dmaib@me.com
Posted: Sat Oct 11, 2008 8:43 pm Post subject: Alternate Static Air Valve |
A couple of years ago, I saw a mechanical switch/valve to control alternate static air in one of the forums. It was panel mounted. I cannot find anything in the archives about it. Does anyone happen to have information about that valve?
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
dogsbark(at)comcast.net Guest
Posted: Sat Oct 11, 2008 10:53 pm Post subject: Alternate Static Air Valve |
Dave,
I can't remember where to get it, but I believe it's made by Clippard.
Sean Blair
#40225
brows [quote][b]
hotwheels
wayne.e(at)grandecom.net Guest
Posted: Sun Oct 12, 2008 4:00 am Post subject: Alternate Static Air Valve |
David,
I installed a alternate static source that I got from Safeair1 http://www.safeair1.com/SA1_products/AirKits.htm They sell a complete pitot static system that I think is quite good. This alternate air is very simple to install, you just put a connector inline to your pitot/static system with a pull cord to activate the alternate air. I installed the alternate air under the panel just forward of my left knee so I can just reach down and pull out the quick release plug if I need to.
Wayne Edgerton #40336
flying N602WT
Time: 09:44:04 PM PST US Subject: Alternate Static Air Valve From: "dmaib(at)mac.com (dmaib(at)mac.com)" <dmaib(at)mac.com>
David Maib
RV-10 #40559
dmaib@me.com
Posted: Sun Oct 12, 2008 4:36 am Post subject: Alternate Static Air Valve |
Thanks Sean!
David Maib
40559
On Oct 12, 2008, at 1:51 AM, dogsbark(at)comcast.net (dogsbark(at)comcast.net) wrote:
Dave,
Sean Blair
#40225
brows | Quote: |
RV-10 #40559
Posted: Sun Oct 12, 2008 7:08 am Post subject: Alternate Static Air Valve |
I went through figuring out which one to get awhile back. there's some information here:
http://tinyurl.com/4el5m3
cj
dlm46007(at)cox.net Guest
Posted: Sun Oct 12, 2008 10:24 am Post subject: Alternate Static Air Valve |
Curtiss valve is used. Check far left of panel and zoom in.
563.99 KB |
395 Time(s) |
Dave(at)AirCraftersLLC.co Guest
Posted: Sun Oct 12, 2008 11:07 am Post subject: Alternate Static Air Valve |
I used McMaster-Carr P/N 6791T13, for $11. It works great. It was in the
system for the static check to 20,000'--no leaks.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
daveleikam(at)wi.rr.com Guest
Posted: Sun Oct 12, 2008 12:06 pm Post subject: Alternate Static Air Valve |
I have this page bookmarked:
http://www.asapmachineryrepair.com/airvalves2.htm
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
johngoodman
Posted: Sun Oct 12, 2008 1:25 pm Post subject: Re: Alternate Static Air Valve |
David,
There is also a panel mounted switch that somebody bought from McMaster-Carr. Look for part number 6791T12 for $14.15 (metal switch) or 6791T13 for $11.51 (plastic switch).
Tim Olson
dmaib@me.com
Posted: Sun Oct 12, 2008 5:30 pm Post subject: Alternate Static Air Valve |
Thanks again to all for the alternate static source valve info. Lots
of good choices.
David Maib
40559
Finishing
On Oct 12, 2008, at 6:32 PM, Tim Olson wrote:
David,
I used something like these:
http://www.discoverysciences.com/product.aspx?id 258
http://www.discoverysciences.com/uploadedFiles/Site_for_Catalog_2008/
gc/GC_Accessories/Valves/valves.pdf
https://www.technical-controls.com/product.asp?prodid=3422
You can get them locally I'm sure. There are parker distributors
all over the place. I used to deal with a parker rep from the cities
for our company when I worked at Cray/SGI. All this stuff
is easy to get. I didn't put mine on the panel...I put it just below
the left side air vent on the side panel. That's where they located
it on my old beech. It's easy enough to get to for the almost
never occasion that you'll need it.
dmaib(at)mac.com wrote:
-------- David Maib RV-10 #40559
http://forums.matronics.com/viewtopic.php?p 8341#208341
RV-10 #40559
