No Title
rwtaylorjar(at)HOTMAIL.CO
PostPosted: Thu Sep 25, 2008 2:22 pm    Post subject: No Title Reply with quote
Has anyone fitted a Trutrak 2 axis auto pilot to a 601 XL?I Cm trying to fit the altitude hold servo and it will not go where trutraks drawing shows C it interferes with the rudder cable.Any help would be apreciated.Two emails and two phone calls to trutrak and have had no response.Photo attached
cookwithgas
PostPosted: Fri Sep 26, 2008 4:38 am    Post subject: Re: No Title Reply with quote
The Trutrak folks are great - just send them an email. They travel a lot to promote the products. I had to go through three ADI's before they got it right, but they hung in there with me and took care of it. Andrew Barker is the General Manager (andrew(at)trutrakap.com).
wa7dvd
PostPosted: Fri Sep 26, 2008 4:34 pm    Post subject: Re: No Title - Tru Trak servos Reply with quote
I spent considerable time installing the Tru Trak servos in my XL. It seems that the rudder cables were located differently in rev 1 drawings and the pitch servo fits with the cables that position. In rev 2 and rev 3 drawings the rudder cables were moved (I believe to reduce cable interference with each other) and the pitch servo does not fit. I originally installed the cables as per rev 3 drawing. To make the servo work I moved them back to the original position and then installed several extra fairleads to make sure to make sure the cables do not interfere with each other. Everything seems to fit now. Here are some photos of what I did.
BK Johnson
601XL - N601BK (reserved)
 Filesize:  156.92 KB
 Viewed:  492 Time(s)
 Filesize:  144.62 KB
 Viewed:  496 Time(s)
 Filesize:  123.99 KB
 Viewed:  463 Time(s)
 Filesize:  135.64 KB
 Viewed:  469 Time(s)
 Filesize:  150.55 KB
 Viewed:  485 Time(s)
 Filesize:  137.21 KB
 Viewed:  482 Time(s)
 Filesize:  125.29 KB
 Viewed:  470 Time(s)
 Filesize:  138.73 KB
 Viewed:  479 Time(s)
BK Johnson
Zodiac 601XLb
Jabiru 3300a
N601BK
PostPosted: Sat Sep 27, 2008 3:21 pm    Post subject: No Title Reply with quote
Thanks Mate C
This explains it all.
I don't no why Trutrak could not tell me this.
Rob
Subject: Re: No Title
Date: Fri C 26 Sep 2008 17:34:39 -0700
--> Zenith-List message posted by: "wa7dvd" <wa7dvd(at)comcast.net>
BK Johnson
BK Johnson
Zodiac 601XL
N601BK (reserved)
http://forums.matronics.com/viewtopic.php?p=206390#206390
http://forums.matronics.com//files/dscn1249_202.jpg
http://forums.matronics.com//files/dscn1248_952.jpg
http://forums.matronics.com//files/dscn1227_366.jpg
http://forums.matronics.com//files/dscn1226_188.jpg
http://forums.matronics.com//files/dscn1219_476.jpg
http://forums.matronics.com//files/dscn1216_134.jpg
http://forums.matronics.com//files/dscn1215_205.jpg
http://forums.matronics.com//files/dscn1214_193.jpg
&gt=======================
&g=====================
Play now to win prizes for you andhref=http://www.friendmagnet.com.au' target='_new'>Are you a friend magnet? [quote][b]
