul the plugs more often.
 So far so good with the E fuel but I still don't like it.
 Is anyone using exclusively 100LL in a 2 stroke rotax?
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Mon Sep 22, 2008 12:48 pm    Post subject: 100LL use in rotax 503? |
 Grant R:
 I used a lot of 100LL during my travels with old Firestar and point ign 447.
 This was in the 1980's.  I doubt there would be any difference now as then.
 Hope 100LL doesn't flat spot bearings, because I burn an awful lot of it in
 my 912ULS loaded with bearings.
 I always ran my two strokes hard, as I do my 4 strokes.  I cruised at 5,800
 rpm, the recommended cruise power for all the current Rotax two strokes.
 Sometimes, when I got closer to home after a long trip, I'd push it on up to
 6200 rpm and let it rip.
 I am a firm believer in running the engines as they were designed, not
 babying them, but keeping them blown out and clean.  4 to 5 thousand rpm
 hardly keeps a two stroke crankcase free from excess oil.
 My thoughts only, for what they are worth.
 _________________ John Hauck
Titus, Alabama |
		grantr
				 Posted: Mon Sep 22, 2008 1:23 pm    Post subject: 100LL use in rotax 503? |
				Grant R:
 Probably leaves less carbon deposits, but some lead deposits.
 Spark plugs are cheap.  I would not skimp when it came to changing them out.
 Usually, you can pull the plugs, use a small pin knife blade and a piece of
 safety wire to clean the lead out of the plugs.  I end up doing that
 occasionally on the 912ULS on long cross country flights.
   I don't have a problem babying my 503 on my Mk III she has to turn about
 5700 to 6000 to cruise.
  Did the spark plug last as long with the 100LL. How about combustion
  deposits and carbon build up?
  Grant
Titus, Alabama |
		grantr
		Dana
				 Posted: Mon Sep 22, 2008 4:12 pm    Post subject: 100LL use in rotax 503? |
				Not a reason to choose a fuel, but an interesting aside:  When my friend's
 MKIII crashed this weekend, the DEP was on the scene because all the fuel
 leaked out of the plane into the ground, close to the river and to a
 well.  He was quite concerned if it was leaded aviation fuel (it
 wasn't).  Either way the pilot (or the pilot's insurance) will have to pay
 to have the soil dug up and disposed of.
 -Dana
   Sometimes you're the windshield, sometimes you're the bug.
		herbgh(at)nctc.com Guest
				 Posted: Mon Sep 22, 2008 4:13 pm    Post subject: 100LL use in rotax 503? |
				If a bearing(ball or roller or needle) slides rather than
 rolls,,,then there can be irregular wear.. Herb
 At 06:56 PM 9/22/2008, you wrote:
 Thanks John,
 I only head that from one person regarding 100LL  flat spotting
 bearing. I have not seen that posted any where else.
 Looks like I am going leaded [Wink]
 http://forums.matronics.com/viewtopic.php?p 5593#205593
		Jim Baker
				 Posted: Mon Sep 22, 2008 4:53 pm    Post subject: 100LL use in rotax 503? |
				X-SpamReason %%SpamReason%%:
  posted by: herb <herbgh(at)nctc.com>
 Herb makes a good point...the same can be achieved by using too much
 oil...just how much is too much is uncertain...wherein the oil
 creates a hydrodynamic wedge that causes the ball/needle to slide
 instead of roll.
 Jim Baker
 580.788.2779
 Elmore City, OK
		Steven Green
				 Posted: Mon Sep 22, 2008 5:10 pm    Post subject: 100LL use in rotax 503? |
				This is good information on bearings, but doesn't rolling element skidding
 have more to do with minimum loading, bearing alignment, and lubricant
 viscosity than lead additive in the fuel?  Maybe I am missing something, I
 usually do.
 Steven
  instead of roll.
  Jim Baker
  580.788.2779
  Elmore City, OK
 _________________ Steven Green |
		Possums
				 Posted: Mon Sep 22, 2008 5:41 pm    Post subject: 100LL use in rotax 503? |
				At 08:10 PM 9/22/2008, you wrote:
 friend's MKIII crashed this weekend, the DEP was on the scene
 because all the fuel leaked out of the plane into the ground, close
 to the river and to a well.  He was quite concerned if it was leaded
 aviation fuel (it wasn't).  Either way the pilot (or the pilot's
 insurance) will have to pay to have the soil dug up and disposed of.
 -Dana
 Yeah, when I sunk mine in the lake, the Corp of Engineers were more
 concerned about
 wether or not I might still have fuel in my tank that could leak,
 than just about
 anything else. Like every boat & jet ski sloshing back & forth all
 day long never spilled a drop.
		|  Description: |
		|  Filesize: |
		 53.02 KB |
		|  Viewed: |
		 426 Time(s) |
 _________________ Possum |
				 Posted: Tue Sep 23, 2008 4:00 am    Post subject: 100LL use in rotax 503? |
				disposed of?  in other words they dig it up and move it to another
 spot..-problem solved?.... no
 transplanted maybe.  How many of us have gotten a good mouthful of
 the old leaded stuff
 trying to prime a gas transfer?
 Me?, brain-damaged?  nahhhhhh
 BB
 > close to the river and to a well.  He was quite concerned if it
 > was leaded aviation fuel (it wasn't).  Either way the pilot (or
 > the pilot's insurance) will have to pay to have the soil dug up
 > and disposed of.
 > -Dana
  concerned about
  than just about
  day long never spilled a drop. <Torpedo Sullivan.jpg>
		russ(at)rkiphoto.com Guest
				 Posted: Tue Sep 23, 2008 7:48 am    Post subject: 100LL use in rotax 503? |
				I believe the DEP requires that fuel-contaminated soil be BURNED --
 like, cremated. That's one  reason  why it costs so much.
 The air pollution may well be worse than burying it -- but that's the
 Gov't for you.
 A residence  nearby had a fuel-oil leak that cost over $100-K.
 do not repeat!
 On Sep 23, 2008, at 7:58 AM, robert bean wrote:
  BB
  _
		pj.ladd(at)btinternet.com Guest
				 Posted: Tue Sep 23, 2008 8:22 am    Post subject: 100LL use in rotax 503? |
 like, cremated.>>
 Good grief.  i can see the pointof all this if a tanker had crashed but for
 5 gallons?
 Pat
		Dana
				At 07:58 AM 9/23/2008, robert bean wrote:
 I didn't say it made sense...
 -Dana
   I'm as confused as a baby in a topless bar.
		aslsa.rng(at)gmail.com Guest
				 Posted: Tue Sep 23, 2008 9:22 am    Post subject: 100LL use in rotax 503? |
				Hey guys, I have a well for my drinking water. Somebodies spills a quantity of any petroleum product and it gets in the aquifer and I'm screwed. So yeah, dig it up and take it elsewhere. And now back to the Kolb show, already in progress.
 Rick
 Government of the people, by the people, and for the people. You wanna criticize the government? Look in the mirror.
 On Tue, Sep 23, 2008 at 11:20 AM, Dana Hague <d-m-hague(at)comcast.net (d-m-hague(at)comcast.net)> wrote:
  [quote]--> Kolb-List message posted by: Dana Hague <d-m-hague(at)comcast.net (d-m-hague(at)comcast.net)>
   	  | Quote: | 	 		   --> Kolb-List message posted by: robert bean <slyck(at)frontiernet.net (slyck(at)frontiernet.net)>
  -Dana
		ulflyer(at)verizon.net Guest
				 Posted: Fri Sep 26, 2008 10:08 pm    Post subject: 100LL use in rotax 503? |
				There may be another advantage to using 100LL, I feel the fuel at
 least without oil does not go stale nearly as fast as auto fuel.  So
 if you planes sits a while between flights, it might pay off.  With
 oil ???  I still feel it would stay fresher, longer.  Just my opinion
 based upon experience.
 jerb
 Thanks John,
