Collins TDR-950 & Narco 500 Help
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List
zenithlist(at)yahoo.com
PostPosted: Sun Oct 05, 2008 7:16 am    Post subject: Collins TDR-950 & Narco 500 Help Reply with quote
I am looking for pinouts for Collins TDR-950 transponder & Narco 500 altitude encoder so I can connect them together. Does anyone have the pinouts?
- The Matronics Avionics-List Email Forum -
http://www.matronics.com/Navigator?Avionics-List
hdwysong
PostPosted: Mon Oct 06, 2008 3:03 pm    Post subject: Collins TDR-950 & Narco 500 Help Reply with quote
de encoder so I can connect them together.- Does anyone have the pinouts?
They're available on the AeroElectric site, John:
http://www.aeroelectric.com/Installation_Data/
See TDR950-950L.pdf and AR500-850.pdf.
dougritter(at)frontiernet
PostPosted: Mon Oct 06, 2008 5:36 pm    Post subject: Collins TDR-950 & Narco 500 Help Reply with quote
Try the attached pinouts
Doug Ritter:
 Filesize:  160.66 KB
 Viewed:  1098 Time(s)
PostPosted: Sun Oct 12, 2008 8:06 am    Post subject: Collins TDR-950 & Narco 500 Help Reply with quote
Thank you all for pointing and providing info for the pinouts. I will make the wiring harness to connect the transponder & encoder next and powering on the devices. Beside sending these devices to avionic shop, are there any testing instructions on what to look for and to confirm they are working or not? I am somewhat knowledgable with electronics and have testing devices such as scope and frequency counter.
Vince Palermo
PostPosted: Sun Oct 12, 2008 8:26 am    Post subject: Collins TDR-950 & Narco 500 Help Reply with quote
Power up the system without the units plugged in and check the power and ground pins.
Vincent Palermo
vpalermo(at)tampabay.rr.com (vpalermo(at)tampabay.rr.com)
On Oct 12, 2008, at 12:04 PM, John Smith wrote:
[quote]Thank you all for pointing and providing info for the pinouts. I will make the wiring harness to connect the transponder & encoder next and powering on the devices. Beside sending these devices to avionic shop, are there any testing instructions on what to look for and to confirm they are working or not? I am somewhat knowledgable with electronics and have testing devices such as scope and frequency counter.
Vincent J. Palermo
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List All times are GMT - 8 Hours
