timb
Joined: 16 Apr 2008 Posts: 77 Location: Frankston, Texas
Posted: Sun Oct 12, 2008 12:09 pm Post subject: Brake Pad replacement |
My RV-6 is in need of new brake pads after 120 hours. This seems a bit pre-mature but it needs them none the less. I just looked on Vans site and they show brake lining kit with rivets. Does this require a special rivet device? At 30 bucks I can’t surmise it would be very cheap to buy the pads with the backing already on. Questions:
Is 120 hours sooner than normal for needing brake pads?
What do I use to rivet on the linings?
Is there a reasonable availability somewhere for complete brake pads?
Tim Bryan
RV-6 Flying
N616TB over 100 hours now
_________________ Tim Bryan
RV-6 Flying
N616TB |
rhdudley1(at)bellsouth.ne Guest
Posted: Sun Oct 12, 2008 12:30 pm Post subject: Brake Pad replacement |
Hi Tim,
I decided to replace my pads around the 120 hour point. Could have gotten a few more miles but at annual time it seemed most convenient. Getting everything apart for bearing maintenance is the most time consuming. Replacing the pads is easy and quick. The kits from Van's contain the rivets. The tool is inexpensive from Spruce. See: http://www.aircraftspruce.com/catalog/topages/brakeliningrivset.php
Rich Dudley
6A flying and for sale
timb
Posted: Sun Oct 12, 2008 2:12 pm Post subject: Brake Pad replacement |
Hi John,
Thanks for the info and link. I was actually just turning my tires around so they would wear on the other side, so packing bearings and such. The brakes are easy, but didn’t plan that so now need to wait to get parts and tools.
Thanks again.
Tim Bryan
RV-6 Flying
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Richard Dudley
Sent: Sunday, October 12, 2008 3:29 PM
To: rv-list(at)matronics.com
Subject: Re: Brake Pad replacement
Hi Tim,
Rich Dudley
----- Original Message -----
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
Sent: Sunday, October 12, 2008 4:07 PM
Subject: Brake Pad replacement
Tim Bryan
RV-6 Flying
N616TB over 100 hours now | Quote: | | href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c | | 0123456789 | Quote: | | href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List | 0 | Quote: | | href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List | 1 | Quote: | | href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List | 2 | Quote: | | href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List | 3 | Quote: | | href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List | 4
RV-6 Flying
N616TB |
Gary.A.Sobek
Posted: Sun Oct 12, 2008 3:00 pm Post subject: Brake Pad replacement |
If you do not mind spending a little extra money for the best rivet setting tool C order these dies for your hand rivet squeezer.
http://www.averytools.com/p-173-die-set-for-setting-brake-rivets.aspx
I like these dies in my hand squeezer better than ANY other brake rivet tool that I have seen. This is my opinion and someone else may have something they like better. These dies are what work best for me. Someone else may have something better that works for them.
Gary A. Sobek
"My Sanity" RV-6 N157GS O-320 Hartzell C
2 C156+ Flying Hours So. CA C USA
Subject: RE: Brake Pad replacement
Date: Sun C 12 Oct 2008 17:11:02 -0500
.ExternalClass p.EC_MsoNormal C .ExternalClass li.EC_MsoNormal C .ExternalClass div.EC_MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman' C'serif';} .ExternalClass a:link C .ExternalClass span.EC_MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited C .ExternalClass span.EC_MsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:'Courier New';} .ExternalClass span.EC_HTMLPreformattedChar {font-family:Consolas;} .ExternalClass span.EC_apple-style-span {;} .ExternalClass span.EC_EmailStyle20 {font-family:'Lucida Calligraphy';color:blue;font-weight:normal;font-style:normal;text-decoration:none none;} .ExternalClass span.EC_EmailStyle21 {font-family:'Lucida Calligraphy';color:blue;font-weight:normal;font-style:normal;text-decoration:none none;} .ExternalClass .EC_MsoChpDefault {font-size:10.0pt;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass div.EC_Section1 {page:Section1;}
Hi John C
Thanks for the info and link. I was actually just turning my tires around so they would wear on the other side C so packing bearings and such. The brakes are easy C but didn’t plan that so now need to wait to get parts and tools.
Thanks again.
Tim Bryan
RV-6 Flying
Sent: Sunday C October 12 C 2008 3:29 PM
Hi Tim C
Rich Dudley
Sent: Sunday C October 12 C 2008 4:07 PM
Tim Bryan
RV-6 Flying
| Quote: | | href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List | 5Stay up to date on your PC C the Web C and your mobile phone with/direct/01/' target='_new'>See Now [quote][b]
baremetl(at)gvtc.com Guest
Posted: Sun Oct 12, 2008 3:02 pm Post subject: Brake Pad replacement |
Tim,
The tool comes in two models: standard and deluxe. The ad says the deluxe model is threaded so you can assume the standard model is the hammer (impact) type. Having used both over the years, I would recommend the screw type. Well worth the extra $.If you break just one pad with the hammer type, you'll know what I mean. Not that I've ever broken one myself.......
Ivan Haecker -4 1506hrs. S. Cen. TX
HCRV6(at)comcast.net Guest
Posted: Sun Oct 12, 2008 4:59 pm Post subject: Brake Pad replacement |
timb
Posted: Sun Oct 12, 2008 5:34 pm Post subject: Brake Pad replacement |
Thanks everyone for the answers, links, and advice. I will be ordering a toolset tomorrow along with new brake pads. I can’t wait too long since I need to be able to fly. Condition Inspection is next month so trying to get ahead of the game.
Tim Bryan
RV-6 Flying
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of RV6 Flyer
Sent: Sunday, October 12, 2008 5:59 PM
If you do not mind spending a little extra money for the best rivet setting tool, order these dies for your hand rivet squeezer.
Gary A. Sobek
"My Sanity" RV-6 N157GS O-320 Hartzell,
2,156+ Flying Hours So. CA, USA
Date: Sun, 12 Oct 2008 17:11:02 -0500
Hi John,
Thanks again.
Tim Bryan
RV-6 Flying
Hi Tim,
Rich Dudley
Tim Bryan
RV-6 Flying
N616TB over 100 hours now | Quote: | | href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c | http://www.matronics.com/Navigator?RV-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution | 0
Stay up to date on your PC, the Web, and your mobile phone with/direct/01/' target='_new'>See Now 23456789 | Quote: | | href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List | 0 | Quote: | | href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List | 1 | Quote: | | href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List | 2 | Quote: | | href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List | 3 | Quote: | | href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List | 4 | Quote: | | href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List | 5 | Quote: | | href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List | 6 | Quote: | | href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List | 7 | Quote: | | href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List | 8 | Quote: | | href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List | 9 | Quote: | | href="http://forums.matronics.com">http://forums.matronics.com | 0 | Quote: | | href="http://forums.matronics.com">http://forums.matronics.com | 1
RV-6 Flying
N616TB |
bicyclop(at)pacbell.net Guest
Posted: Sun Oct 12, 2008 9:10 pm Post subject: Brake Pad replacement |
The Rapco brake rivet tool is really good.
http://www.aircraftspruce.com/catalog/topages/RapcoBrake.php
I like it better than the ones you hit with a hammer because it's really easy to overset those.
Pax,
Ed Holyoke
Richard Dudley wrote: [quote] (at)font-face { font-family: Calibri; } (at)font-face { font-family: Lucida Calligraphy; } (at)font-face { font-family: Consolas; } (at)page Section1 {size: 8.5in 11.0in; margin: 1.0in 1.0in 1.0in 1.0in; } P.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman","serif" } LI.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman","serif" } DIV.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman","serif" } A:link { COLOR: blue; TEXT-DECORATION: underline; mso-style-priority: 99 } SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline; mso-style-priority: 99 } A:visited { COLOR: purple; TEXT-DECORATION: underline; mso-style-priority: 99 } SPAN.MsoHyperlinkFollowed { COLOR: purple; TEXT-DECORATION: underline; mso-style-priority: 99 } PRE { FONT-SIZE: 10pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Courier New"; mso-style-priority: 99; mso-style-link: "HTML Preformatted Char" } SPAN.apple-style-span { mso-style-name: apple-style-span } SPAN.HTMLPreformattedChar { FONT-FAMILY: Consolas; mso-style-priority: 99; mso-style-link: "HTML Preformatted"; mso-style-name: "HTML Preformatted Char" } SPAN.EmailStyle20 { FONT-WEIGHT: normal; COLOR: blue; FONT-STYLE: normal; FONT-FAMILY: "Lucida Calligraphy"; TEXT-DECORATION: none; mso-style-type: personal-reply } .MsoChpDefault { FONT-SIZE: 10pt; mso-style-type: export-only } DIV.Section1 { page: Section1 } <![endif]--> <![endif]--> Hi Tim,
Rich Dudley
| Quote: | ----- Original Message -----
Tim Bryan
RV-6 Flying
| [b]
tcervin(at)embarqmail.com Guest
Posted: Mon Oct 13, 2008 3:03 pm Post subject: Brake Pad replacement |
Will this tool work on Matco caliper shoes?
Thanks, Tom in Ohio
