changing bungee
keystone(at)gci.net
PostPosted: Tue Oct 07, 2008 7:14 am    Post subject: changing bungee Reply with quote
Hi
After 5 years and 400 hours I am thinking of changing the nose wheel bungee
this winter. Does anyone have a bungee installation tool that I could
borrow? I would be happy to pay the freight to Alaska and back.
Bill Wilcox
N801BW
405 hrs
Off floats and back on wheels.
Thinking of keeping the 82" prop on and installing an AL block to raise the
nose.
Geoff Heap
PostPosted: Wed Oct 08, 2008 3:38 am    Post subject: Re: changing bungee Reply with quote
Bill. You can do this for lack of a better tool. Attached is a photo of a Breaker bar I use. 1/2" I think. I cut the handle down to allow use while my rotax 912 is still installed. I cut it to suit so that it just misses everything. One hand has the necessary leverage to lift on and off. You have to slip the bungee onto the tool before lowering it. Installing a new one is easier. I have no plans on buying a tool as this works fine. I havn't tried it yet with all the hoses and cables in place....Geoff
 Filesize:  643.81 KB
 Viewed:  569 Time(s)
Dan Stanton
PostPosted: Fri Oct 10, 2008 3:30 pm    Post subject: Re: changing bungee Reply with quote
Bill, I have a home made rig that I used for our plane. You are welcome to use it if you want. Kind of heavy tho.
