Fergus Kyle
Joined: 03 Jun 2007 Posts: 291 Location: Burlington ON Canada
Posted: Tue Sep 30, 2008 8:29 am Post subject: 914 Coolant temp & Dynon EMS-D10 |
I have begun to apply a dedicated 5Vdc line to a coolant sensor for
my 914. I am using a Dynon EMS-D10 display for engine parameters and
wonder what sensor you use to accomplish this......... According to the
Dynon manual I can use GP#3 function (pin 23 - purple/green) - page 2-12
AND GP#3 function (pin 18 -white/red) -page 2-16.
Confusion - what am I missing? - aside from gray matter.
If you have this combination, what did you do?
In hope,
Ferg Kyle
Europa A064 mono
 Download |
| Filename: |
winmail.dat |
3.23 KB |
| Downloaded: |
366 Time(s) |
hdwysong
Posted: Wed Oct 01, 2008 10:13 pm Post subject: 914 Coolant temp & Dynon EMS-D10 |
| Quote: | Cheers,
We're using a UMA 1B1 1/8" NPT probe with our MGL RDAC to measure 914
coolant temps, Ferg.
It's a 2-wire device with an isolated case, but if you pull one of the
wires to ground it will can be wired like the figure on 3-16 of your
installation manual (or like the figure on 3-13) using the +5V
excitation (pin 1 and the GP input (pin 23) you noted.
Pull one of the sender wires to ground. Pull the other sender wire
through a "Y" to pin 23 and to pin 18 via the pullup resistor. The 1K
pullup should be adequate but it's worth a call to Dynon to verify
once you decide which sender to go with. If you need the calibration
curve (Ohms vs temp) for the UMA sender just send me an email. We had
to pry the data out of 'em since the curve didn't come with the
sender.
D
