dave(at)davelaird.com Guest
dsavarese(at)elmore.rr.co Guest
Posted: Thu Mar 09, 2006 8:56 am Post subject: CJ6 main wheel tire change |
1- Remove the wheel assembly from the airplane
2- Deflate the tire by removing the valve core
3- Look at the valve stem and you will see a nut and washer holding the
valve stem in place on the rim. Remove the nut and washer.
4- Use two large screwdrivers or similar tools, insert the screwdriver or
tool between the tire and outside rim. Press down on the screwdriver to
release the tire bead from the rim. Do this in several locations around the
rim until the bead has broken away from the rim. Repeat for the other side
of the rim and tire.
5- Once both the top and bottom tire beads have been broken away from the
rim, place the wheel assembly on a suitable pad with the brake drum down.
Now press the outside of rim down. The two large semi-circular clips will
release between the rim and the hub. Remove the clips noting precisely
which way you removed them. They are not the same length from the notch to
the end in both directions. It is important when reassembling the rim to
make sure one end of the clip is NOT extending over the valve stem area.
6- After the clips are removed, lift the outer rim up and away from the hub.
Next lift the tire and tube up and away from the hub. There should be a
thin metal sleeve over the valve stem. It has a 90 degree bend at the top
with a hole in it for the valve stem.
Reassembly
7- Spread talcum powder or similar inside the new tire. This will allow the
tube to slide uniformly inside the tire when you inflate it.
8- Find the red dot on the new tire. Insert the tube and align the valve
stem with the red dot on the new tire. Remove the valve core from the new
tube. Inflate the tube in the new tire to evenly spread the tube inside the
new tire. Allow the tube to deflate. Again, check the alignment of the
valve stem on the tube to the red dot. Be sure to keep the rubber valve
stem guard on the tube.
9- Spray some soapy water on the beads of the tire.
10- With the valve stem up, place the new tire and tube over the hub.
11- Next place the outer rim over the hub, being sure you align the notches
of the rim to the hub. These are for the big clips to fit into. Once
again, check the alignment of the valve stem to the red dot on the tire.
Realign if necessary.
12- Place the metal sleeve back over the valve stem.
13- Place the washer and screw the nut loosely onto the valve stem.
14- Place the large clips on the rim making sure one end does not cover the
opening of the valve stem. The clip should not protrude at all into the
valve stem cavity.
15- Press down firmly on the outer rim and while doing so press the large
clips in place. Once in place they will lock the rim to the hub.
16- Insert the valve core into the valve stem.
17- Inflate the tire making sure the clips seat properly between the rim and
hub.
18- Tighten the nut on the valve stem to allow the valve stem to protrude
approximately 1/2" or above the nut.
Any questions, please ask.
Dennis
Posted: Thu Mar 09, 2006 9:44 am Post subject: CJ6 main wheel tire change |
great post!
thanks dennis!
Dave
wlannon(at)cablerocket.co Guest
Posted: Thu Mar 09, 2006 10:04 am Post subject: CJ6 main wheel tire change |
Hey Dennis, et al ---
Don't have time to read the whole article right now but I do suggest you
through those screwdrivers away. That is a guaranteed method of causing
irreparable damage to the wheel.
If absolutely necessary you may use tire irons with great care (right shape,
no sharp edges) but even that is usually not required. The right tool is a
heavy dead blow rubberized mallet and maybe an extra guy to stand on the
opposite side.
Later;
Walt
Posted: Thu Mar 09, 2006 11:33 am Post subject: CJ6 main wheel tire change |
Hi Walt,
You're correct about the tire irons. I have tried the supersized dead blow
hammers and had no luck with them. As an alternative I have taken the wheel
assembly to an automotive tire store where they have the air driven tire
bead breaking equipment. It takes them about 2 seconds and they usually
don't charge you any money because it was so quick.
Dennis
KingCJ6(at)aol.com Guest
Posted: Thu Mar 09, 2006 12:56 pm Post subject: CJ6 main wheel tire change |
Harbor Freight has a simple "Mini-tire Changer" for $39 that works great.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=34552
Dave
In a message dated 3/9/2006 11:35:26 AM Pacific Standard Time, dsavarese(at)elmore.rr.com writes:
| Quote: | --> Yak-List message posted by: "A. Dennis Savarese" <dsavarese(at)elmore.rr.com>
Hi Walt,
Dennis
Posted: Thu Mar 09, 2006 2:02 pm Post subject: CJ6 main wheel tire change |
Dave,
Thanks for the info.
Dennis,
The hanger now has a tire bead breaker on the way.
Doc
Posted: Thu Mar 09, 2006 2:14 pm Post subject: CJ6 main wheel tire change |
funny....
MY hangar now ALSO
has a tire bead breaker on the way, too....
Dave (Laird) also thanks Dave (King)
On Mar 9, 2006, at 4:00 PM, Roger Kemp wrote:
| Quote: | Dave,
Dennis,
Doc
f
cpayne(at)joimail.com Guest
Posted: Thu Mar 09, 2006 4:20 pm Post subject: CJ6 main wheel tire change |
Good description Dennis, but don't forget the 3 short little pins that fit UNDER the clip halves that align the 2 wheel halves. They fiendishly and steathily drop out on the hanger floor without notice!
Craig Payne
cjpilot710(at)aol.com Guest
Posted: Thu Mar 09, 2006 4:30 pm Post subject: CJ6 main wheel tire change |
Don't forget to use a little MMO, or WD 40 or even Mouse Milk. Makes releasing that bead a whole lot eraser.
Pappy
Posted: Thu Mar 09, 2006 8:13 pm Post subject: CJ6 main wheel tire change |
Mouse mIlk? How do you keep the little buggers from biting through your gloves when you pinch their teats!
Doc
Posted: Thu Mar 09, 2006 10:23 pm Post subject: CJ6 main wheel tire change |
Well, OK, but make sure all that stuff is 100% removed before you install the new tire. Must be clean and dry. If not you may find your tire rotating on the wheel during brake application and shearing off the tube stem. Not good.
If you are re-installing the same tire don't do that.
Good plan to paint creep marks on the wheel and tire after installation so you can check for movement.
Walt
Mike Bell
Posted: Thu Mar 09, 2006 10:41 pm Post subject: Re: CJ6 main wheel tire change |
Are Yak-52 wheels the same?
_________________ Mike Bell
Elk Grove, CA
avbell2(at)comcastdotnet |
Posted: Thu Mar 09, 2006 10:56 pm Post subject: CJ6 main wheel tire change |
Yes.
Walt
pilling.k(at)btconnect.co Guest
Posted: Fri Mar 10, 2006 1:40 am Post subject: CJ6 main wheel tire change |
Place the wheel on a piece of MDF board. Have a friend hold it and then
guide you
to drive your car tire (tyre) over the sidewall rubber to rubber. Its what
the auto
guys do when no bead breaker equipment is available......works every time
and
the MDF prevents any scratching of the rim and the rubber to rubber is
gentle
but persuasive.
kp
ps. bin those screwdrivers, Done properly no levers are needed.
Posted: Fri Mar 10, 2006 5:24 am Post subject: CJ6 main wheel tire change |
If I'm not mistaken, they are only on the nose wheel hub because the nose wheel hub does not have the square center piece on the clip that keeps the rim from rotating on the hub. The pins keep the nose wheel rim from rotating on the hub. At least that's true on the Yak 52.
Dennis
Posted: Fri Mar 10, 2006 5:56 am Post subject: CJ6 main wheel tire change |
Yes, they are. Unless of course you have a 52W or TW, which have Cleveland
wheels and brakes.
Dennis
