dcw(at)dddirectories.com Guest
Posted: Fri Oct 03, 2008 5:27 am Post subject: TowbarsTowbars |
Thanks for the info on the Power Tow. Are you using it on grass or concrete?
Any challenges with balance using one tire?
David
N2733K
rene(at)felker.com Guest
Posted: Fri Oct 03, 2008 5:54 am Post subject: TowbarsTowbars |
Wide tire, so not really a balance problem. Once you hook it to the nose
wheel it is very stable.
I am using it on asphalt and concrete. Slight up hill and have to push it
over a ~1.5 inch lip. No problems with doing that. I built little ramps to
get over the lip just to make it easier.
I have no experience on grass, but I would not think it would be a problem,
you can push down on the handle to get better traction......
Rene' Felker
RV-10 N423CF Flying
801-721-6080
lbgjb10
Posted: Fri Oct 03, 2008 7:10 am Post subject: Re: TowbarsTowbars |
The 'standard' tow bar that a lot of 10 users have (http://www.bogert-av.com/bogi-bars.php) has an extension that you can get that will allow it to be hooked to golf cart, lawnmower etc. I've ordered one, but haven't tried it yet, but looks like it should work. Biggest concern I would have with ANY towbars is that it might slip as you push. don't ask how I know (previous airplane!!) The tow bar with slight addition, also does a very good job as a rudder gust lock. larry
_________________ Larry and Gayle N104LG |
jcumins(at)jcis.net Guest
Posted: Fri Oct 03, 2008 8:46 am Post subject: TowbarsTowbars |
I to have a Power tow, and move a Saratoga up a slope with no problems at
all.
Will be adapting it to the rv-10 when done
John G. Cumins
President
JC'S Interactive Systems
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
